[PATCH 04/15] score: Add node adjust to _RBTree_Find_inline()
Tue Apr 5 15:44:59 UTC 2016
On Tue, Apr 5, 2016 at 11:35 AM, Sebastian Huber
> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>> I don't understand the name "adjust"? I think of adjusting as
>> something that would cause a change or modify, which is not the case
>> here. I don't have any great replacement, but I guess I might suggest
>> "dereference"?
> You may adjust the pointer value, e.g. node + offset.  Dereference is wrong, since you are not supposed to do a *node.  Maybe "fixup"?
As I understand it, this callout does not modify the tree or node, so
I would avoid using any verb that implies a change happens: fixup
implies some modification to me. Perhaps I misunderstood, but the
comment says the callout should "get the return value" of a found
node. get_value() would be OK except for slight overload with POSIX
keys. read()?
I'm not coming up with any great ideas.
