[rtems commit] or1k/generic_or1k: Add per-section compilation and linking support
Hesham Almatary heshamelmatary at gmail.com
Mon Apr 4 05:00:17 UTC 2016
Should I "undo" this patch to get it working again?
On Sat, Apr 2, 2016 at 11:57 AM Gedare Bloom <gedare at rtems.org> wrote:
> ---------- Forwarded message ----------
> From: Hesham Almatary <heshamelmatary at gmail.com>
> Date: Fri, Apr 1, 2016 at 8:45 PM
> Subject: Re: [rtems commit] or1k/generic_or1k: Add per-section
> To: vc at rtems.org
> Cc: Stefan Wallentowitz <stefan at wallentowitz.de>
> hello and ticker fail to run with this commit.
> On Sat, Mar 12, 2016 at 7:14 AM Joel Sherrill <joel at rtems.org> wrote:
> > Module:    rtems
> > Branch:    master
> > Commit:    e1768fdd950fb24004183cdfdbef0bcd1a07908c
> > Changeset:
> http://git.rtems.org/rtems/commit/?id=e1768fdd950fb24004183cdfdbef0bcd1a07908c
> > Author:    Joel Sherrill <joel at rtems.org>
> > Date:      Thu Mar 10 16:28:12 2016 -0600
> > updates #2577.
> > For the generic_or1k BSP variant without this option sample
> > executables sizes were as follows:
> >    text    data     bss           dec             hex   filename
> >  255044    1780 33297600        33554424        1fffff8 ticker.exe
> >  188484    1496 33364448        33554428        1fffffc minimum.exe
> >  829728   77432 32647264        33554424        1fffff8 cxx_iostream.exe
> > 1110588    6112 32437728        33554428        1fffffc fileio.exe
> >  881676   14420 32658304        33554400        1ffffe0 pppd.exe
> >  428200    2556 33123648        33554404        1ffffe4 capture.exe
> >  274012    1868 33278528        33554408        1ffffe8 nsecs.exe
> >  398084    2184 33154144        33554412        1ffffec paranoia.exe
> >  387348    7420 33159648        33554416        1fffff0 cdtest.exe
> >  247752    1780 33304896        33554428        1fffffc base_sp.exe
> >  253888    1808 33298720        33554416        1fffff0 unlimited.exe
> >  261792    1752 33290880        33554424        1fffff8 hello.exe
> >  569612    6792 32978016        33554420        1fffff4 loopback.exe
> > For the generic_or1k BSP variant with this option sample executables
> >  229804    1760 33314592        33546156        1ffdfac ticker.exe
> >  118744    1424 33425984        33546152        1ffdfa8 minimum.exe
> >  607344   29188 32909632        33546164        1ffdfb4 cxx_iostream.exe
> > 1064124    6088 32475936        33546148        1ffdfa4 fileio.exe
> >  801832   14156 32730176        33546164        1ffdfb4 pppd.exe
> >  392908    2508 33150752        33546168        1ffdfb8 capture.exe
> >  249932    1848 33294368        33546148        1ffdfa4 nsecs.exe
> >  372320    2164 33171680        33546164        1ffdfb4 paranoia.exe
> >  361148    6980 33178016        33546144        1ffdfa0 cdtest.exe
> >  222004    1760 33322400        33546164        1ffdfb4 base_sp.exe
> >  222812    1772 33321568        33546152        1ffdfa8 unlimited.exe
> >  229764    1704 33314688        33546156        1ffdfac hello.exe
> >  515572    6576 33024000        33546148        1ffdfa4 loopback.exe
> >  c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg | 3 +++
> >  1 file changed, 3 insertions(+)
> > diff --git
> a/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> b/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> > index fff00ae..9a00643 100644
> > --- a/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> > +++ b/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> > @@ -5,3 +5,6 @@ RTEMS_CPU = or1k
> >  CPU_CFLAGS = -O2
> >  CFLAGS_OPTIMIZE_V ?= -O0 -g
> > +CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
> > +LDFLAGS = -Wl,--gc-sections
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
> vc mailing list
> vc at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160404/e4d07a09/attachment-0002.html>
