[PATCH 7/7] Adding pipe support
Mon Dec 12 07:42:38 UTC 2016
On 09/12/16 21:26, Kevin Kirspel wrote:
> @@ -280,10 +298,14 @@ start_worker(test_context *ctx)
>   static void
>   set_non_blocking(int fd, int enable)
> -	int rv;
> +	int flags = fcntl(fd, F_GETFL, 0);
> -	rv = ioctl(fd, FIONBIO, &enable);
> -	assert(rv == 0);
> +	if (enable ) {
> +		fcntl(fd, F_SETFL, flags | O_NONBLOCK);
> +	else{
> +		fcntl(fd, F_SETFL, flags & ~O_NONBLOCK);
All return values should be checked in the tests. Please use BSD style
for the { }.
Please remove all white-space changes of original BSD files.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
