[PATCH 11/13] mghttpd: Allow to have no timegm().
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 21 08:49:51 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
We currently don't have a timegm function. There seems to be no easy
way to replace this function with POSIX functions in a thread save
way. This patch just avoids the call.
Note that with this solution, the caching feature is effectively
disabled.
 cpukit/mghttpd/civetweb.c | 6 ++++++
 1 file changed, 6 insertions(+)
diff --git a/cpukit/mghttpd/civetweb.c b/cpukit/mghttpd/civetweb.c
index edc13d6..41c3eed 100644
--- a/cpukit/mghttpd/civetweb.c
+++ b/cpukit/mghttpd/civetweb.c
@@ -4918,6 +4918,7 @@ get_month_index(const char *s)
 /* Parse UTC date-time string, and return the corresponding time_t value. */
+#if !defined(NO_TIMEGM)
 static time_t
 parse_date_string(const char *datetime)
@@ -4971,6 +4972,7 @@ parse_date_string(const char *datetime)
 	return result;
+#endif /* !NO_TIMEGM */
 /* Protect against directory disclosure attack by removing '..',
@@ -7051,6 +7053,7 @@ substitute_index_file(struct mg_connection *conn,
 static int
 is_not_modified(const struct mg_connection *conn, const struct file *filep)
 	char etag[64];
 	const char *ims = mg_get_header(conn, "If-Modified-Since");
 	const char *inm = mg_get_header(conn, "If-None-Match");
@@ -7060,6 +7063,9 @@ is_not_modified(const struct mg_connection *conn, const struct file *filep)
 	return (inm != NULL && !mg_strcasecmp(etag, inm))
 	       || (ims != NULL && (filep->last_modified <= parse_date_string(ims)));
+#else /* NO_TIMEGM */
+	return false;
1.8.4.5
