Python problem
Jason Wong jason.hcwong at gmail.com
Thu Feb 11 21:51:19 UTC 2016
I am using a docker image running Ubuntu 15.10, I have no problem
installing both "python2.7-dev" and "libpython2.7-dev".
According to apt-cache, "python2.7-dev" depends on "python2.7".
If you install "python2.7-dev", then "python2.7" should be automatically
installed.
Perhaps you should show us the message you got when you try to install
 "python2.7-dev", and you should also report the problem to ubuntu
community as well.
root at c0e8f7d4cae3:/# apt-cache depends python2.7-dev
python2.7-dev
  Depends: python2.7
  Depends: libpython2.7-dev
  Depends: libexpat1-dev
 |Recommends: libc6-dev
  Recommends: <libc-dev>
    libc6-dev
  Replaces: python2.7
On 11 February 2016 at 19:44, punit vara <punitvara at gmail.com> wrote:
> On Wed, Feb 10, 2016 at 11:45 PM, Joel Sherrill <joel at rtems.org> wrote:
> > We need the config.log from the subdirectory where the failure occurred.
> > This looks like one from the top directory,
> > Look at the build log to see what directory the build failed in and grab
> > that one.
> > FWIW a quick google for this issue on Ubuntu showed someone suggested:
> > sudo apt-get install python-dev
> > Have you done that?
> > --joel
> > On Wed, Feb 10, 2016 at 11:50 AM, punit vara <punitvara at gmail.com>
> wrote:
> >> On Tue, Feb 9, 2016 at 8:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> >> > On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com>
> wrote:
> >> >> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net>
> wrote:
> >> >> > Hi,
> >> >> > I was having the same problem yesterday and managed to find a fix
> by
> >> >> > installing libpython2.7-dev:
> >> >> > sudo apt-get install libpython2.7-dev
> >> >> > Aun-Ali Zaidi
> >> >> Thanks Aun-Ali. I have tried but again I am getting same error.
> >> >> Because this package would get installed when you install
> >> >> python2.7-dev
> >> > Can you look in the config.log for gdb where the failure occurred? Or
> >> > even
> >> > at the configure.in/ac script in its source. It is looking for a very
> >> > specific
> >> > file to link against and failing.
> >> > yum have a "provides" subcommand to search for which package provides
> >> > a specific file. Apt must have a similar capability.
> >> > So you can figure out the file gdb needs to link and the corresponding
> >> > package which includes it.
> >> > --joel
> >> >> _______________________________________________
> >> >> devel mailing list
> >> >> devel at rtems.org
> >> >> http://lists.rtems.org/mailman/listinfo/devel
> >> Yes I agree with you Joel. From line 129 I found errors if you can
> >> help me out. Perhaps somebody can help me I am attaching config.log
> >> file from
> /home/punit/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build
> Yes I tried that before but same error.  I am attaching log file I
> have sent config.log from failure subdirectory. I have provided
> location in previous mail which is the same as shown in this log file.
> If I am wrong let me.
> Thanks for support.
> devel mailing list
> devel at rtems.org
Regards,
Jason Wong
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160211/245e1f58/attachment-0002.html>
