BBB PWM driver development - GSOC 2016
punit vara punitvara at gmail.com
Mon Apr 4 17:15:30 UTC 2016
I am extremely sorry about my rough work. I have gone through coding
conversion. From next time I will strictly follow coding conventions and
publish my work in good way. It seems that I have to generate gpio
interface file for epwm pins same as André Marques used in i2c code for
rpi. Yes it is possible to stick close to the gpio framework. Right now my
primary focus is to implement pwm driver with minimum functions and utilize
epwm pins(for which pin muxing is not required as their by default mode
supports epwm) to generate pwm waveform with 50% duty cycle. Once I am
successful to generate pwm waveform and able to show demo then with
community we can decide where to add necessary functions.  Any suggestions
to make my primary task more focused are welcome.
Thank you,
Punit Vara
On Sun, Apr 3, 2016 at 6:29 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Please read https://devel.rtems.org/wiki/Developer/Coding/Conventions
> carefully including some of the linked pages related to style. Search
> back through this mailing list for discussions related to the gpio
> framework. Would it be sensible to stick close to the gpio framework
> and add pwm to it?
> On Fri, Apr 1, 2016 at 4:10 PM, punit vara <punitvara at gmail.com> wrote:
> > Recently Worth Burruss suggested me function prototype for getting
> started
> > to develop PWM driver.  I updated my blog
> > http://punitvara.github.io/rtems%20drivers/2016/02/28/basic-function
> with
> > sample functions.
> > rtems_status_code SetDutyCycle(int subSystemNumber,float HZ, float
> > DutyCycleA, float DutyCycleB);
> > void PWMSubSystemEnable(int subSytemNumber,bool EnableOrDisable);
> > I have written this function at
> > https://github.com/punitvara/rtems_gsoc16/blob/master/pwd/worth.c
> > Marcos, can you please look at blog and function definition? Do you have
> > advice for me ?
> > Thanks,
> > Punit Vara
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160404/91d8da76/attachment-0002.html>
