Python problem
punit vara punitvara at gmail.com
Fri Feb 12 21:38:21 UTC 2016
On Fri, Feb 12, 2016 at 3:21 AM, Jason Wong <jason.hcwong at gmail.com> wrote:
> I am using a docker image running Ubuntu 15.10, I have no problem installing
> both "python2.7-dev" and "libpython2.7-dev".
> According to apt-cache, "python2.7-dev" depends on "python2.7".
> If you install "python2.7-dev", then "python2.7" should be automatically
> installed.
> Perhaps you should show us the message you got when you try to install
> "python2.7-dev", and you should also report the problem to ubuntu community
> as well.
> root at c0e8f7d4cae3:/# apt-cache depends python2.7-dev
> python2.7-dev
>   Depends: python2.7
>   Depends: libpython2.7-dev
>   Depends: libexpat1-dev
>  |Recommends: libc6-dev
>   Recommends: <libc-dev>
>     libc6-dev
>   Replaces: python2.7
> On 11 February 2016 at 19:44, punit vara <punitvara at gmail.com> wrote:
>> On Wed, Feb 10, 2016 at 11:45 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > We need the config.log from the subdirectory where the failure occurred.
>> > This looks like one from the top directory,
>> > Look at the build log to see what directory the build failed in and grab
>> > that one.
>> > FWIW a quick google for this issue on Ubuntu showed someone suggested:
>> > sudo apt-get install python-dev
>> > Have you done that?
>> > --joel
>> > On Wed, Feb 10, 2016 at 11:50 AM, punit vara <punitvara at gmail.com>
>> > wrote:
>> >> On Tue, Feb 9, 2016 at 8:21 PM, Joel Sherrill <joel at rtems.org> wrote:
>> >> > On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com>
>> >> > wrote:
>> >> >> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net>
>> >> >> wrote:
>> >> >> > Hi,
>> >> >> > I was having the same problem yesterday and managed to find a fix
>> >> >> > by
>> >> >> > installing libpython2.7-dev:
>> >> >> > sudo apt-get install libpython2.7-dev
>> >> >> > Aun-Ali Zaidi
>> >> >> Thanks Aun-Ali. I have tried but again I am getting same error.
>> >> >> Because this package would get installed when you install
>> >> >> python2.7-dev
>> >> > Can you look in the config.log for gdb where the failure occurred? Or
>> >> > even
>> >> > at the configure.in/ac script in its source. It is looking for a very
>> >> > specific
>> >> > file to link against and failing.
>> >> > yum have a "provides" subcommand to search for which package provides
>> >> > a specific file. Apt must have a similar capability.
>> >> > So you can figure out the file gdb needs to link and the
>> >> > corresponding
>> >> > package which includes it.
>> >> > --joel
>> >> >> _______________________________________________
>> >> >> devel mailing list
>> >> >> devel at rtems.org
>> >> >> http://lists.rtems.org/mailman/listinfo/devel
>> >> Yes I agree with you Joel. From line 129 I found errors if you can
>> >> help me out. Perhaps somebody can help me I am attaching config.log
>> >> file from
>> >> /home/punit/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build
>> Yes I tried that before but same error.  I am attaching log file I
>> have sent config.log from failure subdirectory. I have provided
>> location in previous mail which is the same as shown in this log file.
>> If I am wrong let me.
>> Thanks for support.
>> devel mailing list
>> devel at rtems.org
> Regards,
> Jason Wong
root at punit-Compaq-420:~# apt-cache depends python2.7-dev
python2.7-dev
  Depends: python2.7
    libc6-dev
  Replaces: python2.7
  Replaces: python2.7:i386
  Conflicts: python2.7-dev:i386
Thanks Jason this is really helpful. I am attaching log file as well .
How did you solve python missing error. I have found some linking
error and some header file error. Please look into it. I have already
asked to ubuntu community but not yet got any answer.
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160213/1002f466/attachment-0002.bin>
