OpenRISC patch series...
Fri Feb 19 16:41:08 UTC 2016
On Fri, Feb 19, 2016 at 10:48 AM, Jakob Viketoft
<jakob.viketoft at aacmicrotec.com> wrote:
> ________________________________________
> From: gedare at gwmail.gwu.edu [gedare at gwmail.gwu.edu] on behalf of Gedare Bloom [gedare at rtems.org]
> Sent: Friday, February 19, 2016 15:58
> To: Jakob Viketoft
> Cc: devel at rtems.org
> Subject: Re: OpenRISC patch series...
>>On Fri, Feb 19, 2016 at 7:59 AM, Jakob Viketoft
>>> From: Sebastian Huber [sebastian.huber at embedded-brains.de]
>>> Sent: Friday, February 19, 2016 13:44
>>> To: Jakob Viketoft; devel at rtems.org
>>>>On 19/02/16 13:40, Jakob Viketoft wrote:
>>> Ok, does the format work on this first set? I assume it's okay to resend all 7 patches again, rebased on master.
>>I haven't tried to apply these patches, but they don't quite look like
>>they were sent properly by git-send-email. Your signature line is
>>appended at the bottom.
> The simple answer is because I didn't. :) I was hoping to get away anyway since I'm working through a less then optimal e-mail solution in git terms, but I'll have a go at sending them directly instead.
If you can't use git-send-email, just attach them separately, Anything
else is complicated to pull the patch out of the email.
