About cache enabling in LWIP port of BBB in RTEMS
ragu nath
ragunath3252 at gmail.com
Wed Sep 16 19:41:32 UTC 2015
Hi Marcos,
Great news! I did not find any solution to the issue. I have a REV C board
from element14. Is this the same board you are using? In my board I saw
the issue.
Does this have anything to do with the patch you submitted [PATCH]
Beaglebone: fix missing clobber in inline assembly.
https://lists.rtems.org/pipermail/devel/2015-September/012531.html
I have not yet tested with this patch.
The freebsd driver is working with cache disabled. If possible pls check
if it is working with cache enabled in your board.
Thanks,
Ragunath
On Mon, Sep 14, 2015 at 7:22 PM, Marcos Díaz <
marcos.diaz at tallertechnologies.com> wrote:
> Hi Ragu,
> I wanted to know if you were able to see something else about the problem
> we had in the BBB when using LWIP and enabling cache ( the program freezes).
> I can tell you that here we were using BBB rev. A5C and had this problem,
> but now we could test this with a BBB Rev C, and it successfully works with
> cache enabled (using the same sdcard in both boards, one works and the
> other doesn't).
> Greetings
> ______________________________
> <http://www.tallertechnologies.com>
> Marcos Díaz
> Software Engineer
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
> Skype: markdiaz22
ragu
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150917/9706071a/attachment-0002.html>
