[PATCH 01/13] or1k: Delete superfluous _CPU_Null_fp_context
Thu Feb 4 06:37:31 UTC 2016
Update #2559.
 cpukit/score/cpu/or1k/rtems/score/cpu.h | 18 +-----------------
 1 file changed, 1 insertion(+), 17 deletions(-)
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 2405844..7364343 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -391,7 +391,6 @@ typedef Context_Control CPU_Interrupt_frame;
 #define CPU_CONTEXT_FP_SIZE  0
-SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
  *  Amount of extra stack (above minimum stack size) required by
@@ -653,23 +652,8 @@ void _CPU_Context_Initialize(
 #define _CPU_Context_Fp_start( _base, _offset ) \
    ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
- *  This routine initializes the FP context area passed to it to.
- *  There are a few standard ways in which to initialize the
- *  floating point context.  The code included for this macro assumes
- *  that this is a CPU in which a "initial" FP context was saved into
- *  _CPU_Null_fp_context and it simply copies it to the destination
- *  context passed to it.
- *  Other models include (1) not doing anything, and (2) putting
- *  a "null FP status word" in the correct place in the FP context.
 #define _CPU_Context_Initialize_fp( _destination ) \
-   *(*(_destination)) = _CPU_Null_fp_context; \
+  memset( *( _destination ), 0, CPU_CONTEXT_FP_SIZE );
 /* end of Context handler macros */
1.8.4.5
