About cache enabling in LWIP port of BBB in RTEMS
Marcos Díaz marcos.diaz at tallertechnologies.com
Thu Sep 17 14:44:54 UTC 2015
Yes, sorry about that, There are two registers we can check to see the
different revision numbers. I will check it myself once i confirm that the
different revisions are the problem (i'm not sure because of what Ragu
said). Thanks!
On Thu, Sep 17, 2015 at 11:12 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 9/17/2015 8:43 AM, Marcos Díaz wrote:
>> Yes, in my case the older (that doesn't work) revision is a
>> XAM3359AZCZ100
>> And the rev C (that works well with cache) is
>> AM3358BZCZ100
> Can we determine that in software?
> On Thu, Sep 17, 2015 at 10:32 AM, Joel Sherrill <joel.sherrill at oarcorp.com
>> <mailto:joel.sherrill at oarcorp.com>> wrote:
>>     On September 17, 2015 8:26:41 AM CDT, "Marcos Díaz" <
>> marcos.diaz at tallertechnologies.com <mailto:
>> marcos.diaz at tallertechnologies.com>> wrote:
>>     >Hi,
>>     >How did you see the revision number? if you are using u-boot you can
>>     >pause the start and write printenv and enter to see that:
>>     >board=am335x
>>     >board_name=A335BNLT
>>     >board_rev=00C0
>>     >This is in my version.
>>     >Please tell me so I can check if is the revision, or perhaps is
>>     >something else in u-boot initialization.
>>     >For the question Joel asked there is a way:
>> http://dumb-looks-free.blogspot.com.ar/2014/05/beaglebone-black-bbb-revision-serial.html
>>     >apparently, in the eeprom thorugh i2c it is recorded. But first we
>> must
>>     >confirm that is a problem from the revisions, since Ragu has the
>>     >problem in a rev C.
>>     Does the SoC itself have a revision number we can read? It may be
>> that newer boards have a newer CPU.
>>      >Greetings
>>      >On Wed, Sep 16, 2015 at 7:22 PM, Joel Sherrill
>>      ><joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>
>> wrote:
>>      >On 9/16/2015 2:41 PM, ragu nath wrote:
>>      >Hi Marcos,
>>      >Great news! I did not  find any solution to the issue. I have a REV
>> C
>>      >board from element14. Is this the same board you are using?  In my
>>      >board I saw the issue.
>>      >Does this have anything to do with the patch you submitted [PATCH]
>>      >Beaglebone: fix missing clobber in inline assembly.
>>      >https://lists.rtems.org/pipermail/devel/2015-September/012531.html
>>      >I have not yet tested with this patch.
>>      >The freebsd driver is working with cache disabled.  If possible pls
>>      >check if it is working with cache enabled in your board.
>>      >If this is a board revision related issue, is there a way
>>      >programmatically to
>>      >know which revision the board is? That way the BSP could auto-detect
>>      >the right
>>      >thing to do. Otherwise, we may be looking at a BSP variant or a
>> build
>>      >option.
>>      >I would rather avoid those if we can auto-detect.
>>      >--joel
>>      >Thanks,
>>      >Ragunath
>>      >On Mon, Sep 14, 2015 at 7:22 PM, Marcos Díaz
>>      ><marcos.diaz at tallertechnologies.com <mailto:
>>      ><mailto:marcos.diaz at tallertechnologies.com <mailto:
>> marcos.diaz at tallertechnologies.com>>> wrote:
>>      >    Hi Ragu,
>>      >I wanted to know if you were able to see something else about the
>>      >problem we had in the BBB when using LWIP and enabling cache ( the
>>      >program freezes).
>>      >I can tell you that here we were using BBB rev. A5C and had this
>>      >problem, but now we could test this with a BBB Rev C, and it
>>      >successfully works with cache enabled (using the same sdcard in both
>>      >boards, one works and the other doesn't).
>>      >    Greetings
>>      >    ______________________________
>>      >    <http://www.tallertechnologies.com>
>>      >    Marcos Díaz
>>      >    Software Engineer
>>      >    San Lorenzo 47, 3rd Floor, Office 5
>>      >    Córdoba, Argentina
>>      >    Phone:+54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>      >    Skype:markdiaz22
>>      >ragu
>>      >Joel Sherrill, Ph.D.             Director of Research & Development
>>      >joel.sherrill at OARcorp.com        On-Line Applications Research
>>      >Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>      >Support Available                (256) 722-9985
>>      >Marcos Díaz
>>      >Software Engineer
>>      >Córdoba, Argentina
>>      >Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>      >Skype: markdiaz22
>>     --joel
>> Marcos Díaz
>> Software Engineer
>> Córdoba, Argentina
>> Skype:markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150917/07d8143e/attachment-0002.html>
