[PATCH v3 2/7] Ported driver bcm283x_dwcotg to RTEMS.
Deval Shah deval.maker at gmail.com
Wed Aug 31 08:59:48 UTC 2016
 freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c | 24 +++++++++++++++++
 freebsd/sys/dev/usb/controller/dwc_otg_fdt.c       | 10 ++++++++
 libbsd.txt                                         | 30 ++++++++++++++++++++++
 rtemsbsd/include/machine/rtems-bsd-nexus-bus.h     | 22 ++++++++++++++++
 rtemsbsd/include/machine/rtems-bsd-sysinit.h       |  3 +++
 testsuite/usb01/usb-sysinit.h                      |  4 +++
 6 files changed, 93 insertions(+)
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c b/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
index 1ab4d08..de73b57 100644
--- a/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
@@ -37,7 +37,9 @@ __FBSDID("$FreeBSD$");
 #include <sys/condvar.h>
 #include <sys/module.h>
+#ifndef __rtems__
 #include <dev/ofw/ofw_bus_subr.h>
+#endif
 #include <dev/usb/usb.h>
 #include <dev/usb/usbdi.h>
@@ -51,7 +53,12 @@ __FBSDID("$FreeBSD$");
 #include <dev/usb/controller/dwc_otg.h>
 #include <dev/usb/controller/dwc_otg_fdt.h>
+#ifndef __rtems__
 #include <arm/broadcom/bcm2835/bcm2835_mbox_prop.h>
+#else /* __rtems__ */
+#include <bsp/mailbox.h>
+#include <bsp/vc.h>
+#endif /* __rtems__ */
 static device_probe_t bcm283x_dwc_otg_probe;
 static device_attach_t bcm283x_dwc_otg_attach;
@@ -60,11 +67,13 @@ static int
 bcm283x_dwc_otg_probe(device_t dev)
+#ifndef __rtems__
 	if (!ofw_bus_status_okay(dev))
 		return (ENXIO);
 	if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-usb"))
 		return (ENXIO);
 	device_set_desc(dev, "DWC OTG 2.0 integrated USB controller (bcm283x)");
@@ -76,9 +85,19 @@ bcm283x_dwc_otg_attach(device_t dev)
 	int err;
+#ifndef __rtems__
 	err = bcm2835_mbox_set_power_state(BCM2835_MBOX_POWER_ID_USB_HCD, TRUE);
 	if (err)
 		device_printf(dev, "failed to set power state, err=%d\n", err);
+	bcm2835_set_power_state_entries power_state_usb;
+	power_state_usb.dev_id = bcm2835_mailbox_power_udid_usb_hcd;
+	power_state_usb.state = BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON;
+	err = bcm2835_mailbox_set_power_state(&power_state_usb);
+	if (err)
+		device_printf(dev, "failed to set power state, err=%d\n", err);
 	return (dwc_otg_attach(dev));
@@ -95,6 +114,11 @@ static devclass_t bcm283x_dwc_otg_devclass;
 DEFINE_CLASS_1(bcm283x_dwcotg, bcm283x_dwc_otg_driver, bcm283x_dwc_otg_methods,
     sizeof(struct dwc_otg_fdt_softc), dwc_otg_driver);
+#ifndef __rtems__
 DRIVER_MODULE(bcm283x_dwcotg, simplebus, bcm283x_dwc_otg_driver,
     bcm283x_dwc_otg_devclass, 0, 0);
+DRIVER_MODULE(bcm283x_dwcotg, nexus, bcm283x_dwc_otg_driver,
+	bcm283x_dwc_otg_devclass, 0, 0);
 MODULE_DEPEND(bcm283x_dwcotg, usb, 1, 1, 1);
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
index 2b7a715..81d5078 100644
--- a/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
+++ b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
@@ -39,9 +39,11 @@ __FBSDID("$FreeBSD$");
 #include <sys/mutex.h>
 #include <sys/rman.h>
+#ifndef __rtems__
 #include <dev/ofw/openfirm.h>
 #include <dev/ofw/ofw_bus.h>
@@ -64,11 +66,13 @@ static int
+#ifndef __rtems__
 		return (ENXIO);
 	if (!ofw_bus_is_compatible(dev, "synopsys,designware-hs-otg2"))
 		return (ENXIO);
 	device_set_desc(dev, "DWC OTG 2.0 integrated USB controller");
@@ -89,6 +93,7 @@ dwc_otg_attach(device_t dev)
 	sc->sc_otg.sc_bus.devices_max = DWC_OTG_MAX_DEVICES;
 	sc->sc_otg.sc_bus.dma_bits = 32;
+#ifndef __rtems__
 	/* get USB mode, if any */
 	if (OF_getprop(ofw_bus_get_node(dev), "dr_mode",
 	    &usb_mode, sizeof(usb_mode)) > 0) {
@@ -105,6 +110,7 @@ dwc_otg_attach(device_t dev)
 			    usb_mode);
 	/* get all DMA memory */
 	if (usb_bus_mem_alloc_all(&sc->sc_otg.sc_bus,
@@ -218,5 +224,9 @@ driver_t dwc_otg_driver = {
 static devclass_t dwc_otg_devclass;
+#ifndef __rtems__
 DRIVER_MODULE(dwcotg, simplebus, dwc_otg_driver, dwc_otg_devclass, 0, 0);
+DRIVER_MODULE(dwcotg, nexus, dwc_otg_driver, dwc_otg_devclass, 0, 0);
 MODULE_DEPEND(dwcotg, usb, 1, 1, 1);
diff --git a/libbsd.txt b/libbsd.txt
index d18f77b..80566e1 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -625,6 +625,36 @@ include a `__rtems__` in the guards to make searches easy, so use
 * `#else /* __rtems__ */`, and
 * `#endif /* __rtems__ */`.
+The guards must start at the begin of the line.  Examples for wrong guards:
+static void
+guards_must_start_at_the_begin_of_the_line(int j)
+	#ifdef __rtems__
+	return (j + 1);
+	#else /* __rtems__ */
+	return (j + 2);
+	#endif /* __rtems__ */
+static void
+missing_rtems_comments_in_the_guards(int j)
+#ifdef __rtems__
+	return (j + 3);
+#else
+	return (j + 4);
+#endif
+Do not disable option header includes via guards.  Instead, add an empty option
+header, e.g. `rtemsbsd/include/rtems/bsd/local/opt_xyz.h`.  In general, provide
+empty header files and do not guard includes.
 For new code use
 http://www.freebsd.org/cgi/man.cgi?query=style&apropos=0&sektion=9&manpath=FreeBSD+9.2-RELEASE&arch=default&format=html[STYLE(9)].
 Do not format original FreeBSD code.
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index 5a3458c..467ea7b 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -46,6 +46,7 @@
  *   RTEMS_BSD_DRIVER_DWCOTG0
  *   RTEMS_BSD_DRIVER_DWCOTG0_BASE_ADDR
  *    RTEMS_BSD_DRIVER_DWCOTG0_IRQ
+ *   RTEMS_BSD_DRIVER_BCM283X_DWCOTG
  *   RTEMS_BSD_DRIVER_DWC_MMC
  *   RTEMS_BSD_DRIVER_MMC
  *   RTEMS_BSD_DRIVER_USB
@@ -155,6 +156,27 @@ extern "C" {
 #endif /* RTEMS_BSD_DRIVER_DWCOTG0 */
+ * RaspberryPi OTG USB Controller.
+#if !defined(RTEMS_BSD_DRIVER_BCM283X_DWCOTG)
+  #define RTEMS_BSD_DRIVER_BCM283X_DWCOTG(_base, _irq)                  \
+    static const rtems_bsd_device_resource bcm283x_dwcotg_res[] = {     \
+        .type = RTEMS_BSD_RES_MEMORY,                                   \
+        .start_request = 0,                                             \
+        .start_actual = (_base)                                         \
+        .type = RTEMS_BSD_RES_IRQ,                                      \
+        .start_actual = (_irq)                                          \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE(bcm283x_dwcotg, 0,                    \
+                                  RTEMS_ARRAY_SIZE(bcm283x_dwcotg_res), \
+                                  &bcm283x_dwcotg_res[0])
+#endif /* RTEMS_BSD_DRIVER_BCM283X_DWCOTG */
  * Designware/Synopsys MMC.
 #if !defined(RTEMS_BSD_DRIVER_DWC_MMC)
diff --git a/rtemsbsd/include/machine/rtems-bsd-sysinit.h b/rtemsbsd/include/machine/rtems-bsd-sysinit.h
index 2c892da..b72e564 100644
--- a/rtemsbsd/include/machine/rtems-bsd-sysinit.h
+++ b/rtemsbsd/include/machine/rtems-bsd-sysinit.h
@@ -55,6 +55,9 @@
 #define SYSINIT_NEED_USB_EHCI \
 	SYSINIT_DRIVER_REFERENCE(ehci, nexus); \
 	SYSINIT_DRIVER_REFERENCE(usbus, ehci)
+#define SYSINIT_NEED_USB_BCM283x_DWC_OTG \
+	SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
 #define SYSINIT_NEED_USB_MASS_STORAGE \
 	SYSINIT_DRIVER_REFERENCE(umass, uhub)
diff --git a/testsuite/usb01/usb-sysinit.h b/testsuite/usb01/usb-sysinit.h
index eca10ed..c22bcf2 100644
--- a/testsuite/usb01/usb-sysinit.h
+++ b/testsuite/usb01/usb-sysinit.h
@@ -39,6 +39,10 @@ SYSINIT_NEED_USB_CORE;
 #ifdef NEED_USB_EHCI
 	SYSINIT_NEED_USB_EHCI;
 #endif
+#ifdef NEED_USB_OTG
+	SYSINIT_NEED_USB_BCM283x_DWC_OTG;
+#endif
 SYSINIT_NEED_USB_MASS_STORAGE;
 #endif /* USB_SYSINIT_INIT */
2.7.4
