[PATCH 1/5] SD Card : Initial Port of DMA Controller
Mon Aug 22 06:02:26 UTC 2016
Please add the import versions of the files to libbsd.txt if they differ
from the default FreeBSD version.
On 22/08/16 05:57, Mudit Jain wrote:
> This is the initial port of the DMA controller
> from the libbsd using freebsd-to-rtems.py
> This change is dependent on the interrupt handler
> in the Mainline.
>   freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c   | 768 +++++++++++++++++++++++
>   freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h   |  60 ++
>   freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h |  72 +++
>   libbsd.py                                        |  13 +
>   libbsd_waf.py                                    |   3 +-
>   5 files changed, 915 insertions(+), 1 deletion(-)
>   create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
>   create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.h
>   create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_vcbus.h
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
