Python problem
punit vara
punitvara at gmail.com
Wed Feb 10 17:50:12 UTC 2016
On Tue, Feb 9, 2016 at 8:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com> wrote:
>> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
>> > Hi,
>> > I was having the same problem yesterday and managed to find a fix by
>> > installing libpython2.7-dev:
>> > sudo apt-get install libpython2.7-dev
>> > Aun-Ali Zaidi
>> Thanks Aun-Ali. I have tried but again I am getting same error.
>> Because this package would get installed when you install
>> python2.7-dev
> Can you look in the config.log for gdb where the failure occurred? Or even
> at the configure.in/ac script in its source. It is looking for a very
> specific
> file to link against and failing.
> yum have a "provides" subcommand to search for which package provides
> a specific file. Apt must have a similar capability.
> So you can figure out the file gdb needs to link and the corresponding
> package which includes it.
> --joel
>> devel mailing list
>> devel at rtems.org
Yes I agree with you Joel. From line 129 I found errors if you can
help me out. Perhaps somebody can help me I am attaching config.log
file from
/home/punit/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160210/ea22b75e/attachment-0001.bin>
