[PATCH] doc: source-builder.txt: Update installtion for ubuntu packages
Mon Aug 1 18:45:23 UTC 2016
committed, thanks.
On Thu, Jul 28, 2016 at 4:05 PM, Punit Vara <punitvara at gmail.com> wrote:
>         This patch fixes the most common python missing error for RTEMS
>         tool chain build and RSB built is tested for ubuntu 16.04.1 LTS
>  doc/source-builder.txt | 5 +++--
>  1 file changed, 3 insertions(+), 2 deletions(-)
> diff --git a/doc/source-builder.txt b/doc/source-builder.txt
> index 43bcf77..8b0cd89 100644
> --- a/doc/source-builder.txt
> +++ b/doc/source-builder.txt
> @@ -3098,11 +3098,12 @@ home directory as recommended and end up on the SD card.
>  Ubuntu
> -The latest testing was with Ubuntu 13.10 64bit. This section also includes Xubuntu. A
> +The latest testing was with Ubuntu 16.04.1 LTS 64bit. This section also includes Xubuntu. A
>  minimal installation was used and the following packages installed.
> -$ sudo apt-get build-dep binutils gcc g++ gdb unzip git python2.7-dev
> +$ sudo apt-get build-dep binutils gcc g++ gdb unzip git
> +$ sudo apt-get install python2.7-dev
>  FreeBSD
> 2.7.4
