[PATCH 4/7] SD Card : Clean addition of Kernel Source Files
Mudit Jain muditjain18011995 at gmail.com
Sun Aug 28 07:25:09 UTC 2016
 freebsd/sys/dev/sdhci/sdhci.c | 1510 +++++++++++++++++++++++++++++++++++++++++
 freebsd/sys/dev/sdhci/sdhci.h |  326 +++++++++
 libbsd.txt                    |    1 +
 3 files changed, 1837 insertions(+)
 create mode 100644 freebsd/sys/dev/sdhci/sdhci.c
 create mode 100644 freebsd/sys/dev/sdhci/sdhci.h
diff --git a/freebsd/sys/dev/sdhci/sdhci.c b/freebsd/sys/dev/sdhci/sdhci.c
new file mode 100644
index 0000000..6ba9777
--- /dev/null
+++ b/freebsd/sys/dev/sdhci/sdhci.c
@@ -0,0 +1,1510 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2008 Alexander Motin <mav at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/callout.h>
+#include <sys/conf.h>
+#include <sys/kernel.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/rman.h>
+#include <sys/sysctl.h>
+#include <sys/taskqueue.h>
+#include <machine/bus.h>
+#include <machine/resource.h>
+#include <machine/stdarg.h>
+#include <dev/mmc/bridge.h>
+#include <dev/mmc/mmcreg.h>
+#include <dev/mmc/mmcbrvar.h>
+#include <rtems/bsd/local/mmcbr_if.h>
+#include "sdhci.h"
+#include <rtems/bsd/local/sdhci_if.h>
+SYSCTL_NODE(_hw, OID_AUTO, sdhci, CTLFLAG_RD, 0, "sdhci driver");
+static int sdhci_debug;
+SYSCTL_INT(_hw_sdhci, OID_AUTO, debug, CTLFLAG_RWTUN, &sdhci_debug, 0, "Debug level");
+#define RD1(slot, off)	SDHCI_READ_1((slot)->bus, (slot), (off))
+#define RD2(slot, off)	SDHCI_READ_2((slot)->bus, (slot), (off))
+#define RD4(slot, off)	SDHCI_READ_4((slot)->bus, (slot), (off))
+#define RD_MULTI_4(slot, off, ptr, count)	\
+    SDHCI_READ_MULTI_4((slot)->bus, (slot), (off), (ptr), (count))
+#define WR1(slot, off, val)	SDHCI_WRITE_1((slot)->bus, (slot), (off), (val))
+#define WR2(slot, off, val)	SDHCI_WRITE_2((slot)->bus, (slot), (off), (val))
+#define WR4(slot, off, val)	SDHCI_WRITE_4((slot)->bus, (slot), (off), (val))
+#define WR_MULTI_4(slot, off, ptr, count)	\
+    SDHCI_WRITE_MULTI_4((slot)->bus, (slot), (off), (ptr), (count))
+static void sdhci_set_clock(struct sdhci_slot *slot, uint32_t clock);
+static void sdhci_start(struct sdhci_slot *slot);
+static void sdhci_start_data(struct sdhci_slot *slot, struct mmc_data *data);
+static void sdhci_card_task(void *, int);
+/* helper routines */
+#define SDHCI_LOCK(_slot)		mtx_lock(&(_slot)->mtx)
+#define	SDHCI_UNLOCK(_slot)		mtx_unlock(&(_slot)->mtx)
+#define SDHCI_LOCK_INIT(_slot) \
+	mtx_init(&_slot->mtx, "SD slot mtx", "sdhci", MTX_DEF)
+#define SDHCI_LOCK_DESTROY(_slot)	mtx_destroy(&_slot->mtx);
+#define SDHCI_ASSERT_LOCKED(_slot)	mtx_assert(&_slot->mtx, MA_OWNED);
+#define SDHCI_ASSERT_UNLOCKED(_slot)	mtx_assert(&_slot->mtx, MA_NOTOWNED);
+#define	SDHCI_DEFAULT_MAX_FREQ	50
+#define	SDHCI_200_MAX_DIVIDER	256
+#define	SDHCI_300_MAX_DIVIDER	2046
+ * Broadcom BCM577xx Controller Constants
+#define BCM577XX_DEFAULT_MAX_DIVIDER	256		/* Maximum divider supported by the default clock source. */
+#define BCM577XX_ALT_CLOCK_BASE		63000000	/* Alternative clock's base frequency. */
+#define BCM577XX_HOST_CONTROL		0x198
+#define BCM577XX_CTRL_CLKSEL_MASK	0xFFFFCFFF
+#define BCM577XX_CTRL_CLKSEL_SHIFT	12
+#define BCM577XX_CTRL_CLKSEL_DEFAULT	0x0
+#define BCM577XX_CTRL_CLKSEL_64MHZ	0x3
+static void
+sdhci_getaddr(void *arg, bus_dma_segment_t *segs, int nsegs, int error)
+	if (error != 0) {
+		printf("getaddr: error %d\n", error);
+		return;
+	*(bus_addr_t *)arg = segs[0].ds_addr;
+static int
+slot_printf(struct sdhci_slot *slot, const char * fmt, ...)
+	va_list ap;
+	int retval;
+    	retval = printf("%s-slot%d: ",
+	    device_get_nameunit(slot->bus), slot->num);
+	va_start(ap, fmt);
+	retval += vprintf(fmt, ap);
+	va_end(ap);
+	return (retval);
+static void
+sdhci_dumpregs(struct sdhci_slot *slot)
+	slot_printf(slot,
+	    "============== REGISTER DUMP ==============\n");
+	slot_printf(slot, "Sys addr: 0x%08x | Version:  0x%08x\n",
+	    RD4(slot, SDHCI_DMA_ADDRESS), RD2(slot, SDHCI_HOST_VERSION));
+	slot_printf(slot, "Blk size: 0x%08x | Blk cnt:  0x%08x\n",
+	    RD2(slot, SDHCI_BLOCK_SIZE), RD2(slot, SDHCI_BLOCK_COUNT));
+	slot_printf(slot, "Argument: 0x%08x | Trn mode: 0x%08x\n",
+	    RD4(slot, SDHCI_ARGUMENT), RD2(slot, SDHCI_TRANSFER_MODE));
+	slot_printf(slot, "Present:  0x%08x | Host ctl: 0x%08x\n",
+	    RD4(slot, SDHCI_PRESENT_STATE), RD1(slot, SDHCI_HOST_CONTROL));
+	slot_printf(slot, "Power:    0x%08x | Blk gap:  0x%08x\n",
+	    RD1(slot, SDHCI_POWER_CONTROL), RD1(slot, SDHCI_BLOCK_GAP_CONTROL));
+	slot_printf(slot, "Wake-up:  0x%08x | Clock:    0x%08x\n",
+	    RD1(slot, SDHCI_WAKE_UP_CONTROL), RD2(slot, SDHCI_CLOCK_CONTROL));
+	slot_printf(slot, "Timeout:  0x%08x | Int stat: 0x%08x\n",
+	    RD1(slot, SDHCI_TIMEOUT_CONTROL), RD4(slot, SDHCI_INT_STATUS));
+	slot_printf(slot, "Int enab: 0x%08x | Sig enab: 0x%08x\n",
+	    RD4(slot, SDHCI_INT_ENABLE), RD4(slot, SDHCI_SIGNAL_ENABLE));
+	slot_printf(slot, "AC12 err: 0x%08x | Slot int: 0x%08x\n",
+	    RD2(slot, SDHCI_ACMD12_ERR), RD2(slot, SDHCI_SLOT_INT_STATUS));
+	slot_printf(slot, "Caps:     0x%08x | Max curr: 0x%08x\n",
+	    RD4(slot, SDHCI_CAPABILITIES), RD4(slot, SDHCI_MAX_CURRENT));
+	slot_printf(slot,
+	    "===========================================\n");
+static void
+sdhci_reset(struct sdhci_slot *slot, uint8_t mask)
+	int timeout;
+	if (slot->quirks & SDHCI_QUIRK_NO_CARD_NO_RESET) {
+		if (!(RD4(slot, SDHCI_PRESENT_STATE) &
+			SDHCI_CARD_PRESENT))
+			return;
+	/* Some controllers need this kick or reset won't work. */
+	if ((mask & SDHCI_RESET_ALL) == 0 &&
+	    (slot->quirks & SDHCI_QUIRK_CLOCK_BEFORE_RESET)) {
+		uint32_t clock;
+		/* This is to force an update */
+		clock = slot->clock;
+		slot->clock = 0;
+		sdhci_set_clock(slot, clock);
+	if (mask & SDHCI_RESET_ALL) {
+		slot->clock = 0;
+		slot->power = 0;
+	WR1(slot, SDHCI_SOFTWARE_RESET, mask);
+	if (slot->quirks & SDHCI_QUIRK_WAITFOR_RESET_ASSERTED) {
+		 * Resets on TI OMAPs and AM335x are incompatible with SDHCI
+		 * specification.  The reset bit has internal propagation delay,
+		 * so a fast read after write returns 0 even if reset process is
+		 * in progress. The workaround is to poll for 1 before polling
+		 * for 0.  In the worst case, if we miss seeing it asserted the
+		 * time we spent waiting is enough to ensure the reset finishes.
+		timeout = 10000;
+		while ((RD1(slot, SDHCI_SOFTWARE_RESET) & mask) != mask) {
+			if (timeout <= 0)
+				break;
+			timeout--;
+			DELAY(1);
+	/* Wait max 100 ms */
+	timeout = 10000;
+	/* Controller clears the bits when it's done */
+	while (RD1(slot, SDHCI_SOFTWARE_RESET) & mask) {
+		if (timeout <= 0) {
+			slot_printf(slot, "Reset 0x%x never completed.\n",
+			    mask);
+			sdhci_dumpregs(slot);
+			return;
+		timeout--;
+		DELAY(10);
+static void
+sdhci_init(struct sdhci_slot *slot)
+	sdhci_reset(slot, SDHCI_RESET_ALL);
+	/* Enable interrupts. */
+	slot->intmask = SDHCI_INT_BUS_POWER | SDHCI_INT_DATA_END_BIT |
+	    SDHCI_INT_DATA_CRC | SDHCI_INT_DATA_TIMEOUT | SDHCI_INT_INDEX |
+	    SDHCI_INT_END_BIT | SDHCI_INT_CRC | SDHCI_INT_TIMEOUT |
+	    SDHCI_INT_CARD_REMOVE | SDHCI_INT_CARD_INSERT |
+	    SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL |
+	    SDHCI_INT_DMA_END | SDHCI_INT_DATA_END | SDHCI_INT_RESPONSE |
+	    SDHCI_INT_ACMD12ERR;
+	WR4(slot, SDHCI_INT_ENABLE, slot->intmask);
+	WR4(slot, SDHCI_SIGNAL_ENABLE, slot->intmask);
+static void
+sdhci_set_clock(struct sdhci_slot *slot, uint32_t clock)
+	uint32_t clk_base;
+	uint32_t clk_sel;
+	uint32_t res;
+	uint16_t clk;
+	uint16_t div;
+	int timeout;
+	if (clock == slot->clock)
+		return;
+	slot->clock = clock;
+	/* Turn off the clock. */
+	clk = RD2(slot, SDHCI_CLOCK_CONTROL);
+	WR2(slot, SDHCI_CLOCK_CONTROL, clk & ~SDHCI_CLOCK_CARD_EN);
+	/* If no clock requested - left it so. */
+	if (clock == 0)
+		return;
+	/* Determine the clock base frequency */
+	clk_base = slot->max_clk;
+	if (slot->quirks & SDHCI_QUIRK_BCM577XX_400KHZ_CLKSRC) {
+		clk_sel = RD2(slot, BCM577XX_HOST_CONTROL) & BCM577XX_CTRL_CLKSEL_MASK;
+		/* Select clock source appropriate for the requested frequency. */
+		if ((clk_base / BCM577XX_DEFAULT_MAX_DIVIDER) > clock) {
+			clk_base = BCM577XX_ALT_CLOCK_BASE;
+			clk_sel |= (BCM577XX_CTRL_CLKSEL_64MHZ << BCM577XX_CTRL_CLKSEL_SHIFT);
+		} else {
+			clk_sel |= (BCM577XX_CTRL_CLKSEL_DEFAULT << BCM577XX_CTRL_CLKSEL_SHIFT);
+		WR2(slot, BCM577XX_HOST_CONTROL, clk_sel);
+	/* Recalculate timeout clock frequency based on the new sd clock. */
+	if (slot->quirks & SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK)
+		slot->timeout_clk = slot->clock / 1000;
+	if (slot->version < SDHCI_SPEC_300) {
+		/* Looking for highest freq <= clock. */
+		res = clk_base;
+		for (div = 1; div < SDHCI_200_MAX_DIVIDER; div <<= 1) {
+			if (res <= clock)
+				break;
+			res >>= 1;
+		/* Divider 1:1 is 0x00, 2:1 is 0x01, 256:1 is 0x80 ... */
+		div >>= 1;
+	else {
+		/* Version 3.0 divisors are multiples of two up to 1023*2 */
+		if (clock >= clk_base)
+			div = 0;
+		else {
+			for (div = 2; div < SDHCI_300_MAX_DIVIDER; div += 2) {
+				if ((clk_base / div) <= clock)
+					break;
+		div >>= 1;
+	if (bootverbose || sdhci_debug)
+		slot_printf(slot, "Divider %d for freq %d (base %d)\n",
+			div, clock, clk_base);
+	/* Now we have got divider, set it. */
+	clk = (div & SDHCI_DIVIDER_MASK) << SDHCI_DIVIDER_SHIFT;
+	clk |= ((div >> SDHCI_DIVIDER_MASK_LEN) & SDHCI_DIVIDER_HI_MASK)
+		<< SDHCI_DIVIDER_HI_SHIFT;
+	WR2(slot, SDHCI_CLOCK_CONTROL, clk);
+	/* Enable clock. */
+	clk |= SDHCI_CLOCK_INT_EN;
+	/* Wait up to 10 ms until it stabilize. */
+	timeout = 10;
+	while (!((clk = RD2(slot, SDHCI_CLOCK_CONTROL))
+		& SDHCI_CLOCK_INT_STABLE)) {
+		if (timeout == 0) {
+			slot_printf(slot,
+			    "Internal clock never stabilised.\n");
+			return;
+		timeout--;
+		DELAY(1000);
+	/* Pass clock signal to the bus. */
+	clk |= SDHCI_CLOCK_CARD_EN;
+static void
+sdhci_set_power(struct sdhci_slot *slot, u_char power)
+	uint8_t pwr;
+	if (slot->power == power)
+		return;
+	slot->power = power;
+	/* Turn off the power. */
+	pwr = 0;
+	WR1(slot, SDHCI_POWER_CONTROL, pwr);
+	/* If power down requested - left it so. */
+	if (power == 0)
+		return;
+	/* Set voltage. */
+	switch (1 << power) {
+	case MMC_OCR_LOW_VOLTAGE:
+		pwr |= SDHCI_POWER_180;
+		break;
+	case MMC_OCR_290_300:
+	case MMC_OCR_300_310:
+		pwr |= SDHCI_POWER_300;
+		break;
+	case MMC_OCR_320_330:
+	case MMC_OCR_330_340:
+		pwr |= SDHCI_POWER_330;
+		break;
+	/* Turn on the power. */
+	pwr |= SDHCI_POWER_ON;
+static void
+sdhci_read_block_pio(struct sdhci_slot *slot)
+	uint32_t data;
+	char *buffer;
+	size_t left;
+	buffer = slot->curcmd->data->data;
+	buffer += slot->offset;
+	/* Transfer one block at a time. */
+	left = min(512, slot->curcmd->data->len - slot->offset);
+	slot->offset += left;
+	/* If we are too fast, broken controllers return zeroes. */
+	if (slot->quirks & SDHCI_QUIRK_BROKEN_TIMINGS)
+		DELAY(10);
+	/* Handle unaligned and aligned buffer cases. */
+	if ((intptr_t)buffer & 3) {
+		while (left > 3) {
+			data = RD4(slot, SDHCI_BUFFER);
+			buffer[0] = data;
+			buffer[1] = (data >> 8);
+			buffer[2] = (data >> 16);
+			buffer[3] = (data >> 24);
+			buffer += 4;
+			left -= 4;
+	} else {
+		RD_MULTI_4(slot, SDHCI_BUFFER,
+		    (uint32_t *)buffer, left >> 2);
+		left &= 3;
+	/* Handle uneven size case. */
+	if (left > 0) {
+		while (left > 0) {
+			*(buffer++) = data;
+			data >>= 8;
+			left--;
+static void
+sdhci_write_block_pio(struct sdhci_slot *slot)
+	uint32_t data = 0;
+	char *buffer;
+	size_t left;
+			data = buffer[0] +
+			    (buffer[1] << 8) +
+			    (buffer[2] << 16) +
+			    (buffer[3] << 24);
+			left -= 4;
+			buffer += 4;
+			WR4(slot, SDHCI_BUFFER, data);
+	} else {
+		WR_MULTI_4(slot, SDHCI_BUFFER,
+		left &= 3;
+	if (left > 0) {
+			data <<= 8;
+			data += *(buffer++);
+			left--;
+static void
+sdhci_transfer_pio(struct sdhci_slot *slot)
+	/* Read as many blocks as possible. */
+	if (slot->curcmd->data->flags & MMC_DATA_READ) {
+		while (RD4(slot, SDHCI_PRESENT_STATE) &
+		    SDHCI_DATA_AVAILABLE) {
+			sdhci_read_block_pio(slot);
+			if (slot->offset >= slot->curcmd->data->len)
+				break;
+	} else {
+		    SDHCI_SPACE_AVAILABLE) {
+			sdhci_write_block_pio(slot);
+				break;
+static void
+sdhci_card_delay(void *arg)
+	struct sdhci_slot *slot = arg;
+	taskqueue_enqueue(taskqueue_swi_giant, &slot->card_task);
+static void
+sdhci_card_task(void *arg, int pending)
+	SDHCI_LOCK(slot);
+	if (RD4(slot, SDHCI_PRESENT_STATE) & SDHCI_CARD_PRESENT) {
+		if (slot->dev == NULL) {
+			/* If card is present - attach mmc bus. */
+			slot->dev = device_add_child(slot->bus, "mmc", -1);
+			device_set_ivars(slot->dev, slot);
+			SDHCI_UNLOCK(slot);
+			device_probe_and_attach(slot->dev);
+		} else
+	} else {
+		if (slot->dev != NULL) {
+			/* If no card present - detach mmc bus. */
+			device_t d = slot->dev;
+			slot->dev = NULL;
+			device_delete_child(slot->bus, d);
+		} else
+int
+sdhci_init_slot(device_t dev, struct sdhci_slot *slot, int num)
+	uint32_t caps, freq;
+	int err;
+	SDHCI_LOCK_INIT(slot);
+	slot->num = num;
+	slot->bus = dev;
+	/* Allocate DMA tag. */
+	err = bus_dma_tag_create(bus_get_dma_tag(dev),
+	    DMA_BLOCK_SIZE, 0, BUS_SPACE_MAXADDR_32BIT,
+	    BUS_SPACE_MAXADDR, NULL, NULL,
+	    DMA_BLOCK_SIZE, 1, DMA_BLOCK_SIZE,
+	    BUS_DMA_ALLOCNOW, NULL, NULL,
+	    &slot->dmatag);
+	if (err != 0) {
+		device_printf(dev, "Can't create DMA tag\n");
+		SDHCI_LOCK_DESTROY(slot);
+		return (err);
+	/* Allocate DMA memory. */
+	err = bus_dmamem_alloc(slot->dmatag, (void **)&slot->dmamem,
+	    BUS_DMA_NOWAIT, &slot->dmamap);
+	if (err != 0) {
+		device_printf(dev, "Can't alloc DMA memory\n");
+		return (err);
+	/* Map the memory. */
+	err = bus_dmamap_load(slot->dmatag, slot->dmamap,
+	    (void *)slot->dmamem, DMA_BLOCK_SIZE,
+	    sdhci_getaddr, &slot->paddr, 0);
+	if (err != 0 || slot->paddr == 0) {
+		device_printf(dev, "Can't load DMA memory\n");
+		if(err)
+			return (err);
+		else
+			return (EFAULT);
+	/* Initialize slot. */
+	sdhci_init(slot);
+	slot->version = (RD2(slot, SDHCI_HOST_VERSION)
+		>> SDHCI_SPEC_VER_SHIFT) & SDHCI_SPEC_VER_MASK;
+	if (slot->quirks & SDHCI_QUIRK_MISSING_CAPS)
+		caps = slot->caps;
+	else
+		caps = RD4(slot, SDHCI_CAPABILITIES);
+	/* Calculate base clock frequency. */
+	if (slot->version >= SDHCI_SPEC_300)
+		freq = (caps & SDHCI_CLOCK_V3_BASE_MASK) >>
+		    SDHCI_CLOCK_BASE_SHIFT;
+	else
+		freq = (caps & SDHCI_CLOCK_BASE_MASK) >>
+	if (freq != 0)
+		slot->max_clk = freq * 1000000;
+	 * If the frequency wasn't in the capabilities and the hardware driver
+	 * hasn't already set max_clk we're probably not going to work right
+	 * with an assumption, so complain about it.
+	if (slot->max_clk == 0) {
+		slot->max_clk = SDHCI_DEFAULT_MAX_FREQ * 1000000;
+		device_printf(dev, "Hardware doesn't specify base clock "
+		    "frequency, using %dMHz as default.\n", SDHCI_DEFAULT_MAX_FREQ);
+	/* Calculate timeout clock frequency. */
+	if (slot->quirks & SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK) {
+		slot->timeout_clk = slot->max_clk / 1000;
+	} else {
+			(caps & SDHCI_TIMEOUT_CLK_MASK) >> SDHCI_TIMEOUT_CLK_SHIFT;
+		if (caps & SDHCI_TIMEOUT_CLK_UNIT)
+			slot->timeout_clk *= 1000;
+	 * hasn't already set timeout_clk we'll probably work okay using the
+	 * max timeout, but still mention it.
+	if (slot->timeout_clk == 0) {
+		device_printf(dev, "Hardware doesn't specify timeout clock "
+		    "frequency, setting BROKEN_TIMEOUT quirk.\n");
+		slot->quirks |= SDHCI_QUIRK_BROKEN_TIMEOUT_VAL;
+	slot->host.f_min = SDHCI_MIN_FREQ(slot->bus, slot);
+	slot->host.f_max = slot->max_clk;
+	slot->host.host_ocr = 0;
+	if (caps & SDHCI_CAN_VDD_330)
+	    slot->host.host_ocr |= MMC_OCR_320_330 | MMC_OCR_330_340;
+	if (caps & SDHCI_CAN_VDD_300)
+	    slot->host.host_ocr |= MMC_OCR_290_300 | MMC_OCR_300_310;
+	if (caps & SDHCI_CAN_VDD_180)
+	    slot->host.host_ocr |= MMC_OCR_LOW_VOLTAGE;
+	if (slot->host.host_ocr == 0) {
+		device_printf(dev, "Hardware doesn't report any "
+		    "support voltages.\n");
+	slot->host.caps = MMC_CAP_4_BIT_DATA;
+	if (caps & SDHCI_CAN_DO_8BITBUS)
+		slot->host.caps |= MMC_CAP_8_BIT_DATA;
+	if (caps & SDHCI_CAN_DO_HISPD)
+		slot->host.caps |= MMC_CAP_HSPEED;
+	/* Decide if we have usable DMA. */
+	if (caps & SDHCI_CAN_DO_DMA)
+		slot->opt |= SDHCI_HAVE_DMA;
+	if (slot->quirks & SDHCI_QUIRK_BROKEN_DMA)
+		slot->opt &= ~SDHCI_HAVE_DMA;
+	if (slot->quirks & SDHCI_QUIRK_FORCE_DMA)
+	 * Use platform-provided transfer backend
+	 * with PIO as a fallback mechanism
+	if (slot->opt & SDHCI_PLATFORM_TRANSFER)
+	if (bootverbose || sdhci_debug) {
+		slot_printf(slot, "%uMHz%s %s%s%s%s %s\n",
+		    slot->max_clk / 1000000,
+		    (caps & SDHCI_CAN_DO_HISPD) ? " HS" : "",
+		    (caps & MMC_CAP_8_BIT_DATA) ? "8bits" :
+			((caps & MMC_CAP_4_BIT_DATA) ? "4bits" : "1bit"),
+		    (caps & SDHCI_CAN_VDD_330) ? " 3.3V" : "",
+		    (caps & SDHCI_CAN_VDD_300) ? " 3.0V" : "",
+		    (caps & SDHCI_CAN_VDD_180) ? " 1.8V" : "",
+		    (slot->opt & SDHCI_HAVE_DMA) ? "DMA" : "PIO");
+	slot->timeout = 10;
+	SYSCTL_ADD_INT(device_get_sysctl_ctx(slot->bus),
+	    SYSCTL_CHILDREN(device_get_sysctl_tree(slot->bus)), OID_AUTO,
+	    "timeout", CTLFLAG_RW, &slot->timeout, 0,
+	    "Maximum timeout for SDHCI transfers (in secs)");
+	TASK_INIT(&slot->card_task, 0, sdhci_card_task, slot);
+	callout_init(&slot->card_callout, 1);
+	callout_init_mtx(&slot->timeout_callout, &slot->mtx, 0);
+	return (0);
+void
+sdhci_start_slot(struct sdhci_slot *slot)
+	sdhci_card_task(slot, 0);
+int
+sdhci_cleanup_slot(struct sdhci_slot *slot)
+	device_t d;
+	callout_drain(&slot->timeout_callout);
+	callout_drain(&slot->card_callout);
+	taskqueue_drain(taskqueue_swi_giant, &slot->card_task);
+	SDHCI_LOCK(slot);
+	d = slot->dev;
+	slot->dev = NULL;
+	if (d != NULL)
+	SDHCI_LOCK(slot);
+	bus_dmamap_unload(slot->dmatag, slot->dmamap);
+	bus_dmamem_free(slot->dmatag, slot->dmamem, slot->dmamap);
+	bus_dma_tag_destroy(slot->dmatag);
+	return (0);
+int
+sdhci_generic_suspend(struct sdhci_slot *slot)
+	return (0);
+int
+sdhci_generic_resume(struct sdhci_slot *slot)
+	sdhci_init(slot);
+	return (0);
+uint32_t
+sdhci_generic_min_freq(device_t brdev, struct sdhci_slot *slot)
+		return (slot->max_clk / SDHCI_300_MAX_DIVIDER);
+	else
+		return (slot->max_clk / SDHCI_200_MAX_DIVIDER);
+int
+sdhci_generic_update_ios(device_t brdev, device_t reqdev)
+	struct sdhci_slot *slot = device_get_ivars(reqdev);
+	struct mmc_ios *ios = &slot->host.ios;
+	SDHCI_LOCK(slot);
+	/* Do full reset on bus power down to clear from any state. */
+	if (ios->power_mode == power_off) {
+		WR4(slot, SDHCI_SIGNAL_ENABLE, 0);
+		sdhci_init(slot);
+	/* Configure the bus. */
+	sdhci_set_clock(slot, ios->clock);
+	sdhci_set_power(slot, (ios->power_mode == power_off) ? 0 : ios->vdd);
+	if (ios->bus_width == bus_width_8) {
+		slot->hostctrl |= SDHCI_CTRL_8BITBUS;
+		slot->hostctrl &= ~SDHCI_CTRL_4BITBUS;
+	} else if (ios->bus_width == bus_width_4) {
+		slot->hostctrl &= ~SDHCI_CTRL_8BITBUS;
+		slot->hostctrl |= SDHCI_CTRL_4BITBUS;
+	} else if (ios->bus_width == bus_width_1) {
+	} else {
+		panic("Invalid bus width: %d", ios->bus_width);
+	if (ios->timing == bus_timing_hs &&
+	    !(slot->quirks & SDHCI_QUIRK_DONT_SET_HISPD_BIT))
+		slot->hostctrl |= SDHCI_CTRL_HISPD;
+	else
+		slot->hostctrl &= ~SDHCI_CTRL_HISPD;
+	WR1(slot, SDHCI_HOST_CONTROL, slot->hostctrl);
+	/* Some controllers like reset after bus changes. */
+	if(slot->quirks & SDHCI_QUIRK_RESET_ON_IOS)
+		sdhci_reset(slot, SDHCI_RESET_CMD | SDHCI_RESET_DATA);
+	return (0);
+static void
+sdhci_req_done(struct sdhci_slot *slot)
+	struct mmc_request *req;
+	if (slot->req != NULL && slot->curcmd != NULL) {
+		callout_stop(&slot->timeout_callout);
+		req = slot->req;
+		slot->req = NULL;
+		slot->curcmd = NULL;
+		req->done(req);
+static void
+sdhci_timeout(void *arg)
+	if (slot->curcmd != NULL) {
+		slot_printf(slot, " Controller timeout\n");
+		sdhci_reset(slot, SDHCI_RESET_CMD|SDHCI_RESET_DATA);
+		slot->curcmd->error = MMC_ERR_TIMEOUT;
+		sdhci_req_done(slot);
+	} else {
+		slot_printf(slot, " Spurious timeout - no active command\n");
+static void
+sdhci_set_transfer_mode(struct sdhci_slot *slot,
+	struct mmc_data *data)
+	uint16_t mode;
+	if (data == NULL)
+		return;
+	mode = SDHCI_TRNS_BLK_CNT_EN;
+	if (data->len > 512)
+		mode |= SDHCI_TRNS_MULTI;
+	if (data->flags & MMC_DATA_READ)
+		mode |= SDHCI_TRNS_READ;
+	if (slot->req->stop)
+		mode |= SDHCI_TRNS_ACMD12;
+	if (slot->flags & SDHCI_USE_DMA)
+		mode |= SDHCI_TRNS_DMA;
+	WR2(slot, SDHCI_TRANSFER_MODE, mode);
+static void
+sdhci_start_command(struct sdhci_slot *slot, struct mmc_command *cmd)
+	int flags, timeout;
+	uint32_t mask, state;
+	slot->curcmd = cmd;
+	slot->cmd_done = 0;
+	cmd->error = MMC_ERR_NONE;
+	/* This flags combination is not supported by controller. */
+	if ((cmd->flags & MMC_RSP_136) && (cmd->flags & MMC_RSP_BUSY)) {
+		slot_printf(slot, "Unsupported response type!\n");
+		cmd->error = MMC_ERR_FAILED;
+		return;
+	/* Read controller present state. */
+	state = RD4(slot, SDHCI_PRESENT_STATE);
+	/* Do not issue command if there is no card, clock or power.
+	 * Controller will not detect timeout without clock active. */
+	if ((state & SDHCI_CARD_PRESENT) == 0 ||
+	    slot->power == 0 ||
+	    slot->clock == 0) {
+		return;
+	/* Always wait for free CMD bus. */
+	mask = SDHCI_CMD_INHIBIT;
+	/* Wait for free DAT if we have data or busy signal. */
+	if (cmd->data || (cmd->flags & MMC_RSP_BUSY))
+		mask |= SDHCI_DAT_INHIBIT;
+	/* We shouldn't wait for DAT for stop commands. */
+	if (cmd == slot->req->stop)
+		mask &= ~SDHCI_DAT_INHIBIT;
+	 *  Wait for bus no more then 250 ms.  Typically there will be no wait
+	 *  here at all, but when writing a crash dump we may be bypassing the
+	 *  host platform's interrupt handler, and in some cases that handler
+	 *  may be working around hardware quirks such as not respecting r1b
+	 *  busy indications.  In those cases, this wait-loop serves the purpose
+	 *  of waiting for the prior command and data transfers to be done, and
+	 *  SD cards are allowed to take up to 250ms for write and erase ops.
+	 *  (It's usually more like 20-30ms in the real world.)
+	timeout = 250;
+	while (state & mask) {
+			slot_printf(slot, "Controller never released "
+			    "inhibit bit(s).\n");
+			return;
+		timeout--;
+		DELAY(1000);
+	/* Prepare command flags. */
+	if (!(cmd->flags & MMC_RSP_PRESENT))
+		flags = SDHCI_CMD_RESP_NONE;
+	else if (cmd->flags & MMC_RSP_136)
+		flags = SDHCI_CMD_RESP_LONG;
+	else if (cmd->flags & MMC_RSP_BUSY)
+		flags = SDHCI_CMD_RESP_SHORT_BUSY;
+	else
+		flags = SDHCI_CMD_RESP_SHORT;
+	if (cmd->flags & MMC_RSP_CRC)
+		flags |= SDHCI_CMD_CRC;
+	if (cmd->flags & MMC_RSP_OPCODE)
+		flags |= SDHCI_CMD_INDEX;
+	if (cmd->data)
+		flags |= SDHCI_CMD_DATA;
+	if (cmd->opcode == MMC_STOP_TRANSMISSION)
+		flags |= SDHCI_CMD_TYPE_ABORT;
+	/* Prepare data. */
+	sdhci_start_data(slot, cmd->data);
+	 * Interrupt aggregation: To reduce total number of interrupts
+	 * group response interrupt with data interrupt when possible.
+	 * If there going to be data interrupt, mask response one.
+	if (slot->data_done == 0) {
+		    slot->intmask &= ~SDHCI_INT_RESPONSE);
+	/* Set command argument. */
+	WR4(slot, SDHCI_ARGUMENT, cmd->arg);
+	/* Set data transfer mode. */
+	sdhci_set_transfer_mode(slot, cmd->data);
+	/* Start command. */
+	WR2(slot, SDHCI_COMMAND_FLAGS, (cmd->opcode << 8) | (flags & 0xff));
+	/* Start timeout callout. */
+	callout_reset(&slot->timeout_callout, slot->timeout * hz,
+	    sdhci_timeout, slot);
+static void
+sdhci_finish_command(struct sdhci_slot *slot)
+	int i;
+	slot->cmd_done = 1;
+	/* Interrupt aggregation: Restore command interrupt.
+	 * Main restore point for the case when command interrupt
+	 * happened first. */
+	WR4(slot, SDHCI_SIGNAL_ENABLE, slot->intmask |= SDHCI_INT_RESPONSE);
+	/* In case of error - reset host and return. */
+	if (slot->curcmd->error) {
+		sdhci_reset(slot, SDHCI_RESET_CMD);
+		sdhci_reset(slot, SDHCI_RESET_DATA);
+		sdhci_start(slot);
+		return;
+	/* If command has response - fetch it. */
+	if (slot->curcmd->flags & MMC_RSP_PRESENT) {
+		if (slot->curcmd->flags & MMC_RSP_136) {
+			/* CRC is stripped so we need one byte shift. */
+			uint8_t extra = 0;
+			for (i = 0; i < 4; i++) {
+				uint32_t val = RD4(slot, SDHCI_RESPONSE + i * 4);
+				if (slot->quirks & SDHCI_QUIRK_DONT_SHIFT_RESPONSE)
+					slot->curcmd->resp[3 - i] = val;
+				else {
+					    (val << 8) | extra;
+					extra = val >> 24;
+		} else
+			slot->curcmd->resp[0] = RD4(slot, SDHCI_RESPONSE);
+	/* If data ready - finish. */
+	if (slot->data_done)
+static void
+sdhci_start_data(struct sdhci_slot *slot, struct mmc_data *data)
+	uint32_t target_timeout, current_timeout;
+	uint8_t div;
+	if (data == NULL && (slot->curcmd->flags & MMC_RSP_BUSY) == 0) {
+		slot->data_done = 1;
+		return;
+	slot->data_done = 0;
+	/* Calculate and set data timeout.*/
+	/* XXX: We should have this from mmc layer, now assume 1 sec. */
+	if (slot->quirks & SDHCI_QUIRK_BROKEN_TIMEOUT_VAL) {
+		div = 0xE;
+	} else {
+		target_timeout = 1000000;
+		div = 0;
+		current_timeout = (1 << 13) * 1000 / slot->timeout_clk;
+		while (current_timeout < target_timeout && div < 0xE) {
+			++div;
+			current_timeout <<= 1;
+		/* Compensate for an off-by-one error in the CaFe chip.*/
+		if (div < 0xE &&
+		    (slot->quirks & SDHCI_QUIRK_INCR_TIMEOUT_CONTROL)) {
+			++div;
+	WR1(slot, SDHCI_TIMEOUT_CONTROL, div);
+	if (data == NULL)
+		return;
+	/* Use DMA if possible. */
+	if ((slot->opt & SDHCI_HAVE_DMA))
+		slot->flags |= SDHCI_USE_DMA;
+	/* If data is small, broken DMA may return zeroes instead of data, */
+	if ((slot->quirks & SDHCI_QUIRK_BROKEN_TIMINGS) &&
+	    (data->len <= 512))
+		slot->flags &= ~SDHCI_USE_DMA;
+	/* Some controllers require even block sizes. */
+	if ((slot->quirks & SDHCI_QUIRK_32BIT_DMA_SIZE) &&
+	    ((data->len) & 0x3))
+	/* Load DMA buffer. */
+	if (slot->flags & SDHCI_USE_DMA) {
+			bus_dmamap_sync(slot->dmatag, slot->dmamap,
+			    BUS_DMASYNC_PREREAD);
+		else {
+			memcpy(slot->dmamem, data->data,
+			    (data->len < DMA_BLOCK_SIZE) ?
+			    data->len : DMA_BLOCK_SIZE);
+			    BUS_DMASYNC_PREWRITE);
+		WR4(slot, SDHCI_DMA_ADDRESS, slot->paddr);
+		/* Interrupt aggregation: Mask border interrupt
+		 * for the last page and unmask else. */
+		if (data->len == DMA_BLOCK_SIZE)
+			slot->intmask &= ~SDHCI_INT_DMA_END;
+		else
+			slot->intmask |= SDHCI_INT_DMA_END;
+	/* Current data offset for both PIO and DMA. */
+	slot->offset = 0;
+	/* Set block size and request IRQ on 4K border. */
+	WR2(slot, SDHCI_BLOCK_SIZE,
+	    SDHCI_MAKE_BLKSZ(DMA_BOUNDARY, (data->len < 512)?data->len:512));
+	/* Set block count. */
+	WR2(slot, SDHCI_BLOCK_COUNT, (data->len + 511) / 512);
+void
+sdhci_finish_data(struct sdhci_slot *slot)
+	struct mmc_data *data = slot->curcmd->data;
+	 * Auxiliary restore point for the case when data interrupt
+	if (!slot->cmd_done) {
+		    slot->intmask |= SDHCI_INT_RESPONSE);
+	/* Unload rest of data from DMA buffer. */
+	if (!slot->data_done && (slot->flags & SDHCI_USE_DMA)) {
+		if (data->flags & MMC_DATA_READ) {
+			size_t left = data->len - slot->offset;
+			    BUS_DMASYNC_POSTREAD);
+			memcpy((u_char*)data->data + slot->offset, slot->dmamem,
+			    (left < DMA_BLOCK_SIZE)?left:DMA_BLOCK_SIZE);
+		} else
+			    BUS_DMASYNC_POSTWRITE);
+	/* If there was error - reset the host. */
+		return;
+	/* If we already have command response - finish. */
+	if (slot->cmd_done)
+static void
+sdhci_start(struct sdhci_slot *slot)
+	req = slot->req;
+	if (req == NULL)
+		return;
+	if (!(slot->flags & CMD_STARTED)) {
+		slot->flags |= CMD_STARTED;
+		sdhci_start_command(slot, req->cmd);
+		return;
+/* 	We don't need this until using Auto-CMD12 feature
+	if (!(slot->flags & STOP_STARTED) && req->stop) {
+		slot->flags |= STOP_STARTED;
+		sdhci_start_command(slot, req->stop);
+		return;
+	if (sdhci_debug > 1)
+		slot_printf(slot, "result: %d\n", req->cmd->error);
+	if (!req->cmd->error &&
+	    (slot->quirks & SDHCI_QUIRK_RESET_AFTER_REQUEST)) {
+int
+sdhci_generic_request(device_t brdev, device_t reqdev, struct mmc_request *req)
+	SDHCI_LOCK(slot);
+	if (slot->req != NULL) {
+		return (EBUSY);
+	if (sdhci_debug > 1) {
+		slot_printf(slot, "CMD%u arg %#x flags %#x dlen %u dflags %#x\n",
+    		    req->cmd->opcode, req->cmd->arg, req->cmd->flags,
+    		    (req->cmd->data)?(u_int)req->cmd->data->len:0,
+		    (req->cmd->data)?req->cmd->data->flags:0);
+	slot->req = req;
+	slot->flags = 0;
+	if (dumping) {
+		while (slot->req != NULL) {
+			sdhci_generic_intr(slot);
+			DELAY(10);
+	return (0);
+int
+sdhci_generic_get_ro(device_t brdev, device_t reqdev)
+	uint32_t val;
+	SDHCI_LOCK(slot);
+	val = RD4(slot, SDHCI_PRESENT_STATE);
+	return (!(val & SDHCI_WRITE_PROTECT));
+int
+sdhci_generic_acquire_host(device_t brdev, device_t reqdev)
+	int err = 0;
+	SDHCI_LOCK(slot);
+	while (slot->bus_busy)
+		msleep(slot, &slot->mtx, 0, "sdhciah", 0);
+	slot->bus_busy++;
+	/* Activate led. */
+	WR1(slot, SDHCI_HOST_CONTROL, slot->hostctrl |= SDHCI_CTRL_LED);
+	return (err);
+int
+sdhci_generic_release_host(device_t brdev, device_t reqdev)
+	SDHCI_LOCK(slot);
+	/* Deactivate led. */
+	WR1(slot, SDHCI_HOST_CONTROL, slot->hostctrl &= ~SDHCI_CTRL_LED);
+	slot->bus_busy--;
+	wakeup(slot);
+	return (0);
+static void
+sdhci_cmd_irq(struct sdhci_slot *slot, uint32_t intmask)
+	if (!slot->curcmd) {
+		slot_printf(slot, "Got command interrupt 0x%08x, but "
+		    "there is no active command.\n", intmask);
+		return;
+	if (intmask & SDHCI_INT_TIMEOUT)
+	else if (intmask & SDHCI_INT_CRC)
+		slot->curcmd->error = MMC_ERR_BADCRC;
+	else if (intmask & (SDHCI_INT_END_BIT | SDHCI_INT_INDEX))
+		slot->curcmd->error = MMC_ERR_FIFO;
+	sdhci_finish_command(slot);
+static void
+sdhci_data_irq(struct sdhci_slot *slot, uint32_t intmask)
+		slot_printf(slot, "Got data interrupt 0x%08x, but "
+		return;
+	if (slot->curcmd->data == NULL &&
+	    (slot->curcmd->flags & MMC_RSP_BUSY) == 0) {
+		    "there is no active data operation.\n",
+		    intmask);
+		return;
+	if (intmask & SDHCI_INT_DATA_TIMEOUT)
+	else if (intmask & (SDHCI_INT_DATA_CRC | SDHCI_INT_DATA_END_BIT))
+	    (intmask & (SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL |
+	    SDHCI_INT_DMA_END))) {
+		    "there is busy-only command.\n", intmask);
+		slot->curcmd->error = MMC_ERR_INVALID;
+		/* No need to continue after any error. */
+		goto done;
+	/* Handle PIO interrupt. */
+	if (intmask & (SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL)) {
+		if ((slot->opt & SDHCI_PLATFORM_TRANSFER) &&
+		    SDHCI_PLATFORM_WILL_HANDLE(slot->bus, slot)) {
+			SDHCI_PLATFORM_START_TRANSFER(slot->bus, slot, &intmask);
+			slot->flags |= PLATFORM_DATA_STARTED;
+		} else
+			sdhci_transfer_pio(slot);
+	/* Handle DMA border. */
+	if (intmask & SDHCI_INT_DMA_END) {
+		size_t left;
+		/* Unload DMA buffer... */
+		left = data->len - slot->offset;
+		} else {
+		/* ... and reload it again. */
+		slot->offset += DMA_BLOCK_SIZE;
+		} else {
+			memcpy(slot->dmamem, (u_char*)data->data + slot->offset,
+		 * for the last page. */
+		if (left == DMA_BLOCK_SIZE) {
+		/* Restart DMA. */
+	/* We have got all data. */
+	if (intmask & SDHCI_INT_DATA_END) {
+		if (slot->flags & PLATFORM_DATA_STARTED) {
+			slot->flags &= ~PLATFORM_DATA_STARTED;
+			SDHCI_PLATFORM_FINISH_TRANSFER(slot->bus, slot);
+		} else
+			sdhci_finish_data(slot);
+done:
+	if (slot->curcmd != NULL && slot->curcmd->error != 0) {
+		} else
+		return;
+static void
+sdhci_acmd_irq(struct sdhci_slot *slot)
+	uint16_t err;
+	err = RD4(slot, SDHCI_ACMD12_ERR);
+		slot_printf(slot, "Got AutoCMD12 error 0x%04x, but "
+		    "there is no active command.\n", err);
+		return;
+	slot_printf(slot, "Got AutoCMD12 error 0x%04x\n", err);
+void
+sdhci_generic_intr(struct sdhci_slot *slot)
+	uint32_t intmask;
+	SDHCI_LOCK(slot);
+	/* Read slot interrupt status. */
+	intmask = RD4(slot, SDHCI_INT_STATUS);
+	if (intmask == 0 || intmask == 0xffffffff) {
+		return;
+	if (sdhci_debug > 2)
+		slot_printf(slot, "Interrupt %#x\n", intmask);
+	/* Handle card presence interrupts. */
+	if (intmask & (SDHCI_INT_CARD_INSERT | SDHCI_INT_CARD_REMOVE)) {
+		WR4(slot, SDHCI_INT_STATUS, intmask &
+		    (SDHCI_INT_CARD_INSERT | SDHCI_INT_CARD_REMOVE));
+		if (intmask & SDHCI_INT_CARD_REMOVE) {
+				slot_printf(slot, "Card removed\n");
+			callout_stop(&slot->card_callout);
+			    &slot->card_task);
+		if (intmask & SDHCI_INT_CARD_INSERT) {
+				slot_printf(slot, "Card inserted\n");
+			callout_reset(&slot->card_callout, hz / 2,
+			    sdhci_card_delay, slot);
+		intmask &= ~(SDHCI_INT_CARD_INSERT | SDHCI_INT_CARD_REMOVE);
+	/* Handle command interrupts. */
+	if (intmask & SDHCI_INT_CMD_MASK) {
+		WR4(slot, SDHCI_INT_STATUS, intmask & SDHCI_INT_CMD_MASK);
+		sdhci_cmd_irq(slot, intmask & SDHCI_INT_CMD_MASK);
+	/* Handle data interrupts. */
+	if (intmask & SDHCI_INT_DATA_MASK) {
+		WR4(slot, SDHCI_INT_STATUS, intmask & SDHCI_INT_DATA_MASK);
+		/* Dont call data_irq in case of errored command */
+		if ((intmask & SDHCI_INT_CMD_ERROR_MASK) == 0)
+			sdhci_data_irq(slot, intmask & SDHCI_INT_DATA_MASK);
+	/* Handle AutoCMD12 error interrupt. */
+	if (intmask & SDHCI_INT_ACMD12ERR) {
+		WR4(slot, SDHCI_INT_STATUS, SDHCI_INT_ACMD12ERR);
+		sdhci_acmd_irq(slot);
+	intmask &= ~(SDHCI_INT_CMD_MASK | SDHCI_INT_DATA_MASK);
+	intmask &= ~SDHCI_INT_ACMD12ERR;
+	intmask &= ~SDHCI_INT_ERROR;
+	/* Handle bus power interrupt. */
+	if (intmask & SDHCI_INT_BUS_POWER) {
+		WR4(slot, SDHCI_INT_STATUS, SDHCI_INT_BUS_POWER);
+		slot_printf(slot,
+		    "Card is consuming too much power!\n");
+		intmask &= ~SDHCI_INT_BUS_POWER;
+	/* The rest is unknown. */
+	if (intmask) {
+		WR4(slot, SDHCI_INT_STATUS, intmask);
+		slot_printf(slot, "Unexpected interrupt 0x%08x.\n",
+		    intmask);
+int
+sdhci_generic_read_ivar(device_t bus, device_t child, int which, uintptr_t *result)
+	struct sdhci_slot *slot = device_get_ivars(child);
+	switch (which) {
+	default:
+		return (EINVAL);
+	case MMCBR_IVAR_BUS_MODE:
+		*result = slot->host.ios.bus_mode;
+		break;
+	case MMCBR_IVAR_BUS_WIDTH:
+		*result = slot->host.ios.bus_width;
+		break;
+	case MMCBR_IVAR_CHIP_SELECT:
+		*result = slot->host.ios.chip_select;
+		break;
+	case MMCBR_IVAR_CLOCK:
+		*result = slot->host.ios.clock;
+		break;
+	case MMCBR_IVAR_F_MIN:
+		*result = slot->host.f_min;
+		break;
+	case MMCBR_IVAR_F_MAX:
+		*result = slot->host.f_max;
+		break;
+	case MMCBR_IVAR_HOST_OCR:
+		*result = slot->host.host_ocr;
+		break;
+	case MMCBR_IVAR_MODE:
+		*result = slot->host.mode;
+		break;
+	case MMCBR_IVAR_OCR:
+		*result = slot->host.ocr;
+		break;
+	case MMCBR_IVAR_POWER_MODE:
+		*result = slot->host.ios.power_mode;
+		break;
+	case MMCBR_IVAR_VDD:
+		*result = slot->host.ios.vdd;
+		break;
+	case MMCBR_IVAR_CAPS:
+		*result = slot->host.caps;
+		break;
+	case MMCBR_IVAR_TIMING:
+		*result = slot->host.ios.timing;
+		break;
+	case MMCBR_IVAR_MAX_DATA:
+		*result = 65535;
+		break;
+	return (0);
+int
+sdhci_generic_write_ivar(device_t bus, device_t child, int which, uintptr_t value)
+	switch (which) {
+	default:
+		return (EINVAL);
+		slot->host.ios.bus_mode = value;
+		break;
+		slot->host.ios.bus_width = value;
+		break;
+		slot->host.ios.chip_select = value;
+		break;
+		if (value > 0) {
+			uint32_t max_clock;
+			uint32_t clock;
+			int i;
+			max_clock = slot->max_clk;
+			clock = max_clock;
+				for (i = 0; i < SDHCI_200_MAX_DIVIDER;
+				    i <<= 1) {
+					if (clock <= value)
+						break;
+					clock >>= 1;
+			else {
+				for (i = 0; i < SDHCI_300_MAX_DIVIDER;
+				    i += 2) {
+						break;
+					clock = max_clock / (i + 2);
+			slot->host.ios.clock = clock;
+		} else
+			slot->host.ios.clock = 0;
+		break;
+		slot->host.mode = value;
+		break;
+		slot->host.ocr = value;
+		break;
+		slot->host.ios.power_mode = value;
+		break;
+		slot->host.ios.vdd = value;
+		break;
+		slot->host.ios.timing = value;
+		break;
+		return (EINVAL);
+	return (0);
+MODULE_VERSION(sdhci, 1);
diff --git a/freebsd/sys/dev/sdhci/sdhci.h b/freebsd/sys/dev/sdhci/sdhci.h
index 0000000..2638b4f
--- /dev/null
+++ b/freebsd/sys/dev/sdhci/sdhci.h
@@ -0,0 +1,326 @@
+ * are met:
+ * $FreeBSD$
+#ifndef	__SDHCI_H__
+#define	__SDHCI_H__
+#define DMA_BLOCK_SIZE	4096
+#define DMA_BOUNDARY	0	/* DMA reload every 4K */
+/* Controller doesn't honor resets unless we touch the clock register */
+#define SDHCI_QUIRK_CLOCK_BEFORE_RESET			(1<<0)
+/* Controller really supports DMA */
+#define SDHCI_QUIRK_FORCE_DMA				(1<<1)
+/* Controller has unusable DMA engine */
+#define SDHCI_QUIRK_BROKEN_DMA				(1<<2)
+/* Controller doesn't like to be reset when there is no card inserted. */
+#define SDHCI_QUIRK_NO_CARD_NO_RESET			(1<<3)
+/* Controller has flaky internal state so reset it on each ios change */
+#define SDHCI_QUIRK_RESET_ON_IOS			(1<<4)
+/* Controller can only DMA chunk sizes that are a multiple of 32 bits */
+#define SDHCI_QUIRK_32BIT_DMA_SIZE			(1<<5)
+/* Controller needs to be reset after each request to stay stable */
+#define SDHCI_QUIRK_RESET_AFTER_REQUEST			(1<<6)
+/* Controller has an off-by-one issue with timeout value */
+#define SDHCI_QUIRK_INCR_TIMEOUT_CONTROL		(1<<7)
+/* Controller has broken read timings */
+#define SDHCI_QUIRK_BROKEN_TIMINGS			(1<<8)
+/* Controller needs lowered frequency */
+#define	SDHCI_QUIRK_LOWER_FREQUENCY			(1<<9)
+/* Data timeout is invalid, should use SD clock */
+#define	SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK		(1<<10)
+/* Timeout value is invalid, should be overriden */
+#define	SDHCI_QUIRK_BROKEN_TIMEOUT_VAL			(1<<11)
+/* SDHCI_CAPABILITIES is invalid */
+#define	SDHCI_QUIRK_MISSING_CAPS			(1<<12)
+/* Hardware shifts the 136-bit response, don't do it in software. */
+#define	SDHCI_QUIRK_DONT_SHIFT_RESPONSE			(1<<13)
+/* Wait to see reset bit asserted before waiting for de-asserted  */
+#define	SDHCI_QUIRK_WAITFOR_RESET_ASSERTED		(1<<14)
+/* Leave controller in standard mode when putting card in HS mode. */
+#define	SDHCI_QUIRK_DONT_SET_HISPD_BIT			(1<<15)
+/* Alternate clock source is required when supplying a 400 KHz clock. */
+#define	SDHCI_QUIRK_BCM577XX_400KHZ_CLKSRC		(1<<16)
+ * Controller registers
+#define SDHCI_DMA_ADDRESS	0x00
+#define SDHCI_BLOCK_SIZE	0x04
+#define  SDHCI_MAKE_BLKSZ(dma, blksz) (((dma & 0x7) << 12) | (blksz & 0xFFF))
+#define SDHCI_BLOCK_COUNT	0x06
+#define SDHCI_ARGUMENT		0x08
+#define SDHCI_TRANSFER_MODE	0x0C
+#define  SDHCI_TRNS_DMA		0x01
+#define  SDHCI_TRNS_BLK_CNT_EN	0x02
+#define  SDHCI_TRNS_ACMD12	0x04
+#define  SDHCI_TRNS_READ	0x10
+#define  SDHCI_TRNS_MULTI	0x20
+#define SDHCI_COMMAND_FLAGS	0x0E
+#define  SDHCI_CMD_RESP_NONE	0x00
+#define  SDHCI_CMD_RESP_LONG	0x01
+#define  SDHCI_CMD_RESP_SHORT	0x02
+#define  SDHCI_CMD_RESP_SHORT_BUSY 0x03
+#define  SDHCI_CMD_RESP_MASK	0x03
+#define  SDHCI_CMD_CRC		0x08
+#define  SDHCI_CMD_INDEX	0x10
+#define  SDHCI_CMD_DATA		0x20
+#define  SDHCI_CMD_TYPE_NORMAL	0x00
+#define  SDHCI_CMD_TYPE_SUSPEND	0x40
+#define  SDHCI_CMD_TYPE_RESUME	0x80
+#define  SDHCI_CMD_TYPE_ABORT	0xc0
+#define  SDHCI_CMD_TYPE_MASK	0xc0
+#define SDHCI_COMMAND		0x0F
+#define SDHCI_RESPONSE		0x10
+#define SDHCI_BUFFER		0x20
+#define SDHCI_PRESENT_STATE	0x24
+#define  SDHCI_CMD_INHIBIT	0x00000001
+#define  SDHCI_DAT_INHIBIT	0x00000002
+#define  SDHCI_DAT_ACTIVE	0x00000004
+#define  SDHCI_RETUNE_REQUEST	0x00000008
+#define  SDHCI_DOING_WRITE	0x00000100
+#define  SDHCI_DOING_READ	0x00000200
+#define  SDHCI_SPACE_AVAILABLE	0x00000400
+#define  SDHCI_DATA_AVAILABLE	0x00000800
+#define  SDHCI_CARD_PRESENT	0x00010000
+#define  SDHCI_CARD_STABLE	0x00020000
+#define  SDHCI_CARD_PIN		0x00040000
+#define  SDHCI_WRITE_PROTECT	0x00080000
+#define  SDHCI_STATE_DAT_MASK	0x00f00000
+#define  SDHCI_STATE_CMD	0x01000000
+#define SDHCI_HOST_CONTROL 	0x28
+#define  SDHCI_CTRL_LED		0x01
+#define  SDHCI_CTRL_4BITBUS	0x02
+#define  SDHCI_CTRL_HISPD	0x04
+#define  SDHCI_CTRL_SDMA	0x08
+#define  SDHCI_CTRL_ADMA2	0x10
+#define  SDHCI_CTRL_ADMA264	0x18
+#define  SDHCI_CTRL_DMA_MASK	0x18
+#define  SDHCI_CTRL_8BITBUS	0x20
+#define  SDHCI_CTRL_CARD_DET	0x40
+#define  SDHCI_CTRL_FORCE_CARD	0x80
+#define SDHCI_POWER_CONTROL	0x29
+#define  SDHCI_POWER_ON		0x01
+#define  SDHCI_POWER_180	0x0A
+#define  SDHCI_POWER_300	0x0C
+#define  SDHCI_POWER_330	0x0E
+#define SDHCI_BLOCK_GAP_CONTROL	0x2A
+#define SDHCI_WAKE_UP_CONTROL	0x2B
+#define SDHCI_CLOCK_CONTROL	0x2C
+#define  SDHCI_DIVIDER_MASK	0xff
+#define  SDHCI_DIVIDER_MASK_LEN	8
+#define  SDHCI_DIVIDER_SHIFT	8
+#define  SDHCI_DIVIDER_HI_MASK	3
+#define  SDHCI_DIVIDER_HI_SHIFT	6
+#define  SDHCI_CLOCK_CARD_EN	0x0004
+#define  SDHCI_CLOCK_INT_STABLE	0x0002
+#define  SDHCI_CLOCK_INT_EN	0x0001
+#define  SDHCI_DIVIDERS_MASK	\
+    ((SDHCI_DIVIDER_MASK << SDHCI_DIVIDER_SHIFT) | \
+    (SDHCI_DIVIDER_HI_MASK << SDHCI_DIVIDER_HI_SHIFT))
+#define SDHCI_TIMEOUT_CONTROL	0x2E
+#define SDHCI_SOFTWARE_RESET	0x2F
+#define  SDHCI_RESET_ALL	0x01
+#define  SDHCI_RESET_CMD	0x02
+#define  SDHCI_RESET_DATA	0x04
+#define SDHCI_INT_STATUS	0x30
+#define SDHCI_INT_ENABLE	0x34
+#define SDHCI_SIGNAL_ENABLE	0x38
+#define  SDHCI_INT_RESPONSE	0x00000001
+#define  SDHCI_INT_DATA_END	0x00000002
+#define  SDHCI_INT_BLOCK_GAP	0x00000004
+#define  SDHCI_INT_DMA_END	0x00000008
+#define  SDHCI_INT_SPACE_AVAIL	0x00000010
+#define  SDHCI_INT_DATA_AVAIL	0x00000020
+#define  SDHCI_INT_CARD_INSERT	0x00000040
+#define  SDHCI_INT_CARD_REMOVE	0x00000080
+#define  SDHCI_INT_CARD_INT	0x00000100
+#define  SDHCI_INT_INT_A	0x00000200
+#define  SDHCI_INT_INT_B	0x00000400
+#define  SDHCI_INT_INT_C	0x00000800
+#define  SDHCI_INT_RETUNE	0x00001000
+#define  SDHCI_INT_ERROR	0x00008000
+#define  SDHCI_INT_TIMEOUT	0x00010000
+#define  SDHCI_INT_CRC		0x00020000
+#define  SDHCI_INT_END_BIT	0x00040000
+#define  SDHCI_INT_INDEX	0x00080000
+#define  SDHCI_INT_DATA_TIMEOUT	0x00100000
+#define  SDHCI_INT_DATA_CRC	0x00200000
+#define  SDHCI_INT_DATA_END_BIT	0x00400000
+#define  SDHCI_INT_BUS_POWER	0x00800000
+#define  SDHCI_INT_ACMD12ERR	0x01000000
+#define  SDHCI_INT_ADMAERR	0x02000000
+#define  SDHCI_INT_TUNEERR	0x04000000
+#define  SDHCI_INT_NORMAL_MASK	0x00007FFF
+#define  SDHCI_INT_ERROR_MASK	0xFFFF8000
+#define  SDHCI_INT_CMD_ERROR_MASK 	(SDHCI_INT_TIMEOUT | \
+		SDHCI_INT_CRC | SDHCI_INT_END_BIT | SDHCI_INT_INDEX)
+#define  SDHCI_INT_CMD_MASK	(SDHCI_INT_RESPONSE | SDHCI_INT_CMD_ERROR_MASK)
+#define  SDHCI_INT_DATA_MASK	(SDHCI_INT_DATA_END | SDHCI_INT_DMA_END | \
+		SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL | \
+		SDHCI_INT_DATA_TIMEOUT | SDHCI_INT_DATA_CRC | \
+		SDHCI_INT_DATA_END_BIT)
+#define SDHCI_ACMD12_ERR	0x3C
+#define SDHCI_HOST_CONTROL2	0x3E
+#define SDHCI_CAPABILITIES	0x40
+#define  SDHCI_TIMEOUT_CLK_MASK	0x0000003F
+#define  SDHCI_TIMEOUT_CLK_SHIFT 0
+#define  SDHCI_TIMEOUT_CLK_UNIT	0x00000080
+#define  SDHCI_CLOCK_BASE_MASK	0x00003F00
+#define  SDHCI_CLOCK_V3_BASE_MASK	0x0000FF00
+#define  SDHCI_CLOCK_BASE_SHIFT	8
+#define  SDHCI_MAX_BLOCK_MASK	0x00030000
+#define  SDHCI_MAX_BLOCK_SHIFT  16
+#define  SDHCI_CAN_DO_8BITBUS	0x00040000
+#define  SDHCI_CAN_DO_ADMA2	0x00080000
+#define  SDHCI_CAN_DO_HISPD	0x00200000
+#define  SDHCI_CAN_DO_DMA	0x00400000
+#define  SDHCI_CAN_DO_SUSPEND	0x00800000
+#define  SDHCI_CAN_VDD_330	0x01000000
+#define  SDHCI_CAN_VDD_300	0x02000000
+#define  SDHCI_CAN_VDD_180	0x04000000
+#define  SDHCI_CAN_DO_64BIT	0x10000000
+#define  SDHCI_CAN_ASYNC_INTR	0x20000000
+#define SDHCI_CAPABILITIES2	0x44
+#define  SDHCI_CAN_SDR50	0x00000001
+#define  SDHCI_CAN_SDR104	0x00000002
+#define  SDHCI_CAN_DDR50	0x00000004
+#define  SDHCI_CAN_DRIVE_TYPE_A	0x00000010
+#define  SDHCI_CAN_DRIVE_TYPE_B	0x00000020
+#define  SDHCI_CAN_DRIVE_TYPE_C	0x00000040
+#define  SDHCI_RETUNE_CNT_MASK	0x00000F00
+#define  SDHCI_RETUNE_CNT_SHIFT	8
+#define  SDHCI_TUNE_SDR50	0x00002000
+#define  SDHCI_RETUNE_MODES_MASK  0x0000C000
+#define  SDHCI_RETUNE_MODES_SHIFT 14
+#define  SDHCI_CLOCK_MULT_MASK	0x00FF0000
+#define  SDHCI_CLOCK_MULT_SHIFT	16
+#define SDHCI_MAX_CURRENT	0x48
+#define SDHCI_FORCE_AUTO_EVENT	0x50
+#define SDHCI_FORCE_INTR_EVENT	0x52
+#define SDHCI_ADMA_ERR		0x54
+#define SDHCI_ADMA_ADDRESS_LOW	0x58
+#define SDHCI_ADMA_ADDRESS_HI	0x5C
+#define SDHCI_PRESET_VALUE	0x60
+#define SDHCI_SHARED_BUS_CTRL	0xE0
+#define SDHCI_SLOT_INT_STATUS	0xFC
+#define SDHCI_HOST_VERSION	0xFE
+#define  SDHCI_VENDOR_VER_MASK	0xFF00
+#define  SDHCI_VENDOR_VER_SHIFT	8
+#define  SDHCI_SPEC_VER_MASK	0x00FF
+#define  SDHCI_SPEC_VER_SHIFT	0
+#define	SDHCI_SPEC_100		0
+#define	SDHCI_SPEC_200		1
+#define	SDHCI_SPEC_300		2
+SYSCTL_DECL(_hw_sdhci);
+struct sdhci_slot {
+	u_int		quirks;		/* Chip specific quirks */
+	u_int		caps;		/* Override SDHCI_CAPABILITIES */
+	device_t	bus;		/* Bus device */
+	device_t	dev;		/* Slot device */
+	u_char		num;		/* Slot number */
+	u_char		opt;		/* Slot options */
+#define SDHCI_HAVE_DMA			1
+#define SDHCI_PLATFORM_TRANSFER		2
+	u_char		version;
+	int		timeout;	/* Transfer timeout */
+	uint32_t	max_clk;	/* Max possible freq */
+	uint32_t	timeout_clk;	/* Timeout freq */
+	bus_dma_tag_t 	dmatag;
+	bus_dmamap_t 	dmamap;
+	u_char		*dmamem;
+	bus_addr_t	paddr;		/* DMA buffer address */
+	struct task	card_task;	/* Card presence check task */
+	struct callout	card_callout;	/* Card insert delay callout */
+	struct callout	timeout_callout;/* Card command/data response timeout */
+	struct mmc_host host;		/* Host parameters */
+	struct mmc_request *req;	/* Current request */
+	struct mmc_command *curcmd;	/* Current command of current request */
+	uint32_t	intmask;	/* Current interrupt mask */
+	uint32_t	clock;		/* Current clock freq. */
+	size_t		offset;		/* Data buffer offset */
+	uint8_t		hostctrl;	/* Current host control register */
+	u_char		power;		/* Current power */
+	u_char		bus_busy;	/* Bus busy status */
+	u_char		cmd_done;	/* CMD command part done flag */
+	u_char		data_done;	/* DAT command part done flag */
+	u_char		flags;		/* Request execution flags */
+#define CMD_STARTED		1
+#define STOP_STARTED		2
+#define SDHCI_USE_DMA		4	/* Use DMA for this req. */
+#define PLATFORM_DATA_STARTED	8	/* Data transfer is handled by platform */
+	struct mtx	mtx;		/* Slot mutex */
+int sdhci_generic_read_ivar(device_t bus, device_t child, int which, uintptr_t *result);
+int sdhci_generic_write_ivar(device_t bus, device_t child, int which, uintptr_t value);
+int sdhci_init_slot(device_t dev, struct sdhci_slot *slot, int num);
+void sdhci_start_slot(struct sdhci_slot *slot);
+/* performs generic clean-up for platform transfers */
+void sdhci_finish_data(struct sdhci_slot *slot);
+int sdhci_cleanup_slot(struct sdhci_slot *slot);
+int sdhci_generic_suspend(struct sdhci_slot *slot);
+int sdhci_generic_resume(struct sdhci_slot *slot);
+int sdhci_generic_update_ios(device_t brdev, device_t reqdev);
+int sdhci_generic_request(device_t brdev, device_t reqdev, struct mmc_request *req);
+int sdhci_generic_get_ro(device_t brdev, device_t reqdev);
+int sdhci_generic_acquire_host(device_t brdev, device_t reqdev);
+int sdhci_generic_release_host(device_t brdev, device_t reqdev);
+void sdhci_generic_intr(struct sdhci_slot *slot);
+uint32_t sdhci_generic_min_freq(device_t brdev, struct sdhci_slot *slot);
+#endif	/* __SDHCI_H__ */
diff --git a/libbsd.txt b/libbsd.txt
index d876cb4..da0a92a 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -779,6 +779,7 @@ detail and debug level information from the command.
 . sys/dev/dwc/*, trunk, 2015-03-26, cfc3df2b8f708ce8494d9d556e3472a5c8c21b8a
 . sys/dev/mmc/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
 . sys/dev/usb/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
+. sys/dev/sdhci/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
 . *, stable/9, 2015-04-08, 99a648a912e81e29d9c4c159cbbe263462f2d719
 == How to import code from FreeBSD
2.1.4
