[PATCH 2/4] libdl: Fix cache corruption bugs.
Fri Aug 12 09:21:01 UTC 2016
This patch fixes a number of bugs in the cache when requests are
made to read close to the end of the file and the data is copied
from the top of the cache buffer to the bottom of the buffer. This
was compounded by attempting to read past the end of the file.
Closes #2754.
 cpukit/libdl/rtl-obj-cache.c | 87 +++++++++++++++++++++++++++++++++++---------
 cpukit/libdl/rtl-trace.c     |  4 +-
 cpukit/libdl/rtl-trace.h     | 25 +++++++------
 3 files changed, 86 insertions(+), 30 deletions(-)
diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
index 9221765..fd1e945 100644
--- a/cpukit/libdl/rtl-obj-cache.c
+++ b/cpukit/libdl/rtl-obj-cache.c
@@ -19,12 +19,14 @@
 #endif
+#include <stdio.h>
 #include <unistd.h>
 #include <rtems/rtl/rtl-allocator.h>
 #include "rtl-obj-cache.h"
 #include "rtl-error.h"
+#include "rtl-trace.h"
 bool
 rtems_rtl_obj_cache_open (rtems_rtl_obj_cache_t* cache, size_t size)
@@ -46,7 +48,10 @@ rtems_rtl_obj_cache_open (rtems_rtl_obj_cache_t* cache, size_t size)
 void
 rtems_rtl_obj_cache_close (rtems_rtl_obj_cache_t* cache)
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_CACHE))
+    printf ("rtl: cache: %2d: close\n", cache->fd);
   rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, cache->buffer);
+  cache->buffer    = NULL;
   cache->fd        = -1;
   cache->file_size = 0;
   cache->level     = 0;
@@ -55,8 +60,11 @@ rtems_rtl_obj_cache_close (rtems_rtl_obj_cache_t* cache)
 void
 rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache_t* cache)
+    printf ("rtl: cache: %2d: flush\n", cache->fd);
   cache->fd        = -1;
+  cache->offset    = 0;
   cache->level     = 0;
@@ -69,6 +77,13 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
   struct stat sb;
+    printf ("rtl: cache: %2d: fd=%d offset=%d length=%d area=[%d,%d] cache=[%d,%d] size=%d\n",
+            fd, cache->fd, (int) offset, (int) *length,
+            (int) offset, (int) offset + *length,
+            (int) cache->offset, (int) cache->offset + cache->level,
+            (int) cache->file_size);
   if (*length > cache->size)
     rtems_rtl_set_error (EINVAL, "read size larger than cache size");
@@ -84,8 +99,15 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
       return false;
+     * We sometimes are asked to read strings of a length we do not know.
     if ((offset + *length) > cache->file_size)
       *length = cache->file_size - offset;
+        printf ("rtl: cache: %2d: truncate length=%d\n", fd, (int) length);
   while (true)
@@ -99,12 +121,21 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
     if (fd == cache->fd)
+       * Do not read past the end of the file.
+      if ((offset + buffer_read) > cache->file_size)
+        buffer_read = cache->file_size - offset;
        * Is any part of the data in the cache ?
       if ((offset >= cache->offset) &&
           (offset < (cache->offset + cache->level)))
+        size_t size;
         buffer_offset = offset - cache->offset;
+        size          = cache->level - buffer_offset;
          * Return the location of the data in the cache.
@@ -114,24 +145,38 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
          * Is all the data in the cache or just a part ?
-        if (*length <= (cache->level - buffer_offset))
+        if (*length <= size)
           return true;
+          printf ("rtl: cache: %2d: copy-down: buffer_offset=%d size=%d level=%d\n",
+                  fd, (int) buffer_offset, (int) size, (int) cache->level);
-         * Copy down the data in the buffer and then fill the remaining
-         * space with as much data we are able to read.
+         * Copy down the data in the buffer and then fill the remaining space
+         * with as much data we are able to read.
-        memmove (cache->buffer,
-                 cache->buffer + buffer_offset,
-                 cache->size - buffer_offset);
+        memmove (cache->buffer, cache->buffer + buffer_offset, size);
+        cache->offset = offset;
+        cache->level  = size;
+        buffer_read   = cache->size - cache->level;
+        buffer_offset = size;
-        buffer_read   = buffer_offset;
-        buffer_offset = cache->size - buffer_offset;
+        if ((offset + buffer_offset + buffer_read) > cache->file_size)
+          buffer_read = cache->file_size - (offset + buffer_offset);
+      printf ("rtl: cache: %2d: seek: offset=%d buffer_offset=%d read=%d cache=[%d,%d] dist=%d\n",
+              fd, (int) offset + buffer_offset, (int) buffer_offset, (int) buffer_read,
+              (int) offset, (int) offset + buffer_read,
+              (int) (cache->file_size - offset));
     if (lseek (fd, offset + buffer_offset, SEEK_SET) < 0)
       rtems_rtl_set_error (errno, "file seek failed");
@@ -143,7 +188,9 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
      * returned and if data has been read check if the amount is what we
      * want. If not it is an error. A POSIX read can read data in fragments.
-    cache->level = buffer_read;
+    cache->level = buffer_offset + buffer_read;
     while (buffer_read)
       int r = read (fd, cache->buffer + buffer_offset, buffer_read);
@@ -154,6 +201,8 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
       if ((r == 0) && buffer_read)
+          printf ("rtl: cache: %2d: read: past end by=%d\n", fd, (int) buffer_read);
         cache->level = cache->level - buffer_read;
         buffer_read = 0;
@@ -164,16 +213,20 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
-    cache->fd = fd;
-    if (fstat (cache->fd, &sb) < 0)
+    if (cache->fd != fd)
-      rtems_rtl_set_error (errno, "file stat failed");
-      return false;
+      cache->fd = fd;
+      if (fstat (cache->fd, &sb) < 0)
+        rtems_rtl_set_error (errno, "file stat failed");
+        return false;
-    cache->file_size = sb.st_size;
+      cache->file_size = sb.st_size;
   return false;
diff --git a/cpukit/libdl/rtl-trace.c b/cpukit/libdl/rtl-trace.c
index fee8de1..42b3995 100644
--- a/cpukit/libdl/rtl-trace.c
+++ b/cpukit/libdl/rtl-trace.c
@@ -58,6 +58,8 @@ rtems_rtl_trace_shell_command (int argc, char *argv[])
   const char* table[] =
+    "detail",
+    "warning",
     "load",
     "unload",
     "section",
@@ -67,7 +69,7 @@ rtems_rtl_trace_shell_command (int argc, char *argv[])
     "load-sect",
     "allocator",
     "unresolved",
-    "detail"
+    "cache"
   rtems_rtl_trace_mask set_value = 0;
diff --git a/cpukit/libdl/rtl-trace.h b/cpukit/libdl/rtl-trace.h
index 6c060a1..4b93c8c 100644
--- a/cpukit/libdl/rtl-trace.h
+++ b/cpukit/libdl/rtl-trace.h
@@ -36,18 +36,19 @@ typedef uint32_t rtems_rtl_trace_mask;
  * List of tracing bits for the various parts of the link editor.
-#define RTEMS_RTL_TRACE_ALL                    (0xffffffffUL)
-#define RTEMS_RTL_TRACE_LOAD                   (1UL << 0)
-#define RTEMS_RTL_TRACE_UNLOAD                 (1UL << 1)
-#define RTEMS_RTL_TRACE_SECTION                (1UL << 2)
-#define RTEMS_RTL_TRACE_SYMBOL                 (1UL << 3)
-#define RTEMS_RTL_TRACE_RELOC                  (1UL << 4)
-#define RTEMS_RTL_TRACE_GLOBAL_SYM             (1UL << 5)
-#define RTEMS_RTL_TRACE_LOAD_SECT              (1UL << 6)
-#define RTEMS_RTL_TRACE_ALLOCATOR              (1UL << 7)
-#define RTEMS_RTL_TRACE_UNRESOLVED             (1UL << 8)
-#define RTEMS_RTL_TRACE_DETAIL                 (1UL << 9)
-#define RTEMS_RTL_TRACE_WARNING                (1UL << 10)
+#define RTEMS_RTL_TRACE_DETAIL                 (1UL << 0)
+#define RTEMS_RTL_TRACE_WARNING                (1UL << 1)
+#define RTEMS_RTL_TRACE_LOAD                   (1UL << 2)
+#define RTEMS_RTL_TRACE_UNLOAD                 (1UL << 3)
+#define RTEMS_RTL_TRACE_SECTION                (1UL << 4)
+#define RTEMS_RTL_TRACE_SYMBOL                 (1UL << 5)
+#define RTEMS_RTL_TRACE_RELOC                  (1UL << 6)
+#define RTEMS_RTL_TRACE_GLOBAL_SYM             (1UL << 7)
+#define RTEMS_RTL_TRACE_LOAD_SECT              (1UL << 8)
+#define RTEMS_RTL_TRACE_ALLOCATOR              (1UL << 9)
+#define RTEMS_RTL_TRACE_UNRESOLVED             (1UL << 10)
+#define RTEMS_RTL_TRACE_CACHE                  (1UL << 11)
+#define RTEMS_RTL_TRACE_ALL                    (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE))
  * Call to check if this part is bring traced. If RTEMS_RTL_TRACE is defined to
2.4.6
