[PATCH] Added interrupt handler for SD card
Mudit Jain muditjain18011995 at gmail.com
Sat Aug 20 16:10:04 UTC 2016
This is in accordance with the information
in the datasheet and has been verified with the
linux source code for RPi
 c/src/lib/libbsp/arm/raspberrypi/include/irq.h |  1 +
 c/src/lib/libbsp/arm/raspberrypi/irq/irq.c     | 15 +++++++++++++++
 2 files changed, 16 insertions(+)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
index 8436c2d..e3b4e7d 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
@@ -51,6 +51,7 @@
 #define BCM2835_IRQ_ID_UART          57
+#define BCM2835_IRQ_ID_SDCARD        62
 #define BCM2835_IRQ_ID_TIMER_0       64
 #define BCM2835_IRQ_ID_MAILBOX_0     65
 #define BCM2835_IRQ_ID_DOORBELL_0    66
diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
index 7b3b2be..c205ef7 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
@@ -91,6 +91,11 @@ void bsp_interrupt_dispatch(void)
       vector = BCM2835_IRQ_ID_SPI;
+  /* SD CARD */
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(30) )
+      vector = BCM2835_IRQ_ID_SDCARD;
   if ( vector < 255 )
@@ -144,6 +149,11 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
       BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(22);
+  /* SD CARD */
+  else if ( vector == BCM2835_IRQ_ID_SDCARD )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(30);
   rtems_interrupt_enable(level);
@@ -194,6 +204,11 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
       BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(22);
+  /* SD CARD */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_REG(30);
1.9.1
