Rtems-test cortex-m3
Thu Jan 7 06:34:05 UTC 2016
Hello Aurelio,
for the lm3s6965 you need a special Qemu version, see
https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
I tried to integrate the patches in Qemu, but this required more time
than I had.
On 06/01/16 17:40, Aurelio Remonda wrote:
> Hello, i am trying use Rtems tester framework. The goal is to run the
> test on qemu for a board with cortex m3 (lpc1768).
> As far as i know qemu does not support lpc1768 so i choose Stellaris
> lm3s6965 which has a cortex m3 too.
> Im not sure i understand the information given by rtems-tester --list-bsps.
> For example it shows armcortexa9, armcortexa9-run and
> realview_pbx_a9_qemu board wich, from what i understand, has a cortex
> a9.
> So this does not support what im trying to test? If it doesn't can you
> give me a hint of how to add it?
> Thank you.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
