[PATCH v3 1/7] Imported files for driver: bcm283x_dwcotg
Deval Shah
deval.maker at gmail.com
Wed Aug 31 08:59:47 UTC 2016
freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c | 100 ++++++++++
freebsd/sys/dev/usb/controller/dwc_otg_fdt.c | 222 +++++++++++++++++++++
freebsd/sys/dev/usb/controller/dwc_otg_fdt.h | 39 ++++
libbsd.py | 3 +
libbsd.txt | 2 +
libbsd_waf.py | 4 +-
6 files changed, 369 insertions(+), 1 deletion(-)
create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c b/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
new file mode 100644
index 0000000..1ab4d08
--- /dev/null
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
@@ -0,0 +1,100 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright 2015 Andrew Turner.
+ * All rights reserved.
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/kernel.h>
+#include <sys/bus.h>
+#include <sys/callout.h>
+#include <sys/condvar.h>
+#include <sys/module.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <dev/usb/usb.h>
+#include <dev/usb/usbdi.h>
+#include <dev/usb/usb_busdma.h>
+#include <dev/usb/usb_process.h>
+#include <dev/usb/usb_controller.h>
+#include <dev/usb/usb_bus.h>
+#include <dev/usb/controller/dwc_otg.h>
+#include <dev/usb/controller/dwc_otg_fdt.h>
+#include <arm/broadcom/bcm2835/bcm2835_mbox_prop.h>
+static device_probe_t bcm283x_dwc_otg_probe;
+static device_attach_t bcm283x_dwc_otg_attach;
+static int
+bcm283x_dwc_otg_probe(device_t dev)
+ if (!ofw_bus_status_okay(dev))
+ return (ENXIO);
+ if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-usb"))
+ return (ENXIO);
+ device_set_desc(dev, "DWC OTG 2.0 integrated USB controller (bcm283x)");
+ return (BUS_PROBE_VENDOR);
+static int
+bcm283x_dwc_otg_attach(device_t dev)
+ int err;
+ err = bcm2835_mbox_set_power_state(BCM2835_MBOX_POWER_ID_USB_HCD, TRUE);
+ if (err)
+ device_printf(dev, "failed to set power state, err=%d\n", err);
+ return (dwc_otg_attach(dev));
+static device_method_t bcm283x_dwc_otg_methods[] = {
+ /* bus interface */
+ DEVMETHOD(device_probe, bcm283x_dwc_otg_probe),
+ DEVMETHOD(device_attach, bcm283x_dwc_otg_attach),
+ DEVMETHOD_END
+static devclass_t bcm283x_dwc_otg_devclass;
+DEFINE_CLASS_1(bcm283x_dwcotg, bcm283x_dwc_otg_driver, bcm283x_dwc_otg_methods,
+ sizeof(struct dwc_otg_fdt_softc), dwc_otg_driver);
+DRIVER_MODULE(bcm283x_dwcotg, simplebus, bcm283x_dwc_otg_driver,
+ bcm283x_dwc_otg_devclass, 0, 0);
+MODULE_DEPEND(bcm283x_dwcotg, usb, 1, 1, 1);
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
index 0000000..2b7a715
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
@@ -0,0 +1,222 @@
+ * Copyright (c) 2012 Hans Petter Selasky. All rights reserved.
+ * are met:
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/systm.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/malloc.h>
+#include <sys/mutex.h>
+#include <sys/rman.h>
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/usb/usb_core.h>
+#include <dev/usb/usb_util.h>
+static device_probe_t dwc_otg_probe;
+static device_detach_t dwc_otg_detach;
+static int
+dwc_otg_probe(device_t dev)
+ return (ENXIO);
+ if (!ofw_bus_is_compatible(dev, "synopsys,designware-hs-otg2"))
+ return (ENXIO);
+ device_set_desc(dev, "DWC OTG 2.0 integrated USB controller");
+ return (BUS_PROBE_DEFAULT);
+int
+dwc_otg_attach(device_t dev)
+ struct dwc_otg_fdt_softc *sc = device_get_softc(dev);
+ char usb_mode[24];
+ int err;
+ int rid;
+ /* initialise some bus fields */
+ sc->sc_otg.sc_bus.parent = dev;
+ sc->sc_otg.sc_bus.devices = sc->sc_otg.sc_devices;
+ sc->sc_otg.sc_bus.devices_max = DWC_OTG_MAX_DEVICES;
+ sc->sc_otg.sc_bus.dma_bits = 32;
+ /* get USB mode, if any */
+ if (OF_getprop(ofw_bus_get_node(dev), "dr_mode",
+ &usb_mode, sizeof(usb_mode)) > 0) {
+ /* ensure proper zero termination */
+ usb_mode[sizeof(usb_mode) - 1] = 0;
+ if (strcasecmp(usb_mode, "host") == 0)
+ sc->sc_otg.sc_mode = DWC_MODE_HOST;
+ else if (strcasecmp(usb_mode, "peripheral") == 0)
+ sc->sc_otg.sc_mode = DWC_MODE_DEVICE;
+ else if (strcasecmp(usb_mode, "otg") != 0) {
+ device_printf(dev, "Invalid FDT dr_mode: %s\n",
+ usb_mode);
+ /* get all DMA memory */
+ if (usb_bus_mem_alloc_all(&sc->sc_otg.sc_bus,
+ USB_GET_DMA_TAG(dev), NULL)) {
+ return (ENOMEM);
+ rid = 0;
+ sc->sc_otg.sc_io_res =
+ bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid, RF_ACTIVE);
+ if (!(sc->sc_otg.sc_io_res)) {
+ err = ENOMEM;
+ goto error;
+ sc->sc_otg.sc_io_tag = rman_get_bustag(sc->sc_otg.sc_io_res);
+ sc->sc_otg.sc_io_hdl = rman_get_bushandle(sc->sc_otg.sc_io_res);
+ sc->sc_otg.sc_io_size = rman_get_size(sc->sc_otg.sc_io_res);
+ rid = 0;
+ sc->sc_otg.sc_irq_res =
+ bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid, RF_ACTIVE);
+ if (sc->sc_otg.sc_irq_res == NULL)
+ goto error;
+ sc->sc_otg.sc_bus.bdev = device_add_child(dev, "usbus", -1);
+ if (sc->sc_otg.sc_bus.bdev == NULL)
+ goto error;
+ device_set_ivars(sc->sc_otg.sc_bus.bdev, &sc->sc_otg.sc_bus);
+ err = bus_setup_intr(dev, sc->sc_otg.sc_irq_res, INTR_TYPE_TTY | INTR_MPSAFE,
+ &dwc_otg_filter_interrupt, &dwc_otg_interrupt, sc, &sc->sc_otg.sc_intr_hdl);
+ if (err) {
+ sc->sc_otg.sc_intr_hdl = NULL;
+ goto error;
+ err = dwc_otg_init(&sc->sc_otg);
+ if (err == 0) {
+ err = device_probe_and_attach(sc->sc_otg.sc_bus.bdev);
+ if (err)
+ goto error;
+ return (0);
+error:
+ dwc_otg_detach(dev);
+ return (ENXIO);
+static int
+dwc_otg_detach(device_t dev)
+ device_t bdev;
+ int err;
+ if (sc->sc_otg.sc_bus.bdev) {
+ bdev = sc->sc_otg.sc_bus.bdev;
+ device_detach(bdev);
+ device_delete_child(dev, bdev);
+ /* during module unload there are lots of children leftover */
+ device_delete_children(dev);
+ if (sc->sc_otg.sc_irq_res && sc->sc_otg.sc_intr_hdl) {
+ * only call dwc_otg_uninit() after dwc_otg_init()
+ dwc_otg_uninit(&sc->sc_otg);
+ err = bus_teardown_intr(dev, sc->sc_otg.sc_irq_res,
+ sc->sc_otg.sc_intr_hdl);
+ /* free IRQ channel, if any */
+ if (sc->sc_otg.sc_irq_res) {
+ bus_release_resource(dev, SYS_RES_IRQ, 0,
+ sc->sc_otg.sc_irq_res);
+ sc->sc_otg.sc_irq_res = NULL;
+ /* free memory resource, if any */
+ if (sc->sc_otg.sc_io_res) {
+ bus_release_resource(dev, SYS_RES_MEMORY, 0,
+ sc->sc_otg.sc_io_res);
+ sc->sc_otg.sc_io_res = NULL;
+ usb_bus_mem_free_all(&sc->sc_otg.sc_bus, NULL);
+ return (0);
+static device_method_t dwc_otg_methods[] = {
+ /* Device interface */
+ DEVMETHOD(device_probe, dwc_otg_probe),
+ DEVMETHOD(device_attach, dwc_otg_attach),
+ DEVMETHOD(device_detach, dwc_otg_detach),
+ DEVMETHOD(device_suspend, bus_generic_suspend),
+ DEVMETHOD(device_resume, bus_generic_resume),
+ DEVMETHOD(device_shutdown, bus_generic_shutdown),
+ DEVMETHOD_END
+driver_t dwc_otg_driver = {
+ .name = "dwcotg",
+ .methods = dwc_otg_methods,
+ .size = sizeof(struct dwc_otg_fdt_softc),
+static devclass_t dwc_otg_devclass;
+DRIVER_MODULE(dwcotg, simplebus, dwc_otg_driver, dwc_otg_devclass, 0, 0);
+MODULE_DEPEND(dwcotg, usb, 1, 1, 1);
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg_fdt.h b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
index 0000000..9e01118
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
@@ -0,0 +1,39 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DWC_OTG_FDT_H_
+#define _DWC_OTG_FDT_H_
+struct dwc_otg_fdt_softc {
+ struct dwc_otg_softc sc_otg; /* must be first */
+extern driver_t dwc_otg_driver;
+device_attach_t dwc_otg_attach;
+#endif
diff --git a/libbsd.py b/libbsd.py
index 73f5a67..e1e0005 100755
--- a/libbsd.py
+++ b/libbsd.py
@@ -433,6 +433,7 @@ def dev_usb(mm):
'sys/dev/usb/usb_request.c',
'sys/dev/usb/usb_transfer.c',
'sys/dev/usb/usb_util.c',
+ 'sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c',
mm.generator['source']()
@@ -493,6 +494,7 @@ def dev_usb_controller(mm):
'sys/dev/usb/controller/xhcireg.h',
'sys/dev/usb/controller/dwc_otg.h',
'sys/dev/usb/controller/dwc_otgreg.h',
+ 'sys/dev/usb/controller/dwc_otg_fdt.h',
mod.addKernelSpaceSourceFiles(
@@ -501,6 +503,7 @@ def dev_usb_controller(mm):
'sys/dev/usb/controller/ehci.c',
'sys/dev/usb/controller/usb_controller.c',
'sys/dev/usb/controller/dwc_otg.c',
+ 'sys/dev/usb/controller/dwc_otg_fdt.c',
diff --git a/libbsd.txt b/libbsd.txt
index f4b0746..d18f77b 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -738,6 +738,8 @@ detail and debug level information from the command.
. sys/dev/dwc/*, trunk, 2015-03-26, cfc3df2b8f708ce8494d9d556e3472a5c8c21b8a
. sys/dev/usb/*, trunk, 2015-10-30, 968dafb4fcf133cb8beb6fa3c558fecd7dc00ef0
. *, stable/9, 2015-04-08, 99a648a912e81e29d9c4c159cbbe263462f2d719
+. sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c, trunk, 2016-05-26, a7019c8505c0592f2e80ac63be139075d8977c4e
+. sys/dev/usb/controller/dwc_otg_fdt.*, trunk, 2016-05-26, a7019c8505c0592f2e80ac63be139075d8977c4e
== How to import code from FreeBSD
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 524b8bc..8c59ef9 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -693,7 +693,8 @@ def build(bld):
source = objs06_source)
libbsd_use += ["objs06"]
- source = ['freebsd/sys/arm/xilinx/zy7_slcr.c',
+ source = ['freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c',
+ 'freebsd/sys/arm/xilinx/zy7_slcr.c',
'freebsd/sys/cam/cam.c',
'freebsd/sys/cam/scsi/scsi_all.c',
'freebsd/sys/contrib/altq/altq/altq_cbq.c',
@@ -780,6 +781,7 @@ def build(bld):
'freebsd/sys/dev/smc/if_smc.c',
'freebsd/sys/dev/tsec/if_tsec.c',
'freebsd/sys/dev/usb/controller/dwc_otg.c',
+ 'freebsd/sys/dev/usb/controller/dwc_otg_fdt.c',
'freebsd/sys/dev/usb/controller/ehci.c',
'freebsd/sys/dev/usb/controller/ohci.c',
'freebsd/sys/dev/usb/controller/usb_controller.c',
2.7.4
