About cache enabling in LWIP port of BBB in RTEMS
ragu nath
ragunath3252 at gmail.com
Thu Sep 17 19:51:17 UTC 2015
Hi Marcos,
The following are the details from by board
###from uboot
board=am335x
board_name=A335BNLT
board_rev=00A5
### reg dump
0x44E10600 2b94402e
0x44E10604 20fd0383
###linux dump
hexdump -e '8/1 "%c"' "/sys/bus/i2c/devices/0-0050/eeprom" -s
0A5
Thanks,
Ragunath
On Fri, Sep 18, 2015 at 12:35 AM, Marcos Díaz <
marcos.diaz at tallertechnologies.com> wrote:
> Ragu,
> I would like you to confirm which revision you have, for this I printed
> the following registers in the BBB:
> 0x44E10600 and 0x44E10604
> The first will print something like:
> 1b94402e for BBB rev A5C (XAM3359AZCZ100) ( 1b means rev.A of the
> microcontroller)
> 2b94402e for BBB rev C (AM3358BZCZ100) (2b means rev B of the
> microcontroller)
> The second register will print something like:
> 20ff0383 for A5c (this means that this is AM3359)
> 20fd0383 for C (this means it is an AM3358).
> Please let me know which are this values in your Board.
> Thanks!
> On Thu, Sep 17, 2015 at 11:44 AM, Marcos Díaz <
>> Yes, sorry about that, There are two registers we can check to see the
>> different revision numbers. I will check it myself once i confirm that the
>> different revisions are the problem (i'm not sure because of what Ragu
>> said). Thanks!
>> On Thu, Sep 17, 2015 at 11:12 AM, Joel Sherrill <
>> joel.sherrill at oarcorp.com> wrote:
>>> On 9/17/2015 8:43 AM, Marcos Díaz wrote:
>>>> Yes, in my case the older (that doesn't work) revision is a
>>>> XAM3359AZCZ100
>>>> And the rev C (that works well with cache) is
>>>> AM3358BZCZ100
>>> Can we determine that in software?
>>> On Thu, Sep 17, 2015 at 10:32 AM, Joel Sherrill <
>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>> On September 17, 2015 8:26:41 AM CDT, "Marcos Díaz" <
>>>> marcos.diaz at tallertechnologies.com <mailto:
>>>> marcos.diaz at tallertechnologies.com>> wrote:
>>>> >Hi,
>>>> >How did you see the revision number? if you are using u-boot you
>>>> can
>>>> >pause the start and write printenv and enter to see that:
>>>> >board=am335x
>>>> >board_name=A335BNLT
>>>> >board_rev=00C0
>>>> >This is in my version.
>>>> >Please tell me so I can check if is the revision, or perhaps is
>>>> >something else in u-boot initialization.
>>>> >For the question Joel asked there is a way:
>>>> http://dumb-looks-free.blogspot.com.ar/2014/05/beaglebone-black-bbb-revision-serial.html
>>>> >apparently, in the eeprom thorugh i2c it is recorded. But first we
>>>> must
>>>> >confirm that is a problem from the revisions, since Ragu has the
>>>> >problem in a rev C.
>>>> Does the SoC itself have a revision number we can read? It may be
>>>> that newer boards have a newer CPU.
>>>> >Greetings
>>>> >On Wed, Sep 16, 2015 at 7:22 PM, Joel Sherrill
>>>> ><joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>
>>>> wrote:
>>>> >On 9/16/2015 2:41 PM, ragu nath wrote:
>>>> >Hi Marcos,
>>>> >Great news! I did not find any solution to the issue. I have a
>>>> REV C
>>>> >board from element14. Is this the same board you are using? In my
>>>> >board I saw the issue.
>>>> >Does this have anything to do with the patch you submitted [PATCH]
>>>> >Beaglebone: fix missing clobber in inline assembly.
>>>> https://lists.rtems.org/pipermail/devel/2015-September/012531.html
>>>> >I have not yet tested with this patch.
>>>> >The freebsd driver is working with cache disabled. If possible
>>>> pls
>>>> >check if it is working with cache enabled in your board.
>>>> >If this is a board revision related issue, is there a way
>>>> >programmatically to
>>>> >know which revision the board is? That way the BSP could
>>>> auto-detect
>>>> >the right
>>>> >thing to do. Otherwise, we may be looking at a BSP variant or a
>>>> build
>>>> >option.
>>>> >I would rather avoid those if we can auto-detect.
>>>> >--joel
>>>> >Thanks,
>>>> >Ragunath
>>>> >On Mon, Sep 14, 2015 at 7:22 PM, Marcos Díaz
>>>> ><marcos.diaz at tallertechnologies.com <mailto:
>>>> ><mailto:marcos.diaz at tallertechnologies.com <mailto:
>>>> marcos.diaz at tallertechnologies.com>>> wrote:
>>>> > Hi Ragu,
>>>> >I wanted to know if you were able to see something else about the
>>>> >problem we had in the BBB when using LWIP and enabling cache ( the
>>>> >program freezes).
>>>> >I can tell you that here we were using BBB rev. A5C and had this
>>>> >problem, but now we could test this with a BBB Rev C, and it
>>>> >successfully works with cache enabled (using the same sdcard in
>>>> both
>>>> >boards, one works and the other doesn't).
>>>> > Greetings
>>>> > ______________________________
>>>> > <http://www.tallertechnologies.com>
>>>> > Marcos Díaz
>>>> > Software Engineer
>>>> > San Lorenzo 47, 3rd Floor, Office 5
>>>> > Córdoba, Argentina
>>>> > Phone:+54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>> > Skype:markdiaz22
>>>> >ragu
>>>> >Joel Sherrill, Ph.D. Director of Research &
>>>> Development
>>>> >joel.sherrill at OARcorp.com On-Line Applications Research
>>>> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> >Support Available (256) 722-9985
>>>> >Marcos Díaz
>>>> >Software Engineer
>>>> >Córdoba, Argentina
>>>> >Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>> >Skype: markdiaz22
>>>> --joel
>>>> Marcos Díaz
>>>> Software Engineer
>>>> Córdoba, Argentina
>>>> Skype:markdiaz22
>>> Joel Sherrill, Ph.D. Director of Research & Development
>> Marcos Díaz
>> Software Engineer
>> Córdoba, Argentina
>> Skype: markdiaz22
> Marcos Díaz
> Software Engineer
> Córdoba, Argentina
> Skype: markdiaz22
ragu
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150918/1be02e1e/attachment-0001.html>
