[PATCH]doc:source-builder.txt:Typographical errors
Mon Aug 8 14:45:30 UTC 2016
This email did not come through right. Did you use git-send-email?
On Sat, Aug 6, 2016 at 7:23 AM, Sambeet Panigrahi
<sambeet161616 at gmail.com> wrote:
> From 137ed5e54a06738752d18982fcab9d90070e58cc Mon Sep 17 00:00:00 2001
> From: Sambeet Panigrahi <b313036 at iiit-bh.ac.in>
> Date: Sat, 6 Aug 2016 14:28:11 +0530
> Subject: [PATCH] Typo in rsb doc
>  doc/source-builder.txt | 6 +++---
>  1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/doc/source-builder.txt b/doc/source-builder.txt
> index b07b129..221ffb1 100644
> --- a/doc/source-builder.txt
> +++ b/doc/source-builder.txt
> @@ -1384,7 +1384,7 @@ the decompression tool and all other files must be in
> the tar file format.
>  The +%source+ directive typically supports a single source file tar or zip
>  file. The +set+ command is used to set the URL for a specific source group.
> The
> -first set command encoutner is registered and any further set commands are
> +first set command encounter is registered and any further set commands are
>  ignored. This allows you to define a base standard source location and
> override
>  it in build and architecture specific files. You can also add extra source
>  files to a group. This is typically done when a collection of source is
> broken
> @@ -1855,8 +1855,8 @@ packages based on the outer configuration options.
>  The remainder of the script is broken in to the various phases of a build.
> They
>  are:
> -. Preperation
> -. Bulding
> +. Preparation
> +. Building
>  . Installing, and
>  . Cleaning
> 1.9.1
> devel mailing list
> devel at rtems.org
