Build failure for realview_pbx_a9_qemu_smp BSP
Darshit Shah
darnir at gmail.com
Tue Apr 12 22:29:22 UTC 2016
I recently tried rebuilding the realview_pbx_qemu_smp BSP with the
latest toolchain. However, it seems like the build is broken.
The compilation breaks when trying to build the sample Hello program.
The relevant part of the error given by make is:
Making all in hello
make[6]: Entering directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples/hello'
arm-rtems4.12-gcc -B../../../../../atsamv/lib/ -specs bsp_specs -qrtems -mthumb -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -O2 -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wl,--gc-sections -mthumb -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -o hello.exe init.o
../../../../../atsamv/lib/librtemscpu.a(libscore_a-smp.o): In function `_SMP_Handler_initialize':
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/cpukit/score/../../../../../../../src/rtems/c/src/../../cpukit/score/src/smp.c:100: undefined reference to `_CPU_SMP_Initialize'
../../../../../atsamv/lib/librtemscpu.a(libscore_a-smp.o): In function `_SMP_Start_processors':
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/cpukit/score/../../../../../../../src/rtems/c/src/../../cpukit/score/src/smp.c:50: undefined reference to `_CPU_SMP_Start_processor'
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/cpukit/score/../../../../../../../src/rtems/c/src/../../cpukit/score/src/smp.c:115: undefined reference to `_CPU_SMP_Finalize_initialization'
../../../../../atsamv/lib/librtemscpu.a(libscore_a-smp.o): In function `_SMP_Send_message':
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/cpukit/score/../../../../../../../src/rtems/c/src/../../cpukit/score/src/smp.c:182: undefined reference to `_CPU_SMP_Send_interrupt'
../../../../../atsamv/lib/librtemscpu.a(libscore_a-threadrestart.o): In function `_Per_CPU_Send_interrupt':
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/cpukit/score/../../cpukit/../../../atsamv/lib/include/rtems/score/percpu.h:628: undefined reference to `_CPU_SMP_Send_interrupt'
../../../../../atsamv/lib/librtemscpu.a(libscore_a-threadstartmultitasking.o): In function `_Thread_Start_multitasking':
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/cpukit/score/../../../../../../../src/rtems/c/src/../../cpukit/score/src/threadstartmultitasking.c:44: undefined reference to `_CPU_SMP_Prepare_start_multitasking'
../../../../../atsamv/lib/librtemsbsp.a(libbsp_a-cache_manager.o): In function `_CPU_cache_invalidate_instruction_range':
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/lib/libbsp/arm/atsam/../../../../../../../../../src/rtems/c/src/lib/libbsp/arm/atsam/../shared/armv7m/include/cache_.h:66: undefined reference to `rtems_interrupt_disable'
/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/lib/libbsp/arm/atsam/../../../../../../../../../src/rtems/c/src/lib/libbsp/arm/atsam/../shared/armv7m/include/cache_.h:68: undefined reference to `rtems_interrupt_enable'
collect2: error: ld returned 1 exit status
Makefile:626: recipe for target 'hello.exe' failed
make[6]: *** [hello.exe] Error 1
make[6]: Leaving directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples/hello'
Makefile:584: recipe for target 'all-local' failed
make[5]: *** [all-local] Error 1
make[5]: Leaving directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples'
Makefile:246: recipe for target 'all' failed
make[4]: *** [all] Error 2
make[4]: Leaving directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites/samples'
Makefile:314: recipe for target 'all-recursive' failed
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv/testsuites'
Makefile:425: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c/atsamv'
Makefile:286: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/thedoctor/Programming/rtems/builds/realview_pbx_a9_qemu_smp/arm-rtems4.12/c'
Makefile:410: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
I have tried adding the rtems/score/cpu.h header to the errant .c file,
but that doesn't help. Any ideas on what is causing this issue and how I
can fix it?
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160413/cc9fb05f/attachment.bin>
