Math lib inclusion in BSP
Fri Sep 25 01:01:23 UTC 2015
We usually link it later in the Makefile, e.g. see samples/paranoia I believe
On Thu, Sep 24, 2015 at 3:49 PM, sudarshan.rajagopalan
<sudarshan.rajagopalan at vecna.com> wrote:
> Hey all,
> We are developing a new BSP that uses math.h in few of the BSP files. I do
> understand that the math library functions are not part of standard C
> library and has to be linked using "-lm". So I include "LD_LIBS  += -lm" in
> the custom .cgf config file but this doesn't seem to work. I think this has
> to be linked in a proper order. Could someone help with this?
> Heres the custom config file:
> include $(RTEMS_ROOT)/make/custom/default.cfg
> RTEMS_CPU = arm
> LD_LIBS += -lm
> CPU_CFLAGS = -march=armv7-m -mthumb
> CFLAGS_OPTIMIZE_V = -O0 -g -mfloat-abi=hard -mfpu=fpv4-sp-d16
> Thanks and Regards,
> Sudarshan
> devel mailing list
> devel at rtems.org
