[PATCH 2/2] RTEMS changes for lpc32xx VFP support
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Fri Aug 19 00:16:13 UTC 2016
diff --git a/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc b/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc
old mode 100644
new mode 100755
index f184741..1d478ce
--- a/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc
+++ b/c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc
@@ -6,7 +6,8 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU = arm
-CPU_CFLAGS = -mcpu=arm926ej-s -mthumb
+#CPU_CFLAGS = -mcpu=arm926ej-s -mthumb
+CPU_CFLAGS = -mcpu=arm926ej-s -mfpu=vfp -mfloat-abi=softfp
CFLAGS_OPTIMIZE_V ?= -O2 -g
CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
old mode 100644
new mode 100755
index 30501be..cb3bff7
--- a/c/src/lib/libbsp/arm/shared/start/start.S
+++ b/c/src/lib/libbsp/arm/shared/start/start.S
@@ -19,9 +19,9 @@
#include <rtems/asm.h>
-#include <rtems/system.h>
+#include <rtems/system.h>
#include <rtems/score/cpu.h>
#include <bspopts.h>
#include <bsp/irq.h>
#include <bsp/linker-symbols.h>
@@ -265,6 +265,7 @@ bsp_start_skip_hyp_svc_switch:
/* Stay in SVC mode */
#ifdef ARM_MULTILIB_VFP
+#ifndef ARM_MULTILIB_ARCH_V5TEJ
/* Read CPACR */
mrc p15, 0, r0, c1, c0, 2
@@ -280,11 +281,18 @@ bsp_start_skip_hyp_svc_switch:
/* Write CPACR */
mcr p15, 0, r0, c1, c0, 2
isb
+#endif
/* Enable FPU */
mov r0, #(1 << 30)
vmsr FPEXC, r0
+#ifdef ARM_MULTILIB_ARCH_V5TEJ
+ /* Enable FPU Run Fast*/
+ mov r0, #(3 << 24)
+ vmsr FPSCR, r0
+#endif
#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
bl bsp_start_init_registers_vfp
#endif
@@ -399,6 +407,7 @@ _start:
#endif
* Enable CP10 and CP11 coprocessors for privileged and user mode in
* CPACR (bits 20-23). Ensure that write to register completes.
@@ -409,6 +418,7 @@ _start:
str r1, [r0]
dsb
isb
+#endif
diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
old mode 100644
new mode 100755
index fdfb6c1..6485993
--- a/cpukit/score/cpu/arm/arm-context-validate.S
+++ b/cpukit/score/cpu/arm/arm-context-validate.S
@@ -46,7 +46,11 @@
.section .text
+#ifdef __thumb__
FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
+#else
+FUNCTION_ENTRY(_CPU_Context_validate)
+#endif
/* Save */
@@ -99,12 +103,16 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
/* R3 contains the FPSCR */
vmrs r3, FPSCR
+ ldr r4, =0xf000001f
+#else
movs r4, #0x001f
#ifdef ARM_MULTILIB_ARCH_V7M
movt r4, #0xf000
#else
movt r4, #0xf800
#endif
+#endif
bic r3, r3, r4
and r4, r4, r0
orr r3, r3, r4
diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
old mode 100644
new mode 100755
index 7970b8e..cf3f428
--- a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
+++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
@@ -20,7 +20,11 @@
.section .text
+#ifdef __thumb__
FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
+#else
+FUNCTION_ENTRY(_CPU_Context_volatile_clobber)
+#endif
.macro clobber_register reg
sub r0, r0, #1
@@ -29,8 +33,12 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
vmrs r1, FPSCR
+ ldr r2, =0xf800001f
+#else
movs r2, #0x001f
movt r2, #0xf800
+#endif
bic r1, r1, r2
and r2, r2, r0
orr r1, r1, r2
diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
old mode 100644
new mode 100755
index 666ee54..929585e
--- a/cpukit/score/cpu/arm/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/rtems/score/arm.h
@@ -35,6 +35,10 @@ extern "C" {
#elif defined(__ARM_ARCH_6M__)
#define CPU_MODEL_NAME "ARMv6M"
#define ARM_MULTILIB_ARCH_V6M
+#elif defined(__ARM_ARCH_5TEJ__)
+ #define CPU_MODEL_NAME "ARMv5TEJ"
+ #define ARM_MULTILIB_ARCH_V5TEJ
+ #define ARM_MULTILIB_ARCH_V4
#else
#define CPU_MODEL_NAME "ARMv4"
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160819/8e45af3e/attachment-0001.html>
