[PATCH 1/5] SD Card : Initial Port of DMA Controller
Mudit Jain muditjain18011995 at gmail.com
Mon Aug 22 03:57:48 UTC 2016
This is the initial port of the DMA controller
from the libbsd using freebsd-to-rtems.py
This change is dependent on the interrupt handler
in the Mainline.
 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c   | 768 +++++++++++++++++++++++
 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h   |  60 ++
 freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h |  72 +++
 libbsd.py                                        |  13 +
 libbsd_waf.py                                    |   3 +-
 5 files changed, 915 insertions(+), 1 deletion(-)
 create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
 create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h
 create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
new file mode 100644
index 0000000..98dd2cf
--- /dev/null
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
@@ -0,0 +1,768 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2013 Daisuke Aoyama <aoyama at peach.ne.jp>
+ * Copyright (c) 2013 Oleksandr Tymoshenko <gonzo at bluezbox.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <sys/queue.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/rman.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <vm/vm.h>
+#include <vm/pmap.h>
+#include <machine/bus.h>
+#include <machine/cpu.h>
+#include <machine/cpufunc.h>
+#include "bcm2835_dma.h"
+#include "bcm2835_vcbus.h"
+#define	MAX_REG			9
+/* private flags */
+#define	BCM_DMA_CH_USED		0x00000001
+#define	BCM_DMA_CH_FREE		0x40000000
+#define	BCM_DMA_CH_UNMAP	0x80000000
+/* Register Map (4.2.1.2) */
+#define	BCM_DMA_CS(n)		(0x100*(n) + 0x00)
+#define		CS_ACTIVE		(1 <<  0)
+#define		CS_END			(1 <<  1)
+#define		CS_INT			(1 <<  2)
+#define		CS_DREQ			(1 <<  3)
+#define		CS_ISPAUSED		(1 <<  4)
+#define		CS_ISHELD		(1 <<  5)
+#define		CS_ISWAIT		(1 <<  6)
+#define		CS_ERR			(1 <<  8)
+#define		CS_WAITWRT		(1 << 28)
+#define		CS_DISDBG		(1 << 29)
+#define		CS_ABORT		(1 << 30)
+#define		CS_RESET		(1U << 31)
+#define	BCM_DMA_CBADDR(n)	(0x100*(n) + 0x04)
+#define	BCM_DMA_INFO(n)		(0x100*(n) + 0x08)
+#define		INFO_INT_EN		(1 << 0)
+#define		INFO_TDMODE		(1 << 1)
+#define		INFO_WAIT_RESP		(1 << 3)
+#define		INFO_D_INC		(1 << 4)
+#define		INFO_D_WIDTH		(1 << 5)
+#define		INFO_D_DREQ		(1 << 6)
+#define		INFO_S_INC		(1 << 8)
+#define		INFO_S_WIDTH		(1 << 9)
+#define		INFO_S_DREQ		(1 << 10)
+#define		INFO_WAITS_SHIFT	(21)
+#define		INFO_PERMAP_SHIFT	(16)
+#define		INFO_PERMAP_MASK	(0x1f << INFO_PERMAP_SHIFT)
+#define	BCM_DMA_SRC(n)		(0x100*(n) + 0x0C)
+#define	BCM_DMA_DST(n)		(0x100*(n) + 0x10)
+#define	BCM_DMA_LEN(n)		(0x100*(n) + 0x14)
+#define	BCM_DMA_STRIDE(n)	(0x100*(n) + 0x18)
+#define	BCM_DMA_CBNEXT(n)	(0x100*(n) + 0x1C)
+#define	BCM_DMA_DEBUG(n)	(0x100*(n) + 0x20)
+#define		DEBUG_ERROR_MASK	(7)
+#define	BCM_DMA_INT_STATUS	0xfe0
+#define	BCM_DMA_ENABLE		0xff0
+/* relative offset from BCM_VC_DMA0_BASE (p.39) */
+#define	BCM_DMA_CH(n)		(0x100*(n))
+/* channels used by GPU */
+#define	BCM_DMA_CH_BULK		0
+#define	BCM_DMA_CH_FAST1	2
+#define	BCM_DMA_CH_FAST2	3
+#define	BCM_DMA_CH_GPU_MASK	((1 << BCM_DMA_CH_BULK) |	\
+				 (1 << BCM_DMA_CH_FAST1) |	\
+				 (1 << BCM_DMA_CH_FAST2))
+/* DMA Control Block - 256bit aligned (p.40) */
+struct bcm_dma_cb {
+	uint32_t info;		/* Transfer Information */
+	uint32_t src;		/* Source Address */
+	uint32_t dst;		/* Destination Address */
+	uint32_t len;		/* Transfer Length */
+	uint32_t stride;	/* 2D Mode Stride */
+	uint32_t next;		/* Next Control Block Address */
+	uint32_t rsvd1;		/* Reserved */
+	uint32_t rsvd2;		/* Reserved */
+#ifdef DEBUG
+static void bcm_dma_cb_dump(struct bcm_dma_cb *cb);
+static void bcm_dma_reg_dump(int ch);
+#endif
+/* DMA channel private info */
+struct bcm_dma_ch {
+	int			ch;
+	uint32_t		flags;
+	struct bcm_dma_cb *	cb;
+	uint32_t		vc_cb;
+	bus_dmamap_t		dma_map;
+	void 			(*intr_func)(int, void *);
+	void *			intr_arg;
+struct bcm_dma_softc {
+	device_t		sc_dev;
+	struct mtx		sc_mtx;
+	struct resource *	sc_mem;
+	struct resource *	sc_irq[BCM_DMA_CH_MAX];
+	void *			sc_intrhand[BCM_DMA_CH_MAX];
+	struct bcm_dma_ch	sc_dma_ch[BCM_DMA_CH_MAX];
+	bus_dma_tag_t		sc_dma_tag;
+static struct bcm_dma_softc *bcm_dma_sc = NULL;
+static uint32_t bcm_dma_channel_mask;
+static void
+bcm_dmamap_cb(void *arg, bus_dma_segment_t *segs,
+	int nseg, int err)
+        bus_addr_t *addr;
+        if (err)
+                return;
+        addr = (bus_addr_t*)arg;
+        *addr = PHYS_TO_VCBUS(segs[0].ds_addr);
+static void
+bcm_dma_reset(device_t dev, int ch)
+	struct bcm_dma_softc *sc = device_get_softc(dev);
+	struct bcm_dma_cb *cb;
+	uint32_t cs;
+	int count;
+	if (ch < 0 || ch >= BCM_DMA_CH_MAX)
+		return;
+	cs = bus_read_4(sc->sc_mem, BCM_DMA_CS(ch));
+	if (cs & CS_ACTIVE) {
+		/* pause current task */
+		bus_write_4(sc->sc_mem, BCM_DMA_CS(ch), 0);
+		count = 1000;
+		do {
+		} while (!(cs & CS_ISPAUSED) && (count-- > 0));
+		if (!(cs & CS_ISPAUSED)) {
+			device_printf(dev,
+			    "Can't abort DMA transfer at channel %d\n", ch);
+		bus_write_4(sc->sc_mem, BCM_DMA_CBNEXT(ch), 0);
+		/* Complete everything, clear interrupt */
+		    CS_ABORT | CS_INT | CS_END| CS_ACTIVE);
+	/* clear control blocks */
+	bus_write_4(sc->sc_mem, BCM_DMA_CBADDR(ch), 0);
+	/* Reset control block */
+	cb = sc->sc_dma_ch[ch].cb;
+	bzero(cb, sizeof(*cb));
+	cb->info = INFO_WAIT_RESP;
+static int
+bcm_dma_init(device_t dev)
+	uint32_t reg;
+	struct bcm_dma_ch *ch;
+	void *cb_virt;
+	vm_paddr_t cb_phys;
+	int err;
+	int i;
+	 * Only channels set in bcm_dma_channel_mask can be controlled by us.
+	 * The others are out of our control as well as the corresponding bits
+	 * in both BCM_DMA_ENABLE and BCM_DMA_INT_STATUS global registers. As
+	 * these registers are RW ones, there is no safe way how to write only
+	 * the bits which can be controlled by us.
+	 * Fortunately, after reset, all channels are enabled in BCM_DMA_ENABLE
+	 * register and all statuses are cleared in BCM_DMA_INT_STATUS one.
+	 * Not touching these registers is a trade off between correct
+	 * initialization which does not count on anything and not messing up
+	 * something we have no control over.
+	reg = bus_read_4(sc->sc_mem, BCM_DMA_ENABLE);
+	if ((reg & bcm_dma_channel_mask) != bcm_dma_channel_mask)
+		device_printf(dev, "channels are not enabled\n");
+	reg = bus_read_4(sc->sc_mem, BCM_DMA_INT_STATUS);
+	if ((reg & bcm_dma_channel_mask) != 0)
+		device_printf(dev, "statuses are not cleared\n");
+	/* Allocate DMA chunks control blocks */
+	/* p.40 of spec - control block should be 32-bit aligned */
+	err = bus_dma_tag_create(bus_get_dma_tag(dev),
+	    1, 0, BUS_SPACE_MAXADDR_32BIT,
+	    BUS_SPACE_MAXADDR, NULL, NULL,
+	    sizeof(struct bcm_dma_cb), 1,
+	    BUS_DMA_ALLOCNOW, NULL, NULL,
+	    &sc->sc_dma_tag);
+	if (err) {
+		device_printf(dev, "failed allocate DMA tag\n");
+		return (err);
+	/* setup initial settings */
+	for (i = 0; i < BCM_DMA_CH_MAX; i++) {
+		ch = &sc->sc_dma_ch[i];
+		bzero(ch, sizeof(struct bcm_dma_ch));
+		ch->ch = i;
+		ch->flags = BCM_DMA_CH_UNMAP;
+		if ((bcm_dma_channel_mask & (1 << i)) == 0)
+			continue;
+		err = bus_dmamem_alloc(sc->sc_dma_tag, &cb_virt,
+		    BUS_DMA_WAITOK | BUS_DMA_COHERENT | BUS_DMA_ZERO,
+		    &ch->dma_map);
+		if (err) {
+			device_printf(dev, "cannot allocate DMA memory\n");
+			break;
+		 * Least alignment for busdma-allocated stuff is cache
+		 * line size, so just make sure nothing stupid happened
+		 * and we got properly aligned address
+		if ((uintptr_t)cb_virt & 0x1f) {
+			    "DMA address is not 32-bytes aligned: %p\n",
+			    (void*)cb_virt);
+			break;
+		err = bus_dmamap_load(sc->sc_dma_tag, ch->dma_map, cb_virt,
+		    sizeof(struct bcm_dma_cb), bcm_dmamap_cb, &cb_phys,
+		    BUS_DMA_WAITOK);
+		if (err) {
+			device_printf(dev, "cannot load DMA memory\n");
+			break;
+		ch->cb = cb_virt;
+		ch->vc_cb = cb_phys;
+		ch->flags = BCM_DMA_CH_FREE;
+		ch->cb->info = INFO_WAIT_RESP;
+		/* reset DMA engine */
+		bus_write_4(sc->sc_mem, BCM_DMA_CS(i), CS_RESET);
+	return (0);
+ * Allocate DMA channel for further use, returns channel # or
+ *     BCM_DMA_CH_INVALID
+int
+bcm_dma_allocate(int req_ch)
+	struct bcm_dma_softc *sc = bcm_dma_sc;
+	int ch = BCM_DMA_CH_INVALID;
+	int i;
+	if (req_ch >= BCM_DMA_CH_MAX)
+		return (BCM_DMA_CH_INVALID);
+	/* Auto(req_ch < 0) or CH specified */
+	mtx_lock(&sc->sc_mtx);
+	if (req_ch < 0) {
+			if (sc->sc_dma_ch[i].flags & BCM_DMA_CH_FREE) {
+				ch = i;
+				sc->sc_dma_ch[ch].flags &= ~BCM_DMA_CH_FREE;
+				sc->sc_dma_ch[ch].flags |= BCM_DMA_CH_USED;
+				break;
+	else {
+		if (sc->sc_dma_ch[req_ch].flags & BCM_DMA_CH_FREE) {
+			ch = req_ch;
+	mtx_unlock(&sc->sc_mtx);
+	return (ch);
+ * Frees allocated channel. Returns 0 on success, -1 otherwise
+int
+bcm_dma_free(int ch)
+		return (-1);
+	if (sc->sc_dma_ch[ch].flags & BCM_DMA_CH_USED) {
+		sc->sc_dma_ch[ch].flags |= BCM_DMA_CH_FREE;
+		sc->sc_dma_ch[ch].flags &= ~BCM_DMA_CH_USED;
+		sc->sc_dma_ch[ch].intr_func = NULL;
+		sc->sc_dma_ch[ch].intr_arg = NULL;
+		bcm_dma_reset(sc->sc_dev, ch);
+	return (0);
+ * Assign handler function for channel interrupt
+ * Returns 0 on success, -1 otherwise
+int
+bcm_dma_setup_intr(int ch, void (*func)(int, void *), void *arg)
+		return (-1);
+	if (!(sc->sc_dma_ch[ch].flags & BCM_DMA_CH_USED))
+		return (-1);
+	sc->sc_dma_ch[ch].intr_func = func;
+	sc->sc_dma_ch[ch].intr_arg = arg;
+	cb->info |= INFO_INT_EN;
+	return (0);
+ * Setup DMA source parameters
+ *     ch - channel number
+ *     dreq - hardware DREQ # or BCM_DMA_DREQ_NONE if
+ *         source is physical memory
+ *     inc_addr - BCM_DMA_INC_ADDR if source address
+ *         should be increased after each access or
+ *         BCM_DMA_SAME_ADDR if address should remain
+ *         the same
+ *     width - size of read operation, BCM_DMA_32BIT
+ *         for 32bit bursts, BCM_DMA_128BIT for 128 bits
+int
+bcm_dma_setup_src(int ch, int dreq, int inc_addr, int width)
+	uint32_t info;
+		return (-1);
+		return (-1);
+	info = sc->sc_dma_ch[ch].cb->info;
+	info &= ~INFO_PERMAP_MASK;
+	info |= (dreq << INFO_PERMAP_SHIFT) & INFO_PERMAP_MASK;
+	if (dreq)
+		info |= INFO_S_DREQ;
+	else
+		info &= ~INFO_S_DREQ;
+	if (width == BCM_DMA_128BIT)
+		info |= INFO_S_WIDTH;
+	else
+		info &= ~INFO_S_WIDTH;
+	if (inc_addr == BCM_DMA_INC_ADDR)
+		info |= INFO_S_INC;
+	else
+		info &= ~INFO_S_INC;
+	sc->sc_dma_ch[ch].cb->info = info;
+	return (0);
+ * Setup DMA destination parameters
+ *         destination is physical memory
+ *         the same
+ *     width - size of write operation, BCM_DMA_32BIT
+int
+bcm_dma_setup_dst(int ch, int dreq, int inc_addr, int width)
+	uint32_t info;
+		return (-1);
+		return (-1);
+	if (dreq)
+		info |= INFO_D_DREQ;
+	else
+		info &= ~INFO_D_DREQ;
+		info |= INFO_D_WIDTH;
+	else
+		info &= ~INFO_D_WIDTH;
+		info |= INFO_D_INC;
+	else
+		info &= ~INFO_D_INC;
+	return (0);
+#ifdef DEBUG
+void
+bcm_dma_cb_dump(struct bcm_dma_cb *cb)
+	printf("DMA CB ");
+	printf("INFO: %8.8x ", cb->info);
+	printf("SRC: %8.8x ", cb->src);
+	printf("DST: %8.8x ", cb->dst);
+	printf("LEN: %8.8x ", cb->len);
+	printf("\n");
+	printf("STRIDE: %8.8x ", cb->stride);
+	printf("NEXT: %8.8x ", cb->next);
+	printf("RSVD1: %8.8x ", cb->rsvd1);
+	printf("RSVD2: %8.8x ", cb->rsvd2);
+	printf("\n");
+void
+bcm_dma_reg_dump(int ch)
+	int i;
+	uint32_t reg;
+		return;
+	printf("DMA%d: ", ch);
+	for (i = 0; i < MAX_REG; i++) {
+		reg = bus_read_4(sc->sc_mem, BCM_DMA_CH(ch) + i*4);
+		printf("%8.8x ", reg);
+	printf("\n");
+#endif
+ * Start DMA transaction
+ *     src, dst - source and destination address in
+ *         ARM physical memory address space.
+ *     len - amount of bytes to be transferred
+int
+bcm_dma_start(int ch, vm_paddr_t src, vm_paddr_t dst, int len)
+		return (-1);
+		return (-1);
+	if (BCM2835_ARM_IS_IO(src))
+		cb->src = IO_TO_VCBUS(src);
+	else
+		cb->src = PHYS_TO_VCBUS(src);
+	if (BCM2835_ARM_IS_IO(dst))
+		cb->dst = IO_TO_VCBUS(dst);
+	else
+		cb->dst = PHYS_TO_VCBUS(dst);
+	cb->len = len;
+	bus_dmamap_sync(sc->sc_dma_tag,
+	    sc->sc_dma_ch[ch].dma_map, BUS_DMASYNC_PREWRITE);
+	    sc->sc_dma_ch[ch].vc_cb);
+	bus_write_4(sc->sc_mem, BCM_DMA_CS(ch), CS_ACTIVE);
+#ifdef DEBUG
+	bcm_dma_cb_dump(sc->sc_dma_ch[ch].cb);
+	bcm_dma_reg_dump(ch);
+#endif
+	return (0);
+ * Get length requested for DMA transaction
+ * Returns size of transaction, 0 if channel is invalid
+uint32_t
+bcm_dma_length(int ch)
+		return (0);
+		return (0);
+	return (cb->len);
+static void
+bcm_dma_intr(void *arg)
+	struct bcm_dma_ch *ch = (struct bcm_dma_ch *)arg;
+	uint32_t cs, debug;
+	/* my interrupt? */
+	cs = bus_read_4(sc->sc_mem, BCM_DMA_CS(ch->ch));
+	if (!(cs & (CS_INT | CS_ERR))) {
+		device_printf(sc->sc_dev,
+		    "unexpected DMA intr CH=%d, CS=%x\n", ch->ch, cs);
+		return;
+	/* running? */
+	if (!(ch->flags & BCM_DMA_CH_USED)) {
+		    "unused DMA intr CH=%d, CS=%x\n", ch->ch, cs);
+		return;
+	if (cs & CS_ERR) {
+		debug = bus_read_4(sc->sc_mem, BCM_DMA_DEBUG(ch->ch));
+		device_printf(sc->sc_dev, "DMA error %d on CH%d\n",
+			debug & DEBUG_ERROR_MASK, ch->ch);
+		bus_write_4(sc->sc_mem, BCM_DMA_DEBUG(ch->ch),
+		    debug & DEBUG_ERROR_MASK);
+		bcm_dma_reset(sc->sc_dev, ch->ch);
+	if (cs & CS_INT) {
+		/* acknowledge interrupt */
+		bus_write_4(sc->sc_mem, BCM_DMA_CS(ch->ch),
+		    CS_INT | CS_END);
+		/* Prepare for possible access to len field */
+		bus_dmamap_sync(sc->sc_dma_tag, ch->dma_map,
+		    BUS_DMASYNC_POSTWRITE);
+		/* save callback function and argument */
+		if (ch->intr_func)
+			ch->intr_func(ch->ch, ch->intr_arg);
+static int
+bcm_dma_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-dma"))
+		return (ENXIO);
+	device_set_desc(dev, "BCM2835 DMA Controller");
+	return (BUS_PROBE_DEFAULT);
+static int
+bcm_dma_attach(device_t dev)
+	phandle_t node;
+	int rid, err = 0;
+	int i;
+	sc->sc_dev = dev;
+	if (bcm_dma_sc)
+		return (ENXIO);
+		sc->sc_irq[i] = NULL;
+		sc->sc_intrhand[i] = NULL;
+	/* Get DMA channel mask. */
+	node = ofw_bus_get_node(sc->sc_dev);
+	if (OF_getencprop(node, "brcm,dma-channel-mask", &bcm_dma_channel_mask,
+	    sizeof(bcm_dma_channel_mask)) == -1 &&
+	    OF_getencprop(node, "broadcom,channels", &bcm_dma_channel_mask,
+	    sizeof(bcm_dma_channel_mask)) == -1) {
+		device_printf(dev, "could not get channel mask property\n");
+		return (ENXIO);
+	/* Mask out channels used by GPU. */
+	bcm_dma_channel_mask &= ~BCM_DMA_CH_GPU_MASK;
+	/* DMA0 - DMA14 */
+	rid = 0;
+	sc->sc_mem = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid, RF_ACTIVE);
+	if (sc->sc_mem == NULL) {
+		device_printf(dev, "could not allocate memory resource\n");
+		return (ENXIO);
+	/* IRQ DMA0 - DMA11 XXX NOT USE DMA12(spurious?) */
+	for (rid = 0; rid < BCM_DMA_CH_MAX; rid++) {
+		if ((bcm_dma_channel_mask & (1 << rid)) == 0)
+			continue;
+		sc->sc_irq[rid] = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
+						       RF_ACTIVE);
+		if (sc->sc_irq[rid] == NULL) {
+			device_printf(dev, "cannot allocate interrupt\n");
+			err = ENXIO;
+			goto fail;
+		if (bus_setup_intr(dev, sc->sc_irq[rid], INTR_TYPE_MISC | INTR_MPSAFE,
+				   NULL, bcm_dma_intr, &sc->sc_dma_ch[rid],
+				   &sc->sc_intrhand[rid])) {
+			device_printf(dev, "cannot setup interrupt handler\n");
+			err = ENXIO;
+			goto fail;
+	mtx_init(&sc->sc_mtx, "bcmdma", "bcmdma", MTX_DEF);
+	bcm_dma_sc = sc;
+	err = bcm_dma_init(dev);
+	if (err)
+		goto fail;
+	return (err);
+fail:
+	if (sc->sc_mem)
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->sc_mem);
+		if (sc->sc_intrhand[i])
+			bus_teardown_intr(dev, sc->sc_irq[i], sc->sc_intrhand[i]);
+		if (sc->sc_irq[i])
+			bus_release_resource(dev, SYS_RES_IRQ, 0, sc->sc_irq[i]);
+	return (err);
+static device_method_t bcm_dma_methods[] = {
+	DEVMETHOD(device_probe,		bcm_dma_probe),
+	DEVMETHOD(device_attach,	bcm_dma_attach),
+	{ 0, 0 }
+static driver_t bcm_dma_driver = {
+	"bcm_dma",
+	bcm_dma_methods,
+	sizeof(struct bcm_dma_softc),
+static devclass_t bcm_dma_devclass;
+DRIVER_MODULE(bcm_dma, simplebus, bcm_dma_driver, bcm_dma_devclass, 0, 0);
+MODULE_VERSION(bcm_dma, 1);
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h
index 0000000..c39344a
--- /dev/null
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h
@@ -0,0 +1,60 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_BCM2835_DMA_H_
+#define	_BCM2835_DMA_H_
+#define	BCM_DMA_BLOCK_SIZE	512
+/* DMA0-DMA15 but DMA15 is special */
+#define	BCM_DMA_CH_MAX		12
+/* request CH for any nubmer */
+#define	BCM_DMA_CH_INVALID	(-1)
+#define	BCM_DMA_CH_ANY		(-1)
+/* Peripheral DREQ Signals (4.2.1.3) */
+#define	BCM_DMA_DREQ_NONE	0
+#define	BCM_DMA_DREQ_EMMC	11
+#define	BCM_DMA_DREQ_SDHOST	13
+#define	BCM_DMA_SAME_ADDR	0
+#define	BCM_DMA_INC_ADDR	1
+#define	BCM_DMA_32BIT		0
+#define	BCM_DMA_128BIT		1
+int bcm_dma_allocate(int req_ch);
+int bcm_dma_free(int ch);
+int bcm_dma_setup_intr(int ch, void (*func)(int, void *), void *arg);
+int bcm_dma_setup_src(int ch, int dreq, int inc_addr, int width);
+int bcm_dma_setup_dst(int ch, int dreq, int inc_addr, int width);
+int bcm_dma_start(int ch, vm_paddr_t src, vm_paddr_t dst, int len);
+uint32_t bcm_dma_length(int ch);
+#endif	/* _BCM2835_DMA_H_ */
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h
index 0000000..e1d44b3
--- /dev/null
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h
@@ -0,0 +1,72 @@
+ * Copyright (c) 2012 Oleksandr Tymoshenko <gonzo at freebsd.org>
+ * All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+ * Defines for converting physical address to VideoCore bus address and back
+#ifndef _BCM2835_VCBUS_H_
+#define _BCM2835_VCBUS_H_
+#define	BCM2835_VCBUS_SDRAM_CACHED	0x40000000
+#define	BCM2835_VCBUS_IO_BASE		0x7E000000
+#define	BCM2835_VCBUS_SDRAM_UNCACHED	0xC0000000
+#ifdef SOC_BCM2836
+#define	BCM2835_ARM_IO_BASE		0x3f000000
+#define	BCM2835_VCBUS_SDRAM_BASE	BCM2835_VCBUS_SDRAM_UNCACHED
+#else
+#define	BCM2835_ARM_IO_BASE		0x20000000
+#define	BCM2835_VCBUS_SDRAM_BASE	BCM2835_VCBUS_SDRAM_CACHED
+#endif
+#define	BCM2835_ARM_IO_SIZE		0x01000000
+ * Convert physical address to VC bus address. Should be used
+ * when submitting address over mailbox interface
+#define	PHYS_TO_VCBUS(pa)	((pa) + BCM2835_VCBUS_SDRAM_BASE)
+/* Check whether pa bellong top IO window */
+#define BCM2835_ARM_IS_IO(pa)	(((pa) >= BCM2835_ARM_IO_BASE) && \
+    ((pa) < BCM2835_ARM_IO_BASE + BCM2835_ARM_IO_SIZE))
+ * Convert physical address in IO space to VC bus address.
+#define	IO_TO_VCBUS(pa)		((pa - BCM2835_ARM_IO_BASE) + \
+    BCM2835_VCBUS_IO_BASE)
+ * Convert address from VC bus space to physical. Should be used
+ * when address is returned by VC over mailbox interface. e.g.
+ * framebuffer base
+#define	VCBUS_TO_PHYS(vca)	((vca) & ~(BCM2835_VCBUS_SDRAM_BASE))
+#endif /* _BCM2835_VCBUS_H_ */
diff --git a/libbsd.py b/libbsd.py
index d2659c4..9d9e692 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -359,12 +359,25 @@ def mmc(mm):
             'sys/dev/sdhci/sdhci.h',
+    mod.addCPUDependentHeaderFiles(
+            'sys/arm/broadcom/bcm2835/bcm2835_dma.h',
+            'sys/arm/broadcom/bcm2835/bcm2835_vcbus.h',
     mod.addKernelSpaceSourceFiles(
             'sys/dev/mmc/mmc.c',
             'sys/dev/mmc/mmcsd.c',
             'sys/dev/sdhci/sdhci.c',
+    mm.generator['source']()
+    mod.addCPUDependentSourceFiles(
+        [ 'arm' ],
+            'sys/arm/broadcom/bcm2835/bcm2835_dma.c',
     return mod
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 918437f..b9b1181 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -1113,7 +1113,8 @@ def build(bld):
               'rtemsbsd/telnetd/pty.c',
               'rtemsbsd/telnetd/telnetd.c']
     if bld.get_env()["RTEMS_ARCH"] == "arm":
-        source += ['freebsd/sys/mips/mips/in_cksum.c']
+        source += ['freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c',
+                   'freebsd/sys/mips/mips/in_cksum.c']
     if bld.get_env()["RTEMS_ARCH"] == "avr":
     if bld.get_env()["RTEMS_ARCH"] == "bfin":
1.9.1
