[PATCH] arm: mx6ulevk: Initial BSP support for i.MX 6UltraLite EVK board.
Joel Sherrill
joel at rtems.org
Tue Apr 19 15:47:51 UTC 2016
On Tue, Apr 19, 2016 at 10:41 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Apr 19, 2016 at 9:59 AM, Joel Sherrill <joel at rtems.org> wrote:
> > A few quick things.
> > Add a bspimpl.h which is private to the bsp. Do not put anything in bsp.h
> > which
> > does not need to be public to the application. We have been exceedingly
> > uncaring about this in the past and the software tax to correct it is
> going
> > to
> > be painful. In general, the bsp.h probably doesn't need much except to
> > provide the BSP defaults for confdefs.h if it needs to change them.
> > And no.. there aren't any great examples yet.
> Another point is to check the current .cfg files for examples of how
> to add the per-function and per-sections LTO
+1 that would be a good think for the script to check.
As well as for the console table structure Sebastian recommended not using.
Also the new code should be warning free. It should also not result in
warnings in formerly warning free shared code.
The script isn't great but if we can use grep to help us review for
repeat offenders, then we can focus on harder issues.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160419/9ef372b7/attachment.html>
