[PATCH]doc:source-builder.txt:Typographical errors
Sambeet Panigrahi
sambeet161616 at gmail.com
Sat Aug 6 11:23:48 UTC 2016
>From 137ed5e54a06738752d18982fcab9d90070e58cc Mon Sep 17 00:00:00 2001
Date: Sat, 6 Aug 2016 14:28:11 +0530
Subject: [PATCH] Typo in rsb doc
doc/source-builder.txt | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/source-builder.txt b/doc/source-builder.txt
index b07b129..221ffb1 100644
--- a/doc/source-builder.txt
+++ b/doc/source-builder.txt
@@ -1384,7 +1384,7 @@ the decompression tool and all other files must be in
the tar file format.
The +%source+ directive typically supports a single source file tar or zip
file. The +set+ command is used to set the URL for a specific source
group. The
-first set command encoutner is registered and any further set commands are
+first set command encounter is registered and any further set commands are
ignored. This allows you to define a base standard source location and
override
it in build and architecture specific files. You can also add extra source
files to a group. This is typically done when a collection of source is
broken
@@ -1855,8 +1855,8 @@ packages based on the outer configuration options.
The remainder of the script is broken in to the various phases of a build.
They
are:
-. Preperation
-. Bulding
+. Preparation
+. Building
. Installing, and
. Cleaning
1.9.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160806/6132ec6e/attachment-0001.html>
