About cache enabling in LWIP port of BBB in RTEMS
Wed Sep 16 22:22:30 UTC 2015
On 9/16/2015 2:41 PM, ragu nath wrote:
> Hi Marcos,
> Great news! I did not  find any solution to the issue. I have a REV C board from element14. Is this the same board you are using?  In my board I saw the issue.
> Does this have anything to do with the patch you submitted [PATCH] Beaglebone: fix missing clobber in inline assembly. https://lists.rtems.org/pipermail/devel/2015-September/012531.html
> I have not yet tested with this patch.
> The freebsd driver is working with cache disabled.  If possible pls check if it is working with cache enabled in your board.
If this is a board revision related issue, is there a way programmatically to
know which revision the board is? That way the BSP could auto-detect the right
thing to do. Otherwise, we may be looking at a BSP variant or a build option.
I would rather avoid those if we can auto-detect.
--joel
> Thanks,
> Ragunath
> On Mon, Sep 14, 2015 at 7:22 PM, Marcos Díaz <marcos.diaz at tallertechnologies.com <mailto:marcos.diaz at tallertechnologies.com>> wrote:
>     Hi Ragu,
>     I wanted to know if you were able to see something else about the problem we had in the BBB when using LWIP and enabling cache ( the program freezes).
>     I can tell you that here we were using BBB rev. A5C and had this problem, but now we could test this with a BBB Rev C, and it successfully works with cache enabled (using the same sdcard in both boards, one works and the other doesn't).
>     Greetings
>     ______________________________
>     <http://www.tallertechnologies.com>
>     Marcos Díaz
>     Software Engineer
>     San Lorenzo 47, 3rd Floor, Office 5
>     Córdoba, Argentina
>     Phone:+54 351 4217888 / +54 351 4218211/ +54 351 7617452
>     Skype:markdiaz22
> ragu
