About cache enabling in LWIP port of BBB in RTEMS
Marcos Díaz
marcos.diaz at tallertechnologies.com
Fri Sep 18 15:46:15 UTC 2015
By the way we flashed the eMMC with the u-boot image. Follow the guide to
know how to do so.
On Fri, Sep 18, 2015 at 12:42 PM, Marcos Díaz <
marcos.diaz at tallertechnologies.com> wrote:
> Well, after talking with the guys of beagleboard, they made me update the
> u-boot version.
> With that I could make the cache and ethernet work Ok in Rev A5C !!!.
> So, Ragu, if you can update your BBB's u-boot, try again using RTEMS with
> LWIP and cache enabled, and test it.
> Download it from here:
> https://rcn-ee.com/rootfs/bb.org/testing/2015-09-13/console/BBB-eMMC-flasher-debian-8.2-console-armhf-2015-09-13-2gb.img.xz
> md5sum: 64de53c03df006f2cb6f95244871313e
> decompress the image and save it in the sd card using dd.
> And this guide helped me:
> http://derekmolloy.ie/write-a-new-image-to-the-beaglebone-black/#Flashing_the_BBB_with_the_SD_Card_Image
> Hope it helps! Let me know how the tests go.
> Greetings!
> On Thu, Sep 17, 2015 at 5:53 PM, Marcos Díaz <
>> I can only tell you about the boards i tested:
>> I have a revision A5C board with an XAM3359AZCZ100 microcontroller. The
>> use of cache together with ethernet makes this break.
>> I have a revision C board with an AM3358BZCZ100. This does work with
>> cache and ethernet.
>> Apparently Ragu has a rev A5 with an AM3358BZCZ100. Cache doesn't work
>> for him.
>> After reading this document:
>> http://elinux.org/Beagleboard:BeagleBoneBlack#Board_Revisions_and_Changes
>> I can say that the boards I have match with that descripcion. Revisions
>> A4, A4A, A4B have an AM3352 processor,
>> rev A5A A5B A5C A6 A6A have an XAM3359, and revisions B and C have an
>> AM3358 processor.
>> I'm not very sure about what Ragu has, since there it says he has a rev
>> A5 (not mentioned in the document) but with the processor of the newer
>> revisions (AM3358).
>> In Ragu's case the checking of the registers for the processor revision
>> wont do any help, since he has the same processor that in my case works Ok,
>> but his doesn't.
>> Hope this clarifies.
>> On Thu, Sep 17, 2015 at 5:02 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> > wrote:
>>> Can of of you guys start a table/spreadsheet about board
>>> and SoC revisions and when we think it is broken and when
>>> it works?
>>> I emailed the BB project lead and he didn't know anything
>>> off hand but suggested subscribing to beagleboard at googlegroups.com
>>> and asking there. Someone there may actually have an answer.
>>> --joel
>>> On 9/17/2015 2:05 PM, Marcos Díaz wrote:
>>>> Ragu,
>>>> I would like you to confirm which revision you have, for this I printed
>>>> the following registers in the BBB:
>>>> 0x44E10600 and 0x44E10604
>>>> The first will print something like:
>>>> 1b94402e for BBB rev A5C (XAM3359AZCZ100) ( 1b means rev.A of the
>>>> microcontroller)
>>>> 2b94402e for BBB rev C (AM3358BZCZ100) (2b means rev B of the
>>>> microcontroller)
>>>> The second register will print something like:
>>>> 20ff0383 for A5c (this means that this is AM3359)
>>>> 20fd0383 for C (this means it is an AM3358).
>>>> Please let me know which are this values in your Board.
>>>> Thanks!
>>>> On Thu, Sep 17, 2015 at 11:44 AM, Marcos Díaz <
>>>> marcos.diaz at tallertechnologies.com <mailto:
>>>> marcos.diaz at tallertechnologies.com>> wrote:
>>>> Yes, sorry about that, There are two registers we can check to see
>>>> the different revision numbers. I will check it myself once i confirm that
>>>> the different revisions are the problem (i'm not sure because of what Ragu
>>>> said). Thanks!
>>>> On Thu, Sep 17, 2015 at 11:12 AM, Joel Sherrill <
>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>> On 9/17/2015 8:43 AM, Marcos Díaz wrote:
>>>> Yes, in my case the older (that doesn't work) revision is a
>>>> XAM3359AZCZ100
>>>> And the rev C (that works well with cache) is
>>>> AM3358BZCZ100
>>>> Can we determine that in software?
>>>> On Thu, Sep 17, 2015 at 10:32 AM, Joel Sherrill <
>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com> <mailto:
>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>> wrote:
>>>> On September 17, 2015 8:26:41 AM CDT, "Marcos Díaz" <
>>>> marcos.diaz at tallertechnologies.com> <mailto:
>>>> marcos.diaz at tallertechnologies.com>>> wrote:
>>>> >Hi,
>>>> >How did you see the revision number? if you are using
>>>> u-boot you can
>>>> >pause the start and write printenv and enter to see
>>>> that:
>>>> >board=am335x
>>>> >board_name=A335BNLT
>>>> >board_rev=00C0
>>>> >This is in my version.
>>>> >Please tell me so I can check if is the revision, or
>>>> perhaps is
>>>> >something else in u-boot initialization.
>>>> >For the question Joel asked there is a way:
>>>> http://dumb-looks-free.blogspot.com.ar/2014/05/beaglebone-black-bbb-revision-serial.html
>>>> >apparently, in the eeprom thorugh i2c it is recorded.
>>>> But first we must
>>>> >confirm that is a problem from the revisions, since
>>>> Ragu has the
>>>> >problem in a rev C.
>>>> Does the SoC itself have a revision number we can
>>>> read? It may be that newer boards have a newer CPU.
>>>> >Greetings
>>>> >On Wed, Sep 16, 2015 at 7:22 PM, Joel Sherrill
>>>> ><joel.sherrill at oarcorp.com <mailto:
>>>> joel.sherrill at oarcorp.com> <mailto:joel.sherrill at oarcorp.com <mailto:
>>>> >On 9/16/2015 2:41 PM, ragu nath wrote:
>>>> >Hi Marcos,
>>>> >Great news! I did not find any solution to the
>>>> issue. I have a REV C
>>>> >board from element14. Is this the same board you are
>>>> using? In my
>>>> >board I saw the issue.
>>>> >Does this have anything to do with the patch you
>>>> submitted [PATCH]
>>>> >Beaglebone: fix missing clobber in inline assembly.
>>>> https://lists.rtems.org/pipermail/devel/2015-September/012531.html
>>>> >I have not yet tested with this patch.
>>>> >The freebsd driver is working with cache disabled.
>>>> If possible pls
>>>> >check if it is working with cache enabled in your
>>>> board.
>>>> >If this is a board revision related issue, is there
>>>> a way
>>>> >programmatically to
>>>> >know which revision the board is? That way the BSP
>>>> could auto-detect
>>>> >the right
>>>> >thing to do. Otherwise, we may be looking at a BSP
>>>> variant or a build
>>>> >option.
>>>> >I would rather avoid those if we can auto-detect.
>>>> >--joel
>>>> >Thanks,
>>>> >Ragunath
>>>> >On Mon, Sep 14, 2015 at 7:22 PM, Marcos Díaz
>>>> ><marcos.diaz at tallertechnologies.com <mailto:
>>>> ><mailto:marcos.diaz at tallertechnologies.com <mailto:
>>>> marcos.diaz at tallertechnologies.com>>>> wrote:
>>>> > Hi Ragu,
>>>> >I wanted to know if you were able to see something
>>>> else about the
>>>> >problem we had in the BBB when using LWIP and
>>>> enabling cache ( the
>>>> >program freezes).
>>>> >I can tell you that here we were using BBB rev. A5C
>>>> and had this
>>>> >problem, but now we could test this with a BBB Rev
>>>> C, and it
>>>> >successfully works with cache enabled (using the
>>>> same sdcard in both
>>>> >boards, one works and the other doesn't).
>>>> > Greetings
>>>> > ______________________________
>>>> > <http://www.tallertechnologies.com>
>>>> > Marcos Díaz
>>>> > Software Engineer
>>>> > San Lorenzo 47, 3rd Floor, Office 5
>>>> > Córdoba, Argentina
>>>> > Phone:+54 351 4217888 / +54 351 4218211/ +54 351
>>>> 7617452
>>>> > Skype:markdiaz22
>>>> >ragu
>>>> >Joel Sherrill, Ph.D. Director of
>>>> Research & Development
>>>> >joel.sherrill at OARcorp.com On-Line
>>>> Applications Research
>>>> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> >Support Available (256) 722-9985
>>>> >Marcos Díaz
>>>> >Software Engineer
>>>> >Córdoba, Argentina
>>>> >Phone: +54 351 4217888 / +54 351 4218211/ +54 351
>>>> 7617452
>>>> >Skype: markdiaz22
>>>> --joel
>>>> Marcos Díaz
>>>> Software Engineer
>>>> Córdoba, Argentina
>>>> Phone:+54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>> Skype:markdiaz22
>>>> Joel Sherrill, Ph.D. Director of Research &
>>>> Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Marcos Díaz
>>>> Software Engineer
>>>> Córdoba, Argentina
>>>> Skype:markdiaz22
>>>> Marcos Díaz
>>>> Software Engineer
>>>> Córdoba, Argentina
>>>> Skype:markdiaz22
>>> Joel Sherrill, Ph.D. Director of Research & Development
>> Marcos Díaz
>> Software Engineer
>> Córdoba, Argentina
>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>> Skype: markdiaz22
> Marcos Díaz
> Software Engineer
> Córdoba, Argentina
> Skype: markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150918/6512bcb2/attachment-0001.html>
