QT 5.8 Port
Wed Dec 7 20:42:15 UTC 2016
On Dec 7, 2016 1:49 PM, "Kirspel, Kevin" <Kevin-Kirspel at idexx.com> wrote:
I’m porting QT 5.8 to RTEMS 4.12 and rtems-libbsd.  I had to add pipe
support to rtems-libbsd.  I would like to submit the pipe patch but the
“git diff” is long due to the fact that the diff includes the entire file
contents of the modified sys_pipe.c and pipe.h files.  How do you usually
submit patches for review for rtems-libbsd?
The same way as normal. You could compress the diff if that shrinks it
enough to attach a d get to the main list
Probably easier to file a ticket.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642 <(770)%20510-4444>
Direct: (770)-688-1642 <(770)%20688-1642>
Fax: (770)-510-4445 <(770)%20510-4445>
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161207/adb80788/attachment.html>
