[examples-v2 1/2] Compile filesystem testcase
Peng Fan van.freenix at gmail.com
Sat Apr 9 01:11:57 UTC 2016
Hi Gedare,
I met error when `waf`:
"ImportError: No module named rtems_waf.rtems"
This patch will not be accpetted, if switch to use waf? If you plan to
accpet this patch,
I can discard signed off and send out V2.
Thanks,
Peng.
2016-04-08 19:55 GMT+08:00 Gedare Bloom <gedare at rtems.org>:
> you can remove --signed-off-by
> do you know if the filesystem testcases are compiled correctly when
> using the rtems_waf approach to building examples-v2?
> On Fri, Apr 8, 2016 at 4:33 AM, Peng Fan <van.freenix at gmail.com> wrote:
> > Support compiling filesystem testcases.
> > If not, filesystem testcases will not be compiled.
> > Signed-off-by: Peng Fan <van.freenix at gmail.com>
> >  Makefile            | 2 +-
> >  filesystem/Makefile | 5 +++++
> >  2 files changed, 6 insertions(+), 1 deletion(-)
> >  create mode 100644 filesystem/Makefile
> > diff --git a/Makefile b/Makefile
> > index 95d08fb..99b83e3 100644
> > --- a/Makefile
> > +++ b/Makefile
> > @@ -3,7 +3,7 @@ include $(RTEMS_CUSTOM)
> >  include $(RTEMS_SHARE)/make/directory.cfg
> >  SUBDIRS=classic_api posix_api hello led misc ticker file_io \
> > -  benchmarks
> > +  benchmarks filesystem
> >  # Monitor Specific Examples
> >  SUBDIRS += uboot
> > diff --git a/filesystem/Makefile b/filesystem/Makefile
> > new file mode 100644
> > index 0000000..1267598
> > --- /dev/null
> > +++ b/filesystem/Makefile
> > @@ -0,0 +1,5 @@
> > +include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> > +include $(RTEMS_CUSTOM)
> > +include $(RTEMS_SHARE)/make/directory.cfg
> > +SUBDIRS = fat_ramdisk
> > 2.6.2
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160409/acc83f6a/attachment-0002.html>
