[PATCH 1/5] SD Card : Initial Port of DMA Controller
Tue Aug 23 13:24:53 UTC 2016
Hello,
I updated the MMC stack to use the FreeBSD trunk, 2016-08-23,
9fe7c416e6abb28b1398fd3e5687099846800cfd.
https://git.rtems.org/rtems-libbsd/commit/?id=0c24e06130bd034474a33a191c6da095f4f59a5e
Please use exactly this version for your stuff as well.
For the SDHCI support, please try the following.
1. Delete the existing SDHCI support with one commit.
2. Do a fresh import of the SDHCI support.
3. Do the port to RTEMS.
On 22/08/16 05:57, Mudit Jain wrote:
> This is the initial port of the DMA controller
> from the libbsd using freebsd-to-rtems.py
> This change is dependent on the interrupt handler
> in the Mainline.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
