[PATCH v2] [libatomic] Add RTEMS support
Sebastian Huber
Tue Apr 19 12:56:30 UTC 2016
v2: Do not use architecture configuration due to broken ARM libatomic
support.
gcc/
* config/rtems.h (LIB_SPEC): Add -latomic.
libatomic/
* configure.tgt (*-*-rtems*): New supported target.
* config/rtems/host-config.h: New file.
* config/rtems/lock.c: Likewise.
gcc/config/rtems.h | 2 +-
libatomic/config/rtems/host-config.h | 41 ++++++++++++++++++++++++++++++++++++
libatomic/config/rtems/lock.c | 37 ++++++++++++++++++++++++++++++++
libatomic/configure.tgt | 10 +++++++++
4 files changed, 89 insertions(+), 1 deletion(-)
create mode 100644 libatomic/config/rtems/host-config.h
create mode 100644 libatomic/config/rtems/lock.c
diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
index f13f72f..e005547 100644
--- a/gcc/config/rtems.h
+++ b/gcc/config/rtems.h
@@ -45,6 +45,6 @@ see the files COPYING3 and COPYING.RUNTIME respectively. If not, see
#define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
"%{!nostdlib: %{qrtems: --start-group \
-lrtemsbsp -lrtemscpu \
- -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
+ -latomic -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
#define TARGET_POSIX_IO
diff --git a/libatomic/config/rtems/host-config.h b/libatomic/config/rtems/host-config.h
new file mode 100644
index 0000000..d11e9ef
--- /dev/null
+++ b/libatomic/config/rtems/host-config.h
@@ -0,0 +1,41 @@
+/* Copyright (C) 2016 Free Software Foundation, Inc.
+ Contributed by Sebastian Huber <sebastian.huber at embedded-brains.de>.
+ This file is part of the GNU Atomic Library (libatomic).
+ Libatomic is free software; you can redistribute it and/or modify it
+ under the terms of the GNU General Public License as published by
+ the Free Software Foundation; either version 3 of the License, or
+ (at your option) any later version.
+ Libatomic is distributed in the hope that it will be useful, but WITHOUT ANY
+ WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
+ FOR A PARTICULAR PURPOSE. See the GNU General Public License for
+ more details.
+ Under Section 7 of GPL version 3, you are granted additional
+ permissions described in the GCC Runtime Library Exception, version
+ 3.1, as published by the Free Software Foundation.
+ You should have received a copy of the GNU General Public License and
+ a copy of the GCC Runtime Library Exception along with this program;
+ see the files COPYING3 and COPYING.RUNTIME respectively. If not, see
+ <http://www.gnu.org/licenses/>. */
+/* Included after all more target-specific host-config.h. */
+#include <machine/_libatomic.h>
+static inline UWORD
+protect_start (void *ptr)
+ return _Libatomic_Protect_start (ptr);
+static inline void
+protect_end (void *ptr, UWORD isr_level)
+ _Libatomic_Protect_end (ptr, isr_level);
+#include_next <host-config.h>
diff --git a/libatomic/config/rtems/lock.c b/libatomic/config/rtems/lock.c
index 0000000..f999f9b
--- /dev/null
+++ b/libatomic/config/rtems/lock.c
@@ -0,0 +1,37 @@
+ more details.
+#include "libatomic_i.h"
+void
+libat_lock_n (void *ptr, size_t n)
+ _Libatomic_Lock_n (ptr, n);
+void
+libat_unlock_n (void *ptr, size_t n)
+ _Libatomic_Unlock_n (ptr, n);
diff --git a/libatomic/configure.tgt b/libatomic/configure.tgt
index c5470d7..eab2765 100644
--- a/libatomic/configure.tgt
+++ b/libatomic/configure.tgt
@@ -26,6 +26,10 @@
# Map the target cpu to an ARCH sub-directory. At the same time,
# work out any special compilation flags as necessary.
+# Give operating systems the opportunity to discard XCFLAGS modifications based
+# on ${target_cpu}. For example to allow proper use of multilibs.
+configure_tgt_pre_target_cpu_XCFLAGS="${XCFLAGS}"
case "${target_cpu}" in
alpha*)
# fenv.c needs this option to generate inexact exceptions.
@@ -128,6 +132,12 @@ case "${target}" in
esac
+ *-*-rtems*)
+ XCFLAGS="${configure_tgt_pre_target_cpu_XCFLAGS}"
+ config_path="rtems"
*-*-elf*)
# ??? No target OS. We could be targeting bare-metal kernel-mode,
# or user-mode for some custom OS. If the target supports TAS,
1.8.4.5
