[PATCH] [RTEMS] Update RTEMS thread model
Aurelio Remonda aurelio.remonda at tallertechnologies.com
Thu Sep 17 14:36:45 UTC 2015
> It is printing the "real time" but the time is set to a date early
> in the RTEMS development history. Look at the year. That's about the
> time the test was initially written.
> It is likely running faster than "real time" because it is a simulator.
> The numbers not ending in "5" is a bit unusual. The test consists of
> four tasks:
> + one runs every 5 seconds
> + one every 10
> + one every 15
> + IDLE
> It exits when one notices it has gone over 30 seconds.
Thank you Joel! I have another question if you don't mind: where i can find the realview_pbx_a9_qemu.exp file?
I can't find it in dejagnu/boards.
I did try making one (basically a copy of rtems-i386-qemu.exp with modifications), though. However, when I try:
make check 'RUNTESTFLAGS= SIM=realview_pbx_a9_qemu RTEMS_MAKEFILE_PATH=/home/aurelio-remonda/test-gcc/install-svn/arm-rtems4.11/realview_pbx_a9_qemu/ RTEMS_CONFIG_OBJ=/home/aurelio-remonda/test-gcc/rtems-testing/gcc/ --target_board=rtems-arm-realview_pbx_a9_qemu{-march=armv7-a/-mthumb/-mfpu=neon/-mfloat-abi=hard}'
I get a lot of 'compilation failed to produce executable' messages. The log tells me 'No libgloss support for this target'. At the end I get this:
		=== libstdc++ Summary ===
# of expected passes		2676
# of unexpected failures	3162
# of expected failures		6
# of unresolved testcases	3129
# of unsupported tests		808
runtest completed at Tue Sep 15 11:59:24 2015
