Fwd: [rtems commit] or1k/generic_or1k: Add per-section compilation and linking support
Gedare Bloom
gedare at rtems.org
Sat Apr 2 00:56:57 UTC 2016
---------- Forwarded message ----------
From: Hesham Almatary <heshamelmatary at gmail.com>
Date: Fri, Apr 1, 2016 at 8:45 PM
Subject: Re: [rtems commit] or1k/generic_or1k: Add per-section
To: vc at rtems.org
Cc: Stefan Wallentowitz <stefan at wallentowitz.de>
hello and ticker fail to run with this commit.
On Sat, Mar 12, 2016 at 7:14 AM Joel Sherrill <joel at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: e1768fdd950fb24004183cdfdbef0bcd1a07908c
> Changeset: http://git.rtems.org/rtems/commit/?id=e1768fdd950fb24004183cdfdbef0bcd1a07908c
> Author: Joel Sherrill <joel at rtems.org>
> Date: Thu Mar 10 16:28:12 2016 -0600
> updates #2577.
> For the generic_or1k BSP variant without this option sample
> executables sizes were as follows:
> text data bss dec hex filename
> 255044 1780 33297600 33554424 1fffff8 ticker.exe
> 188484 1496 33364448 33554428 1fffffc minimum.exe
> 829728 77432 32647264 33554424 1fffff8 cxx_iostream.exe
> 1110588 6112 32437728 33554428 1fffffc fileio.exe
> 881676 14420 32658304 33554400 1ffffe0 pppd.exe
> 428200 2556 33123648 33554404 1ffffe4 capture.exe
> 274012 1868 33278528 33554408 1ffffe8 nsecs.exe
> 398084 2184 33154144 33554412 1ffffec paranoia.exe
> 387348 7420 33159648 33554416 1fffff0 cdtest.exe
> 247752 1780 33304896 33554428 1fffffc base_sp.exe
> 253888 1808 33298720 33554416 1fffff0 unlimited.exe
> 261792 1752 33290880 33554424 1fffff8 hello.exe
> 569612 6792 32978016 33554420 1fffff4 loopback.exe
> For the generic_or1k BSP variant with this option sample executables
> 229804 1760 33314592 33546156 1ffdfac ticker.exe
> 118744 1424 33425984 33546152 1ffdfa8 minimum.exe
> 607344 29188 32909632 33546164 1ffdfb4 cxx_iostream.exe
> 1064124 6088 32475936 33546148 1ffdfa4 fileio.exe
> 801832 14156 32730176 33546164 1ffdfb4 pppd.exe
> 392908 2508 33150752 33546168 1ffdfb8 capture.exe
> 249932 1848 33294368 33546148 1ffdfa4 nsecs.exe
> 372320 2164 33171680 33546164 1ffdfb4 paranoia.exe
> 361148 6980 33178016 33546144 1ffdfa0 cdtest.exe
> 222004 1760 33322400 33546164 1ffdfb4 base_sp.exe
> 222812 1772 33321568 33546152 1ffdfa8 unlimited.exe
> 229764 1704 33314688 33546156 1ffdfac hello.exe
> 515572 6576 33024000 33546148 1ffdfa4 loopback.exe
> c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg | 3 +++
> 1 file changed, 3 insertions(+)
> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg b/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> index fff00ae..9a00643 100644
> --- a/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> +++ b/c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k.cfg
> @@ -5,3 +5,6 @@ RTEMS_CPU = or1k
> CPU_CFLAGS = -O2
> CFLAGS_OPTIMIZE_V ?= -O0 -g
> +CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
> +LDFLAGS = -Wl,--gc-sections
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
vc mailing list
vc at rtems.org
