[PATCH] arm/xilinx_zynq: Start the second core when an SMP build.
Chris Johns
chrisj at rtems.org
Wed Aug 31 03:50:54 UTC 2016
c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c | 15 +++++++++++++++
c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c | 7 +++++++
2 files changed, 22 insertions(+)
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c
index 3940352..310014d 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c
@@ -14,9 +14,24 @@
#include <rtems/score/smpimpl.h>
+extern void _start(void);
bool _CPU_SMP_Start_processor(uint32_t cpu_index)
+ * Enable the second CPU.
+ if (cpu_index != 0) {
+ volatile uint32_t* const kick_address = (uint32_t*) 0xfffffff0UL;
+ _ARM_Data_synchronization_barrier();
+ _ARM_Instruction_synchronization_barrier();
+ *kick_address = (uint32_t) _start;
+ _ARM_Send_event();
* Wait for secondary processor to complete its basic initialization so that
* we can enable the unified L2 cache.
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c
index c7a1089..e0a7743 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c
@@ -22,6 +22,13 @@
BSP_START_DATA_SECTION static const arm_cp15_start_section_config
zynq_mmu_config_table[] = {
ARMV7_CP15_START_DEFAULT_SECTIONS,
+#if defined(RTEMS_SMP)
+ .begin = 0xffff0000U,
+ .end = 0xffffffffU,
+ .flags = ARMV7_MMU_DEVICE
+#endif
.begin = 0xe0000000U,
.end = 0xe0200000U,
2.3.0
