[PATCH] [RTEMS] Update RTEMS thread model
Mon Sep 14 14:00:23 UTC 2015
On Mon, Sep 14, 2015 at 7:33 AM, Sebastian Huber
> On 11/09/15 16:21, Aurelio Remonda wrote:
>>> The test runners are in "sim-scripts" make sure a "realview_pbx_a9_qemu
>>> >-i ticker.exe" produces the expected output.
>> Hi, silly question here, running ticker gave me the elapsed times
>> but not in 'real time'. It prints 09:00:00, 09:00:04,..., 09:00:34
>> immediately. Is this a normal behaviour for this test in this BSP?
> Yes, in case the fast idle is enabled (default). This helps to speed up test
> suite runs.
Any clue why the test is rounding off a second? It should give
09:00:00, 09:00:05, ..., 09:00:35
> devel mailing list
> devel at rtems.org
