Rtems-test cortex-m3
Wed Jan 6 21:49:30 UTC 2016
On 07/01/2016 03:40, Aurelio Remonda wrote:
> Hello, i am trying use Rtems tester framework. The goal is to run the
> test on qemu for a board with cortex m3 (lpc1768).
> As far as i know qemu does not support lpc1768 so i choose Stellaris
> lm3s6965 which has a cortex m3 too.
> Im not sure i understand the information given by rtems-tester --list-bsps.
> For example it shows armcortexa9, armcortexa9-run and
> realview_pbx_a9_qemu board wich, from what i understand, has a cortex
> a9.
> So this does not support what im trying to test? If it doesn't can you
> give me a hint of how to add it?
Have a look in
https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/bsps.
You will find examples of using qemu, gdb and the gdb simulators.
I have not done any work on the tester in a long while and it need some
more work to clean up the configuration file support.
