Python problem
Joel Sherrill
joel at rtems.org
Tue Feb 9 14:51:09 UTC 2016
On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com> wrote:
> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
> > Hi,
> > I was having the same problem yesterday and managed to find a fix by
> > installing libpython2.7-dev:
> > sudo apt-get install libpython2.7-dev
> > Aun-Ali Zaidi
> Thanks Aun-Ali. I have tried but again I am getting same error.
> Because this package would get installed when you install
> python2.7-dev
Can you look in the config.log for gdb where the failure occurred? Or even
at the configure.in/ac script in its source. It is looking for a very
specific
file to link against and failing.
yum have a "provides" subcommand to search for which package provides
a specific file. Apt must have a similar capability.
So you can figure out the file gdb needs to link and the corresponding
package which includes it.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160209/acb40739/attachment.html>
