Bug in gcc.c for_each_path() (leads to invalid crt0.o selection)?
Mon Dec 5 09:02:08 UTC 2016
Hello,
I noticed that the ARM libgomp is built without TLS support for RTEMS,
since the thread-local storage detection fails, due to missing symbols
in the crt0.o. I added the missing symbols to newlib/libc/sys/rtems/crt0.c:
https://sourceware.org/ml/newlib/2016/msg01138.html
However, this still didn't work. The reason is that during GCC build the
random crt0.o of the prefix is used.
The configure test command line is:
/build/git-build/b-gcc-git-arm-rtems4.12/./gcc/xgcc
-B/build/git-build/b-gcc-git-arm-rtems4.12/./gcc/ -nostdinc
-B/build/git-build/b-gcc-git-arm-rtems4.12/arm-rtems4.12/thumb/newlib/
-isystem
/build/git-build/b-gcc-git-arm-rtems4.12/arm-rtems4.12/thumb/newlib/targ-include
-isystem /home/EB/sebastian_h/archive/gcc-git/newlib/libc/include
-B/opt/rtems-4.12/arm-rtems4.12/bin/
-B/opt/rtems-4.12/arm-rtems4.12/lib/ -isystem
/opt/rtems-4.12/arm-rtems4.12/include -isystem
/opt/rtems-4.12/arm-rtems4.12/sys-include  -mthumb -o conftest -g -O2
conftest.c
GCC searches then in:
Breakpoint 10, file_at_path (path=0x72a960
"/build/git-build/b-gcc-git-arm-rtems4.12/./gcc/arm-rtems4.12/7.0.0/thumb/",
data=0x7fffffffc8c0) at /home/EB/sebastian_h/archive/gcc-git/gcc/gcc.c:2733
2733    {
$70 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
suffix_len = 0, mode = 4}
"/build/git-build/b-gcc-git-arm-rtems4.12/./gcc/thumb/",
2733    {
$71 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/build/git-build/b-gcc-git-arm-rtems4.12/arm-rtems4.12/thumb/newlib/arm-rtems4.12/7.0.0/thumb/",
2733    {
$72 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/build/git-build/b-gcc-git-arm-rtems4.12/arm-rtems4.12/thumb/newlib/thumb/",
2733    {
$73 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/bin/arm-rtems4.12/7.0.0/thumb/",
2733    {
$74 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/bin/thumb/", data=0x7fffffffc8c0) at
2733    {
$75 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/lib/arm-rtems4.12/7.0.0/thumb/",
2733    {
$76 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
"/opt/rtems-4.12/arm-rtems4.12/lib/thumb/", data=0x7fffffffc8c0) at
2733    {
$77 = {name = 0x728d00 "crt0.o", suffix = 0x4d2257 "", name_len = 6,
Since all previous attempts to find the file failed, it picks up
"/opt/rtems-4.12/arm-rtems4.12/lib/thumb/crt0.o".
We have in the build tree:
find -name crt0.o
./arm-rtems4.12/thumb/newlib/crt0.o
./arm-rtems4.12/thumb/newlib/libc/crt0.o
./arm-rtems4.12/thumb/newlib/libc/sys/crt0.o
./arm-rtems4.12/thumb/newlib/libc/sys/rtems/crt0.o
In gcc.c we have:
/* Call CALLBACK for each path in PATHS, breaking out early if CALLBACK
    returns non-NULL.
    If DO_MULTI is true iterate over the paths twice, first with multilib
    suffix then without, otherwise iterate over the paths once without
    adding a multilib suffix.  When DO_MULTI is true, some attempt is made
    to avoid visiting the same path twice, but we could do better.  For
    instance, /usr/lib/../lib is considered different from /usr/lib.
    At least EXTRA_SPACE chars past the end of the path passed to
    CALLBACK are available for use by the callback.
    CALLBACK_INFO allows extra parameters to be passed to CALLBACK.
    Returns the value returned by CALLBACK.  */
static void *
for_each_path (const struct path_prefix *paths,
	       bool do_multi,
	       size_t extra_space,
	       void *(*callback) (char *, void *),
	       void *callback_info)
We have
Its not really clear from the documentation how the search order and
command line order is related.  The documentation doesn't mention
multilib and multiarch options.
https://gcc.gnu.org/onlinedocs/gcc/Directory-Options.html
If we assume that the command line order determines the search order,
then its not clear why for_each_path() first iterates for all paths with
the multilib postfix and then without. Shouldn't it iterate over all
paths and check with/without multilib postfix in each step?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
