[PATCH 06/10] Add warning to ATA/IDE driver chapter
Tue Dec 20 13:45:23 UTC 2016
Close #2849.
 bsp-howto/ata.rst            | 7 +++++++
 bsp-howto/ide_controller.rst | 7 +++++++
 bsp-howto/index.rst          | 4 ++--
 3 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/bsp-howto/ata.rst b/bsp-howto/ata.rst
index 9416a80..7e7e2e8 100644
--- a/bsp-howto/ata.rst
+++ b/bsp-howto/ata.rst
@@ -7,6 +7,13 @@
 ATA Driver
+.. warning::
+   The ATA/IDE Drivers are out of date and should not be used for new BSPs.
+   The preferred alternative is to port the ATA/SATA/SCSI/NVMe support from
+   FreeBSD to RTEMS using the `libbsd <https://git.rtems.org/rtems-libbsd>`_.
+   Ask on the mailing list if you plan to write a driver for an ATA/IDE device.
 Terms
diff --git a/bsp-howto/ide_controller.rst b/bsp-howto/ide_controller.rst
index c5e4435..101c962 100644
--- a/bsp-howto/ide_controller.rst
+++ b/bsp-howto/ide_controller.rst
@@ -7,6 +7,13 @@
 IDE Controller Driver
+.. warning::
 Introduction
diff --git a/bsp-howto/index.rst b/bsp-howto/index.rst
index d826369..ac0d5c0 100644
--- a/bsp-howto/index.rst
+++ b/bsp-howto/index.rst
@@ -51,11 +51,11 @@ to the Community Project hosted at http://www.rtems.org.
 	spi
 	timer
 	real_time_clock
-	ata
-	ide_controller
 	networking
 	shared_memory_support
 	frame_buffer
+	ata
+	ide_controller
 	command
 *	:ref:`genindex`
1.8.4.5
