QT 5.8 Port
Fri Dec 9 08:44:09 UTC 2016
Hello Kevin,
we already have a (broken) pipe support in RTEMS
https://git.rtems.org/rtems/tree/cpukit/libcsupport/src/pipe.c
What is the befit of using the FreeBSD pipe implementation?
On 07/12/16 19:49, Kirspel, Kevin wrote:
> I’m porting QT 5.8 to RTEMS 4.12 and rtems-libbsd.  I had to add pipe
> support to rtems-libbsd.  I would like to submit the pipe patch but
> the “git diff” is long due to the fact that the diff includes the
> entire file contents of the modified sys_pipe.c and pipe.h files.  How
> do you usually submit patches for review for rtems-libbsd?
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Idexx Roswell
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
