[PATCH 5/7] SD Card : Intial Port of SD card driver files
Mudit Jain muditjain18011995 at gmail.com
Sun Aug 28 07:25:10 UTC 2016
 freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c | 677 +++++++++++++++++++++++
 libbsd.py                                        |   2 +
 libbsd.txt                                       |   1 +
 libbsd_waf.py                                    |   1 +
 rtemsbsd/include/rtems/bsd/local/sdhci_if.h      | 150 +++++
 rtemsbsd/local/sdhci_if.c                        |  80 +++
 6 files changed, 911 insertions(+)
 create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
 create mode 100644 rtemsbsd/include/rtems/bsd/local/sdhci_if.h
 create mode 100644 rtemsbsd/local/sdhci_if.c
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
new file mode 100644
index 0000000..4844f19
--- /dev/null
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c
@@ -0,0 +1,677 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2012 Oleksandr Tymoshenko <gonzo at freebsd.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <sys/rman.h>
+#include <sys/sysctl.h>
+#include <sys/taskqueue.h>
+#include <machine/bus.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <dev/mmc/bridge.h>
+#include <dev/mmc/mmcreg.h>
+#include <dev/mmc/mmcbrvar.h>
+#include <dev/sdhci/sdhci.h>
+#include <rtems/bsd/local/sdhci_if.h>
+#include "bcm2835_dma.h"
+#include <arm/broadcom/bcm2835/bcm2835_mbox_prop.h>
+#include "bcm2835_vcbus.h"
+#define	BCM2835_DEFAULT_SDHCI_FREQ	50
+#define	BCM_SDHCI_BUFFER_SIZE		512
+#define	NUM_DMA_SEGS			2
+#ifdef DEBUG
+#define dprintf(fmt, args...) do { printf("%s(): ", __func__);   \
+    printf(fmt,##args); } while (0)
+#else
+#endif
+static int bcm2835_sdhci_hs = 1;
+static int bcm2835_sdhci_pio_mode = 0;
+TUNABLE_INT("hw.bcm2835.sdhci.hs", &bcm2835_sdhci_hs);
+TUNABLE_INT("hw.bcm2835.sdhci.pio_mode", &bcm2835_sdhci_pio_mode);
+struct bcm_sdhci_softc {
+	device_t		sc_dev;
+	struct resource *	sc_mem_res;
+	struct resource *	sc_irq_res;
+	bus_space_tag_t		sc_bst;
+	bus_space_handle_t	sc_bsh;
+	void *			sc_intrhand;
+	struct mmc_request *	sc_req;
+	struct sdhci_slot	sc_slot;
+	int			sc_dma_ch;
+	bus_dma_tag_t		sc_dma_tag;
+	bus_dmamap_t		sc_dma_map;
+	vm_paddr_t		sc_sdhci_buffer_phys;
+	uint32_t		cmd_and_mode;
+	bus_addr_t		dmamap_seg_addrs[NUM_DMA_SEGS];
+	bus_size_t		dmamap_seg_sizes[NUM_DMA_SEGS];
+	int			dmamap_seg_count;
+	int			dmamap_seg_index;
+	int			dmamap_status;
+static int bcm_sdhci_probe(device_t);
+static int bcm_sdhci_attach(device_t);
+static int bcm_sdhci_detach(device_t);
+static void bcm_sdhci_intr(void *);
+static int bcm_sdhci_get_ro(device_t, device_t);
+static void bcm_sdhci_dma_intr(int ch, void *arg);
+static void
+bcm_sdhci_dmacb(void *arg, bus_dma_segment_t *segs, int nseg, int err)
+	struct bcm_sdhci_softc *sc = arg;
+	int i;
+	sc->dmamap_status = err;
+	sc->dmamap_seg_count = nseg;
+	/* Note nseg is guaranteed to be zero if err is non-zero. */
+	for (i = 0; i < nseg; i++) {
+		sc->dmamap_seg_addrs[i] = segs[i].ds_addr;
+		sc->dmamap_seg_sizes[i] = segs[i].ds_len;
+static int
+bcm_sdhci_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-sdhci"))
+		return (ENXIO);
+	device_set_desc(dev, "Broadcom 2708 SDHCI controller");
+	return (BUS_PROBE_DEFAULT);
+static int
+bcm_sdhci_attach(device_t dev)
+	struct bcm_sdhci_softc *sc = device_get_softc(dev);
+	int rid, err;
+	phandle_t node;
+	pcell_t cell;
+	u_int default_freq;
+	sc->sc_dev = dev;
+	sc->sc_req = NULL;
+	err = bcm2835_mbox_set_power_state(BCM2835_MBOX_POWER_ID_EMMC,
+	    TRUE);
+	if (err != 0) {
+		if (bootverbose)
+			device_printf(dev, "Unable to enable the power\n");
+		return (err);
+	default_freq = 0;
+	err = bcm2835_mbox_get_clock_rate(BCM2835_MBOX_CLOCK_ID_EMMC,
+	    &default_freq);
+	if (err == 0) {
+		/* Convert to MHz */
+		default_freq /= 1000000;
+	if (default_freq == 0) {
+		node = ofw_bus_get_node(sc->sc_dev);
+		if ((OF_getencprop(node, "clock-frequency", &cell,
+		    sizeof(cell))) > 0)
+			default_freq = cell / 1000000;
+		default_freq = BCM2835_DEFAULT_SDHCI_FREQ;
+	if (bootverbose)
+		device_printf(dev, "SDHCI frequency: %dMHz\n", default_freq);
+	rid = 0;
+	sc->sc_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+	    RF_ACTIVE);
+	if (!sc->sc_mem_res) {
+		device_printf(dev, "cannot allocate memory window\n");
+		err = ENXIO;
+		goto fail;
+	sc->sc_bst = rman_get_bustag(sc->sc_mem_res);
+	sc->sc_bsh = rman_get_bushandle(sc->sc_mem_res);
+	rid = 0;
+	sc->sc_irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
+	    RF_ACTIVE);
+	if (!sc->sc_irq_res) {
+		device_printf(dev, "cannot allocate interrupt\n");
+		err = ENXIO;
+		goto fail;
+	if (bus_setup_intr(dev, sc->sc_irq_res, INTR_TYPE_BIO | INTR_MPSAFE,
+	    NULL, bcm_sdhci_intr, sc, &sc->sc_intrhand)) {
+		device_printf(dev, "cannot setup interrupt handler\n");
+		err = ENXIO;
+		goto fail;
+	if (!bcm2835_sdhci_pio_mode)
+		sc->sc_slot.opt = SDHCI_PLATFORM_TRANSFER;
+	sc->sc_slot.caps = SDHCI_CAN_VDD_330 | SDHCI_CAN_VDD_180;
+	if (bcm2835_sdhci_hs)
+		sc->sc_slot.caps |= SDHCI_CAN_DO_HISPD;
+	sc->sc_slot.caps |= (default_freq << SDHCI_CLOCK_BASE_SHIFT);
+	sc->sc_slot.quirks = SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK
+		| SDHCI_QUIRK_BROKEN_TIMEOUT_VAL
+		| SDHCI_QUIRK_DONT_SET_HISPD_BIT
+		| SDHCI_QUIRK_MISSING_CAPS;
+	sdhci_init_slot(dev, &sc->sc_slot, 0);
+	sc->sc_dma_ch = bcm_dma_allocate(BCM_DMA_CH_ANY);
+	if (sc->sc_dma_ch == BCM_DMA_CH_INVALID)
+		goto fail;
+	bcm_dma_setup_intr(sc->sc_dma_ch, bcm_sdhci_dma_intr, sc);
+	/* Allocate bus_dma resources. */
+	err = bus_dma_tag_create(bus_get_dma_tag(dev),
+	    1, 0, BUS_SPACE_MAXADDR_32BIT,
+	    BUS_SPACE_MAXADDR, NULL, NULL,
+	    BCM_SDHCI_BUFFER_SIZE, NUM_DMA_SEGS, BCM_SDHCI_BUFFER_SIZE,
+	    BUS_DMA_ALLOCNOW, NULL, NULL,
+	    &sc->sc_dma_tag);
+	if (err) {
+		device_printf(dev, "failed allocate DMA tag");
+		goto fail;
+	err = bus_dmamap_create(sc->sc_dma_tag, 0, &sc->sc_dma_map);
+	if (err) {
+		device_printf(dev, "bus_dmamap_create failed\n");
+		goto fail;
+	sc->sc_sdhci_buffer_phys = BUS_SPACE_PHYSADDR(sc->sc_mem_res,
+	    SDHCI_BUFFER);
+	bus_generic_probe(dev);
+	bus_generic_attach(dev);
+	sdhci_start_slot(&sc->sc_slot);
+	return (0);
+fail:
+	if (sc->sc_intrhand)
+		bus_teardown_intr(dev, sc->sc_irq_res, sc->sc_intrhand);
+	if (sc->sc_irq_res)
+		bus_release_resource(dev, SYS_RES_IRQ, 0, sc->sc_irq_res);
+	if (sc->sc_mem_res)
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->sc_mem_res);
+	return (err);
+static int
+bcm_sdhci_detach(device_t dev)
+	return (EBUSY);
+static void
+bcm_sdhci_intr(void *arg)
+	sdhci_generic_intr(&sc->sc_slot);
+static int
+bcm_sdhci_get_ro(device_t bus, device_t child)
+	return (0);
+static inline uint32_t
+RD4(struct bcm_sdhci_softc *sc, bus_size_t off)
+	uint32_t val = bus_space_read_4(sc->sc_bst, sc->sc_bsh, off);
+	return val;
+static inline void
+WR4(struct bcm_sdhci_softc *sc, bus_size_t off, uint32_t val)
+	bus_space_write_4(sc->sc_bst, sc->sc_bsh, off, val);
+	 * The Arasan HC has a bug where it may lose the content of
+	 * consecutive writes to registers that are within two SD-card
+	 * clock cycles of each other (a clock domain crossing problem).
+	if (sc->sc_slot.clock > 0)
+		DELAY(((2 * 1000000) / sc->sc_slot.clock) + 1);
+static uint8_t
+bcm_sdhci_read_1(device_t dev, struct sdhci_slot *slot, bus_size_t off)
+	uint32_t val = RD4(sc, off & ~3);
+	return ((val >> (off & 3)*8) & 0xff);
+static uint16_t
+bcm_sdhci_read_2(device_t dev, struct sdhci_slot *slot, bus_size_t off)
+	 * Standard 32-bit handling of command and transfer mode.
+	if (off == SDHCI_TRANSFER_MODE) {
+		return (sc->cmd_and_mode >> 16);
+	} else if (off == SDHCI_COMMAND_FLAGS) {
+		return (sc->cmd_and_mode & 0x0000ffff);
+	return ((val >> (off & 3)*8) & 0xffff);
+static uint32_t
+bcm_sdhci_read_4(device_t dev, struct sdhci_slot *slot, bus_size_t off)
+	return RD4(sc, off);
+static void
+bcm_sdhci_read_multi_4(device_t dev, struct sdhci_slot *slot, bus_size_t off,
+    uint32_t *data, bus_size_t count)
+	bus_space_read_multi_4(sc->sc_bst, sc->sc_bsh, off, data, count);
+static void
+bcm_sdhci_write_1(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint8_t val)
+	uint32_t val32 = RD4(sc, off & ~3);
+	val32 &= ~(0xff << (off & 3)*8);
+	val32 |= (val << (off & 3)*8);
+	WR4(sc, off & ~3, val32);
+static void
+bcm_sdhci_write_2(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint16_t val)
+	uint32_t val32;
+	if (off == SDHCI_COMMAND_FLAGS)
+		val32 = sc->cmd_and_mode;
+	else
+		val32 = RD4(sc, off & ~3);
+	val32 &= ~(0xffff << (off & 3)*8);
+		sc->cmd_and_mode = val32;
+	else {
+static void
+bcm_sdhci_write_4(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint32_t val)
+	WR4(sc, off, val);
+static void
+bcm_sdhci_write_multi_4(device_t dev, struct sdhci_slot *slot, bus_size_t off,
+	bus_space_write_multi_4(sc->sc_bst, sc->sc_bsh, off, data, count);
+static void
+bcm_sdhci_start_dma_seg(struct bcm_sdhci_softc *sc)
+	struct sdhci_slot *slot;
+	vm_paddr_t pdst, psrc;
+	int err, idx, len, sync_op;
+	slot = &sc->sc_slot;
+	idx = sc->dmamap_seg_index++;
+	len = sc->dmamap_seg_sizes[idx];
+	slot->offset += len;
+	if (slot->curcmd->data->flags & MMC_DATA_READ) {
+		bcm_dma_setup_src(sc->sc_dma_ch, BCM_DMA_DREQ_EMMC,
+		    BCM_DMA_SAME_ADDR, BCM_DMA_32BIT);
+		bcm_dma_setup_dst(sc->sc_dma_ch, BCM_DMA_DREQ_NONE,
+		    BCM_DMA_INC_ADDR,
+		    (len & 0xf) ? BCM_DMA_32BIT : BCM_DMA_128BIT);
+		psrc = sc->sc_sdhci_buffer_phys;
+		pdst = sc->dmamap_seg_addrs[idx];
+		sync_op = BUS_DMASYNC_PREREAD;
+	} else {
+		bcm_dma_setup_src(sc->sc_dma_ch, BCM_DMA_DREQ_NONE,
+		    BCM_DMA_INC_ADDR,
+		bcm_dma_setup_dst(sc->sc_dma_ch, BCM_DMA_DREQ_EMMC,
+		psrc = sc->dmamap_seg_addrs[idx];
+		pdst = sc->sc_sdhci_buffer_phys;
+		sync_op = BUS_DMASYNC_PREWRITE;
+	 * When starting a new DMA operation do the busdma sync operation, and
+	 * disable SDCHI data interrrupts because we'll be driven by DMA
+	 * interrupts (or SDHCI error interrupts) until the IO is done.
+	if (idx == 0) {
+		bus_dmamap_sync(sc->sc_dma_tag, sc->sc_dma_map, sync_op);
+		slot->intmask &= ~(SDHCI_INT_DATA_AVAIL |
+		    SDHCI_INT_SPACE_AVAIL | SDHCI_INT_DATA_END);
+		bcm_sdhci_write_4(sc->sc_dev, &sc->sc_slot, SDHCI_SIGNAL_ENABLE,
+		    slot->intmask);
+	 * Start the DMA transfer.  Only programming errors (like failing to
+	 * allocate a channel) cause a non-zero return from bcm_dma_start().
+	err = bcm_dma_start(sc->sc_dma_ch, psrc, pdst, len);
+	KASSERT((err == 0), ("bcm2835_sdhci: failed DMA start"));
+static void
+bcm_sdhci_dma_intr(int ch, void *arg)
+	struct bcm_sdhci_softc *sc = (struct bcm_sdhci_softc *)arg;
+	struct sdhci_slot *slot = &sc->sc_slot;
+	uint32_t reg, mask;
+	int left, sync_op;
+	mtx_lock(&slot->mtx);
+	 * If there are more segments for the current dma, start the next one.
+	 * Otherwise unload the dma map and decide what to do next based on the
+	 * status of the sdhci controller and whether there's more data left.
+	if (sc->dmamap_seg_index < sc->dmamap_seg_count) {
+		bcm_sdhci_start_dma_seg(sc);
+		mtx_unlock(&slot->mtx);
+		return;
+		sync_op = BUS_DMASYNC_POSTREAD;
+		mask = SDHCI_INT_DATA_AVAIL;
+	} else {
+		sync_op = BUS_DMASYNC_POSTWRITE;
+		mask = SDHCI_INT_SPACE_AVAIL;
+	bus_dmamap_unload(sc->sc_dma_tag, sc->sc_dma_map);
+	sc->dmamap_seg_count = 0;
+	sc->dmamap_seg_index = 0;
+	left = min(BCM_SDHCI_BUFFER_SIZE,
+	    slot->curcmd->data->len - slot->offset);
+	/* DATA END? */
+	reg = bcm_sdhci_read_4(slot->bus, slot, SDHCI_INT_STATUS);
+	if (reg & SDHCI_INT_DATA_END) {
+		/* ACK for all outstanding interrupts */
+		bcm_sdhci_write_4(slot->bus, slot, SDHCI_INT_STATUS, reg);
+		/* enable INT */
+		slot->intmask |= SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL
+		    | SDHCI_INT_DATA_END;
+		bcm_sdhci_write_4(slot->bus, slot, SDHCI_SIGNAL_ENABLE,
+		    slot->intmask);
+		/* finish this data */
+		sdhci_finish_data(slot);
+	else {
+		/* already available? */
+		if (reg & mask) {
+			/* ACK for DATA_AVAIL or SPACE_AVAIL */
+			    SDHCI_INT_STATUS, mask);
+			/* continue next DMA transfer */
+			if (bus_dmamap_load(sc->sc_dma_tag, sc->sc_dma_map,
+			    (uint8_t *)slot->curcmd->data->data +
+			    slot->offset, left, bcm_sdhci_dmacb, sc,
+			    BUS_DMA_NOWAIT) != 0 || sc->dmamap_status != 0) {
+				slot->curcmd->error = MMC_ERR_NO_MEMORY;
+			} else {
+		} else {
+			/* wait for next data by INT */
+			/* enable INT */
+			    SDHCI_INT_SPACE_AVAIL | SDHCI_INT_DATA_END;
+			    slot->intmask);
+static void
+bcm_sdhci_read_dma(device_t dev, struct sdhci_slot *slot)
+	struct bcm_sdhci_softc *sc = device_get_softc(slot->bus);
+	size_t left;
+	if (sc->dmamap_seg_count != 0) {
+		device_printf(sc->sc_dev, "DMA in use\n");
+		return;
+	KASSERT((left & 3) == 0,
+	    ("%s: len = %d, not word-aligned", __func__, left));
+	    (uint8_t *)slot->curcmd->data->data + slot->offset, left,
+	    bcm_sdhci_dmacb, sc, BUS_DMA_NOWAIT) != 0 ||
+	    sc->dmamap_status != 0) {
+		return;
+	/* DMA start */
+static void
+bcm_sdhci_write_dma(device_t dev, struct sdhci_slot *slot)
+	size_t left;
+		return;
+		return;
+	/* DMA start */
+static int
+bcm_sdhci_will_handle_transfer(device_t dev, struct sdhci_slot *slot)
+	size_t left;
+	 * Do not use DMA for transfers less than block size or with a length
+	 * that is not a multiple of four.
+	left = min(BCM_DMA_BLOCK_SIZE,
+	if (left < BCM_DMA_BLOCK_SIZE)
+		return (0);
+	if (left & 0x03)
+		return (0);
+	return (1);
+static void
+bcm_sdhci_start_transfer(device_t dev, struct sdhci_slot *slot,
+    uint32_t *intmask)
+	/* DMA transfer FIFO 1KB */
+		bcm_sdhci_read_dma(dev, slot);
+	else
+		bcm_sdhci_write_dma(dev, slot);
+static void
+bcm_sdhci_finish_transfer(device_t dev, struct sdhci_slot *slot)
+static device_method_t bcm_sdhci_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		bcm_sdhci_probe),
+	DEVMETHOD(device_attach,	bcm_sdhci_attach),
+	DEVMETHOD(device_detach,	bcm_sdhci_detach),
+	/* Bus interface */
+	DEVMETHOD(bus_read_ivar,	sdhci_generic_read_ivar),
+	DEVMETHOD(bus_write_ivar,	sdhci_generic_write_ivar),
+	DEVMETHOD(bus_print_child,	bus_generic_print_child),
+	/* MMC bridge interface */
+	DEVMETHOD(mmcbr_update_ios,	sdhci_generic_update_ios),
+	DEVMETHOD(mmcbr_request,	sdhci_generic_request),
+	DEVMETHOD(mmcbr_get_ro,		bcm_sdhci_get_ro),
+	DEVMETHOD(mmcbr_acquire_host,	sdhci_generic_acquire_host),
+	DEVMETHOD(mmcbr_release_host,	sdhci_generic_release_host),
+	/* Platform transfer methods */
+	DEVMETHOD(sdhci_platform_will_handle,		bcm_sdhci_will_handle_transfer),
+	DEVMETHOD(sdhci_platform_start_transfer,	bcm_sdhci_start_transfer),
+	DEVMETHOD(sdhci_platform_finish_transfer,	bcm_sdhci_finish_transfer),
+	/* SDHCI registers accessors */
+	DEVMETHOD(sdhci_read_1,		bcm_sdhci_read_1),
+	DEVMETHOD(sdhci_read_2,		bcm_sdhci_read_2),
+	DEVMETHOD(sdhci_read_4,		bcm_sdhci_read_4),
+	DEVMETHOD(sdhci_read_multi_4,	bcm_sdhci_read_multi_4),
+	DEVMETHOD(sdhci_write_1,	bcm_sdhci_write_1),
+	DEVMETHOD(sdhci_write_2,	bcm_sdhci_write_2),
+	DEVMETHOD(sdhci_write_4,	bcm_sdhci_write_4),
+	DEVMETHOD(sdhci_write_multi_4,	bcm_sdhci_write_multi_4),
+	{ 0, 0 }
+static devclass_t bcm_sdhci_devclass;
+static driver_t bcm_sdhci_driver = {
+	"sdhci_bcm",
+	bcm_sdhci_methods,
+	sizeof(struct bcm_sdhci_softc),
+DRIVER_MODULE(sdhci_bcm, simplebus, bcm_sdhci_driver, bcm_sdhci_devclass, 0, 0);
+MODULE_DEPEND(sdhci_bcm, sdhci, 1, 1, 1);
+DRIVER_MODULE(mmc, sdhci_bcm, mmc_driver, mmc_devclass, NULL, NULL);
+MODULE_DEPEND(sdhci_bcm, mmc, 1, 1, 1);
diff --git a/libbsd.py b/libbsd.py
index 7be2044..4adf77d 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -56,6 +56,7 @@ def rtems(mm):
             'local/usb_if.c',
             'local/mmcbus_if.c',
             'local/mmcbr_if.c',
+            'local/sdhci_if.c',
             'rtems/ipsec_get_policylen.c',
             'rtems/rtems-bsd-arp-processor.c',
             'rtems/rtems-bsd-allocator-domain-size.c',
@@ -385,6 +386,7 @@ def mmc(mm):
         [ 'arm' ],
             'sys/arm/broadcom/bcm2835/bcm2835_dma.c',
+            'sys/arm/broadcom/bcm2835/bcm2835_sdhci.c',
     mm.generator['source']()
diff --git a/libbsd.txt b/libbsd.txt
index da0a92a..ee2b64f 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -780,6 +780,7 @@ detail and debug level information from the command.
 . sys/dev/mmc/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
 . sys/dev/usb/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
 . sys/dev/sdhci/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
+. sys/arm/broadcom/bcm2835/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
 . *, stable/9, 2015-04-08, 99a648a912e81e29d9c4c159cbbe263462f2d719
 == How to import code from FreeBSD
diff --git a/libbsd_waf.py b/libbsd_waf.py
index eff7bf8..63cf7d2 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -1143,6 +1143,7 @@ def build(bld):
               'rtemsbsd/telnetd/telnetd.c']
     if bld.get_env()["RTEMS_ARCH"] == "arm":
         source += ['freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c',
+                   'freebsd/sys/arm/broadcom/bcm2835/bcm2835_sdhci.c',
                    'freebsd/sys/mips/mips/in_cksum.c']
     if bld.get_env()["RTEMS_ARCH"] == "avr":
         source += ['freebsd/sys/mips/mips/in_cksum.c']
diff --git a/rtemsbsd/include/rtems/bsd/local/sdhci_if.h b/rtemsbsd/include/rtems/bsd/local/sdhci_if.h
index 0000000..4a96f2a
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/sdhci_if.h
@@ -0,0 +1,150 @@
+ * This file is produced automatically.
+ * Do not modify anything in here by hand.
+ * Created from source file
+ *   sdhci/sdhci_if.m
+ * with
+ *   makeobjops.awk
+ * See the source file for legal information
+#ifndef _sdhci_if_h_
+#define _sdhci_if_h_
+extern struct kobjop_desc sdhci_read_1_desc;
+typedef uint8_t sdhci_read_1_t(device_t brdev, struct sdhci_slot *slot,
+                               bus_size_t off);
+static __inline uint8_t SDHCI_READ_1(device_t brdev, struct sdhci_slot *slot,
+                     bus_size_t off)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_1);
+	return ((sdhci_read_1_t *) _m)(brdev, slot, off);
+extern struct kobjop_desc sdhci_read_2_desc;
+typedef uint16_t sdhci_read_2_t(device_t brdev, struct sdhci_slot *slot,
+                                bus_size_t off);
+static __inline uint16_t SDHCI_READ_2(device_t brdev, struct sdhci_slot *slot,
+                      bus_size_t off)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_2);
+	return ((sdhci_read_2_t *) _m)(brdev, slot, off);
+extern struct kobjop_desc sdhci_read_4_desc;
+typedef uint32_t sdhci_read_4_t(device_t brdev, struct sdhci_slot *slot,
+                                bus_size_t off);
+static __inline uint32_t SDHCI_READ_4(device_t brdev, struct sdhci_slot *slot,
+                      bus_size_t off)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_4);
+	return ((sdhci_read_4_t *) _m)(brdev, slot, off);
+extern struct kobjop_desc sdhci_read_multi_4_desc;
+typedef void sdhci_read_multi_4_t(device_t brdev, struct sdhci_slot *slot,
+                                  bus_size_t off, uint32_t *data,
+                                  bus_size_t count);
+static __inline void SDHCI_READ_MULTI_4(device_t brdev, struct sdhci_slot *slot,
+                        bus_size_t off, uint32_t *data, bus_size_t count)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_read_multi_4);
+	((sdhci_read_multi_4_t *) _m)(brdev, slot, off, data, count);
+extern struct kobjop_desc sdhci_write_1_desc;
+typedef void sdhci_write_1_t(device_t brdev, struct sdhci_slot *slot,
+                             bus_size_t off, uint8_t val);
+static __inline void SDHCI_WRITE_1(device_t brdev, struct sdhci_slot *slot,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_1);
+	((sdhci_write_1_t *) _m)(brdev, slot, off, val);
+extern struct kobjop_desc sdhci_write_2_desc;
+typedef void sdhci_write_2_t(device_t brdev, struct sdhci_slot *slot,
+                             bus_size_t off, uint16_t val);
+static __inline void SDHCI_WRITE_2(device_t brdev, struct sdhci_slot *slot,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_2);
+	((sdhci_write_2_t *) _m)(brdev, slot, off, val);
+extern struct kobjop_desc sdhci_write_4_desc;
+typedef void sdhci_write_4_t(device_t brdev, struct sdhci_slot *slot,
+                             bus_size_t off, uint32_t val);
+static __inline void SDHCI_WRITE_4(device_t brdev, struct sdhci_slot *slot,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_4);
+	((sdhci_write_4_t *) _m)(brdev, slot, off, val);
+extern struct kobjop_desc sdhci_write_multi_4_desc;
+typedef void sdhci_write_multi_4_t(device_t brdev, struct sdhci_slot *slot,
+static __inline void SDHCI_WRITE_MULTI_4(device_t brdev,
+                         struct sdhci_slot *slot, bus_size_t off,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_write_multi_4);
+	((sdhci_write_multi_4_t *) _m)(brdev, slot, off, data, count);
+extern struct kobjop_desc sdhci_platform_will_handle_desc;
+typedef int sdhci_platform_will_handle_t(device_t brdev,
+                                         struct sdhci_slot *slot);
+static __inline int SDHCI_PLATFORM_WILL_HANDLE(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_platform_will_handle);
+	return ((sdhci_platform_will_handle_t *) _m)(brdev, slot);
+extern struct kobjop_desc sdhci_platform_start_transfer_desc;
+typedef void sdhci_platform_start_transfer_t(device_t brdev,
+                                             uint32_t *intmask);
+static __inline void SDHCI_PLATFORM_START_TRANSFER(device_t brdev,
+                                   struct sdhci_slot *slot, uint32_t *intmask)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_platform_start_transfer);
+	((sdhci_platform_start_transfer_t *) _m)(brdev, slot, intmask);
+extern struct kobjop_desc sdhci_platform_finish_transfer_desc;
+typedef void sdhci_platform_finish_transfer_t(device_t brdev,
+static __inline void SDHCI_PLATFORM_FINISH_TRANSFER(device_t brdev,
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_platform_finish_transfer);
+	((sdhci_platform_finish_transfer_t *) _m)(brdev, slot);
+extern struct kobjop_desc sdhci_min_freq_desc;
+typedef uint32_t sdhci_min_freq_t(device_t brdev, struct sdhci_slot *slot);
+static __inline uint32_t SDHCI_MIN_FREQ(device_t brdev, struct sdhci_slot *slot)
+	kobjop_t _m;
+	KOBJOPLOOKUP(((kobj_t)brdev)->ops,sdhci_min_freq);
+	return ((sdhci_min_freq_t *) _m)(brdev, slot);
+#endif /* _sdhci_if_h_ */
\ No newline at end of file
diff --git a/rtemsbsd/local/sdhci_if.c b/rtemsbsd/local/sdhci_if.c
index 0000000..9495fc4
--- /dev/null
+++ b/rtemsbsd/local/sdhci_if.c
@@ -0,0 +1,80 @@
+ *   /sdhci/sdhci_if.m
+ * with
+ *   makeobjops.awk
+#include <sys/queue.h>
+#include <sys/kobj.h>
+#include <sys/types.h>
+struct sdhci_slot;
+struct kobjop_desc sdhci_read_1_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_read_2_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_read_4_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_read_multi_4_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_write_1_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_write_2_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_write_4_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_write_multi_4_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_platform_will_handle_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_platform_start_transfer_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_platform_finish_transfer_desc = {
+	0, (kobjop_t) 0
+struct kobjop_desc sdhci_min_freq_desc = {
+	0, (kobjop_t) sdhci_generic_min_freq
2.1.4
