[PATCH v2] Add RTEMS support for GCC libatomic
Sebastian Huber
Tue Apr 19 08:14:55 UTC 2016
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
newlib/libc/sys/rtems/crt0.c | 9 ++++-
newlib/libc/sys/rtems/include/machine/_libatomic.h | 46 ++++++++++++++++++++++
2 files changed, 54 insertions(+), 1 deletion(-)
create mode 100644 newlib/libc/sys/rtems/include/machine/_libatomic.h
diff --git a/newlib/libc/sys/rtems/crt0.c b/newlib/libc/sys/rtems/crt0.c
index 8d87fd4..3bf7083 100644
--- a/newlib/libc/sys/rtems/crt0.c
+++ b/newlib/libc/sys/rtems/crt0.c
@@ -16,6 +16,7 @@
#include <time.h> /* struct timespec */
#include <unistd.h> /* isatty */
#include <sys/lock.h> /* _Mutex_recursive_Control */
+#include <machine/_libatomic.h>
void rtems_provides_crt0( void ) {} /* dummy symbol so file always has one */
@@ -58,7 +59,13 @@ RTEMS_STUB(int, _Sched_Count(void), { return -1; })
RTEMS_STUB(int, _Sched_Index(void), { return -1; })
RTEMS_STUB(int, _Sched_Name_to_index(const char *p, size_t s), { return -1; })
RTEMS_STUB(int, _Sched_Processor_count(int i), { return 1; })
+/* Stubs for routines from RTEMS <machine/_libatomic.h> */
+RTEMS_STUB(__uint32_t, _Libatomic_Protect_start(void *ptr), { return 0; });
+RTEMS_STUB(void, _Libatomic_Protect_end(void *ptr, __uint32_t isr_level), { });
+RTEMS_STUB(void, _Libatomic_Lock_n(void *ptr, __size_t n), { });
+RTEMS_STUB(void, _Libatomic_Unlock_n(void *ptr, __size_t n), { });
#if defined(__GNUC__)
* stubs for libstdc++ rtems-threads support functions from gcc/gthr-rtems.h
diff --git a/newlib/libc/sys/rtems/include/machine/_libatomic.h b/newlib/libc/sys/rtems/include/machine/_libatomic.h
new file mode 100644
index 0000000..3456440
--- /dev/null
+++ b/newlib/libc/sys/rtems/include/machine/_libatomic.h
@@ -0,0 +1,46 @@
+ * Copyright (c) 2016 embedded brains GmbH
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * The libatomic is a part of GCC. It provides library support for C11/C++11
+ * atomic operations. This file defines the interface to the operating system
+ * for the RTEMS configuration of libatomic.
+#include <sys/cdefs.h>
+#include <sys/_types.h>
+__BEGIN_DECLS
+__uint32_t _Libatomic_Protect_start(void *);
+void _Libatomic_Protect_end(void *, __uint32_t);
+void _Libatomic_Lock_n(void *, __size_t);
+void _Libatomic_Unlock_n(void *, __size_t);
+__END_DECLS
1.8.4.5
