GCC build is broken due to invalid crt0.o selection
Sebastian Huber
Mon Dec 5 07:29:27 UTC 2016
Hello,
I noticed that the ARM libgomp is built without TLS support for RTEMS,
since the thread-local storage detection fails, due to missing symbols
in the crt0.o. I added the missing symbols to newlib/libc/sys/rtems/crt0.c:
https://sourceware.org/ml/newlib/2016/msg01138.html
However, this still didn't work. The reason is that during GCC build the
random crt0.o of the prefix is used. GCC searches in:
Breakpoint 10, file_at_path (path=0x72a960
"/build/git-build/b-gcc-git-arm-rtems4.12/./gcc/arm-rtems4.12/7.0.0/thumb/",
data=0x7fffffffc8c0) at /home/EB/sebastian_h/archive/gcc-git/gcc/gcc.c:2733
2733 {
$70 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
suffix_len = 0, mode = 4}
"/build/git-build/b-gcc-git-arm-rtems4.12/./gcc/thumb/",
2733 {
$71 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/build/git-build/b-gcc-git-arm-rtems4.12/arm-rtems4.12/thumb/newlib/arm-rtems4.12/7.0.0/thumb/",
2733 {
$72 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/build/git-build/b-gcc-git-arm-rtems4.12/arm-rtems4.12/thumb/newlib/thumb/",
2733 {
$73 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/bin/arm-rtems4.12/7.0.0/thumb/",
2733 {
$74 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/bin/thumb/", data=0x7fffffffc8c0) at
2733 {
$75 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/lib/arm-rtems4.12/7.0.0/thumb/",
2733 {
$76 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/lib/thumb/", data=0x7fffffffc8c0) at
2733 {
$77 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
Since all previous attempts to find the file failed, it picks up
"/opt/rtems-4.12/arm-rtems4.12/lib/thumb/crt0.o".
Is this a bug in the Newlib build, e.g. crt0.o is placed in the wrong
build directory? We have in the build tree:
find -name crt0.o
./arm-rtems4.12/newlib/crt0.o
./arm-rtems4.12/newlib/libc/crt0.o
./arm-rtems4.12/newlib/libc/sys/crt0.o
./arm-rtems4.12/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/newlib/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/newlib/libc/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/newlib/libc/sys/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/vfpv3-d16/hard/newlib/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/vfpv3-d16/hard/newlib/libc/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/vfpv3-d16/hard/newlib/libc/sys/crt0.o
./arm-rtems4.12/eb/thumb/armv7-r/vfpv3-d16/hard/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/newlib/crt0.o
./arm-rtems4.12/thumb/newlib/libc/crt0.o
./arm-rtems4.12/thumb/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/newlib/crt0.o
./arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/newlib/libc/crt0.o
./arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv6-m/newlib/crt0.o
./arm-rtems4.12/thumb/armv6-m/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv6-m/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv6-m/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv7-m/newlib/crt0.o
./arm-rtems4.12/thumb/armv7-m/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv7-m/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv7-m/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv7-m/fpv4-sp-d16/hard/newlib/crt0.o
./arm-rtems4.12/thumb/armv7-m/fpv4-sp-d16/hard/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv7-m/fpv4-sp-d16/hard/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv7-m/fpv4-sp-d16/hard/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv7-r/newlib/crt0.o
./arm-rtems4.12/thumb/armv7-r/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv7-r/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv7-r/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv7-r/vfpv3-d16/hard/newlib/crt0.o
./arm-rtems4.12/thumb/armv7-r/vfpv3-d16/hard/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv7-r/vfpv3-d16/hard/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv7-r/vfpv3-d16/hard/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv7-a/newlib/crt0.o
./arm-rtems4.12/thumb/armv7-a/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv7-a/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv7-a/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/thumb/armv7-a/neon/hard/newlib/crt0.o
./arm-rtems4.12/thumb/armv7-a/neon/hard/newlib/libc/crt0.o
./arm-rtems4.12/thumb/armv7-a/neon/hard/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/armv7-a/neon/hard/newlib/libc/sys/rtems/crt0.o
./arm-rtems4.12/vfp/hard/newlib/crt0.o
./arm-rtems4.12/vfp/hard/newlib/libc/crt0.o
./arm-rtems4.12/vfp/hard/newlib/libc/sys/crt0.o
./arm-rtems4.12/vfp/hard/newlib/libc/sys/rtems/crt0.o
None of the crt0.o is in a search directory of GCC.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
