OpenRISC patch series...
Jakob Viketoft jakob.viketoft at aacmicrotec.com
Fri Feb 19 15:48:29 UTC 2016
________________________________________
From: gedare at gwmail.gwu.edu [gedare at gwmail.gwu.edu] on behalf of Gedare Bloom [gedare at rtems.org]
Sent: Friday, February 19, 2016 15:58
To: Jakob Viketoft
Cc: devel at rtems.org
Subject: Re: OpenRISC patch series...
>On Fri, Feb 19, 2016 at 7:59 AM, Jakob Viketoft
>> From: Sebastian Huber [sebastian.huber at embedded-brains.de]
>> Sent: Friday, February 19, 2016 13:44
>> To: Jakob Viketoft; devel at rtems.org
>>>On 19/02/16 13:40, Jakob Viketoft wrote:
>> Ok, does the format work on this first set? I assume it's okay to resend all 7 patches again, rebased on master.
>I haven't tried to apply these patches, but they don't quite look like
>they were sent properly by git-send-email. Your signature line is
>appended at the bottom.
The simple answer is because I didn't. :) I was hoping to get away anyway since I'm working through a less then optimal e-mail solution in git terms, but I'll have a go at sending them directly instead.
Jakob Viketoft
Senior Engineer in RTL and embedded software
ÅAC Microtec AB
Dag Hammarskjölds väg 48
SE-751 83 Uppsala, Sweden
T: +46 702 80 95 97
http://www.aacmicrotec.com
