testsuite/selectpollkqueue01/test_main.c | 186 ++++++++++++++++++++++++++++++-
1 file changed, 183 insertions(+), 3 deletions(-)
mode change 100644 => 100755 testsuite/selectpollkqueue01/test_main.c
diff --git a/testsuite/selectpollkqueue01/test_main.c b/testsuite/selectpollkqueue01/test_main.c
old mode 100644
new mode 100755
index 8f76049..c56327b
--- a/testsuite/selectpollkqueue01/test_main.c
+++ b/testsuite/selectpollkqueue01/test_main.c
@@ -55,7 +55,7 @@
#include <rtems/libcsupport.h>
-#define TEST_NAME "LIBBSD SELECT AND POLL AND KQUEUE 1"
+#define TEST_NAME "LIBBSD SELECT AND POLL AND KQUEUE AND PIPE 1"
#define PRIO_MASTER 1
@@ -71,6 +71,8 @@
#define EVENT_SHUTDOWN RTEMS_EVENT_4
+#define EVENT_CLOSE_PIPE RTEMS_EVENT_5
#define BUF_SIZE 4096
#define PORT 1234
@@ -88,6 +90,7 @@ typedef struct {
int afd;
int rfd;
int wfd;
+ int pfd[2];
struct sockaddr_in caddr;
rtems_id worker_task;
} test_context;
@@ -173,6 +176,8 @@ worker_task(rtems_task_argument arg)
ssize_t n;
int rv;
int cfd = ctx->cfd;
+ int rfd = ctx->pfd[0];
+ int wfd = ctx->pfd[1];
sc = rtems_event_receive(
RTEMS_ALL_EVENTS,
@@ -236,6 +241,19 @@ worker_task(rtems_task_argument arg)
assert(rv == 0);
+ if ((events & EVENT_CLOSE_PIPE) != 0) {
+ puts("worker: close pipe");
+ ctx->pfd[0] = -1;
+ ctx->pfd[1] = -1;
+ rv = close(wfd);
+ assert(rv == 0);
+ rv = close(rfd);
+ assert(rv == 0);
if ((events & EVENT_SHUTDOWN) != 0) {
puts("worker: shutdown");
@@ -281,9 +299,15 @@ static void
set_non_blocking(int fd, int enable)
int rv;
+ int flags = fcntl(fd, F_GETFL, 0);
- rv = ioctl(fd, FIONBIO, &enable);
- assert(rv == 0);
+ if (enable) {
+ rv = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
+ assert(rv == 0);
+ } else {
+ rv = fcntl(fd, F_SETFL, flags & ~O_NONBLOCK);
+ assert(rv == 0);
static void
@@ -1004,6 +1028,157 @@ test_kqueue_user(test_context *ctx)
static void
+test_pipe_timeout(test_context *ctx)
+ struct pipe_poll_events
+ short event;
+ int rv;
+ const struct pipe_poll_events events[] = {
+ { POLLIN, 0 },
+ { POLLPRI, 0 },
+ { POLLOUT, 1 },
+ { POLLRDNORM, 0 },
+ { POLLWRNORM, 1 },
+ { POLLRDBAND, 0 },
+ { POLLWRBAND, 0 },
+ { POLLINIGNEOF, 0 }
+ int timeout = 100;
+ struct pollfd pfd;
+ size_t i;
+ int rv;
+ puts("test pipe timeout");
+ rv = pipe(ctx->pfd);
+ assert(rv == 0);
+ pfd.fd = ctx->pfd[1];
+ for (i = 0; i < nitems(events); ++i) {
+ int rv;
+ pfd.events = events[i].event;
+ pfd.revents = 0;
+ rv = poll(&pfd, 1, timeout);
+ assert(rv == events[i].rv);
+static void
+test_pipe_read(test_context *ctx)
+ struct pollfd pfd = {
+ .fd = rfd,
+ .events = POLLIN
+ int timeout = -1;
+ int rv;
+ ssize_t n;
+ puts("test pipe read");
+ assert(rfd >= 0);
+ assert(wfd >= 0);
+ ctx->wfd = wfd;
+ ctx->wbuf = &msg[0];
+ ctx->wn = sizeof(msg);
+ send_events(ctx, EVENT_WRITE);
+ set_non_blocking(rfd, 1);
+ errno = 0;
+ n = read(rfd, &ctx->buf[0], sizeof(ctx->buf));
+ assert(n == -1);
+ assert(errno == EAGAIN);
+ assert(rv == 1);
+ assert(pfd.revents == POLLIN);
+ assert(n == (ssize_t) sizeof(msg));
+ assert(memcmp(&msg[0], &ctx->buf[0], sizeof(msg)) == 0);
+static void
+test_pipe_write(test_context *ctx)
+ .fd = wfd,
+ .events = POLLOUT
+ int timeout = -1;
+ int rv;
+ ssize_t n;
+ puts("test pipe write");
+ assert(rfd >= 0);
+ assert(wfd >= 0);
+ ctx->rfd = rfd;
+ ctx->rbuf = &ctx->buf[0];
+ ctx->rn = sizeof(ctx->buf);
+ send_events(ctx, EVENT_READ);
+ set_non_blocking(wfd, 1);
+ do {
+ errno = 0;
+ n = write(wfd, &ctx->buf[0], sizeof(ctx->buf));
+ if (n == -1) {
+ } while (n > 0);
+ assert(rv == 1);
+ assert(pfd.revents == POLLOUT);
+static void
+test_pipe_close(test_context *ctx)
+ .fd = rfd,
+ .events = POLLIN
+ int timeout = -1;
+ int rv;
+ puts("test pipe close");
+ assert(ctx->pfd[0] >= 0);
+ assert(ctx->pfd[1] >= 0);
+ send_events(ctx, EVENT_CLOSE_PIPE);
+ set_non_blocking(rfd, 0);
+ assert(rv == 1);
+ assert(pfd.revents == (POLLIN | POLLHUP));
+ assert(ctx->pfd[0] == -1);
+ assert(ctx->pfd[1] == -1);
+static void
test_main(void)
test_context *ctx = &test_instance;
@@ -1034,6 +1209,11 @@ test_main(void)
test_kqueue_close(ctx);
test_kqueue_user(ctx);
+ test_pipe_timeout(ctx);
+ test_pipe_read(ctx);
+ test_pipe_write(ctx);
+ test_pipe_close(ctx);
exit(0);
1.9.1
