Python problem
Joel Sherrill
joel at rtems.org
Wed Feb 10 18:15:32 UTC 2016
We need the config.log from the subdirectory where the failure occurred.
This looks like one from the top directory,
Look at the build log to see what directory the build failed in and grab
that one.
FWIW a quick google for this issue on Ubuntu showed someone suggested:
sudo apt-get install python-dev
Have you done that?
--joel
On Wed, Feb 10, 2016 at 11:50 AM, punit vara <punitvara at gmail.com> wrote:
> On Tue, Feb 9, 2016 at 8:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> > On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com> wrote:
> >> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
> >> > Hi,
> >> > I was having the same problem yesterday and managed to find a fix by
> >> > installing libpython2.7-dev:
> >> > sudo apt-get install libpython2.7-dev
> >> > Aun-Ali Zaidi
> >> Thanks Aun-Ali. I have tried but again I am getting same error.
> >> Because this package would get installed when you install
> >> python2.7-dev
> > Can you look in the config.log for gdb where the failure occurred? Or
> even
> > at the configure.in/ac script in its source. It is looking for a very
> > specific
> > file to link against and failing.
> > yum have a "provides" subcommand to search for which package provides
> > a specific file. Apt must have a similar capability.
> > So you can figure out the file gdb needs to link and the corresponding
> > package which includes it.
> > --joel
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> Yes I agree with you Joel. From line 129 I found errors if you can
> help me out. Perhaps somebody can help me I am attaching config.log
> file from
> /home/punit/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160210/826896cf/attachment.html>
