[PATCH 2/2] score: Avoid dead code in global construction
Thu Jan 7 09:11:48 UTC 2016
Update #2514.
 cpukit/posix/src/pthreadinitthreads.c         | 11 ++++++++++-
 cpukit/rtems/src/taskinitusers.c              | 11 ++++++++++-
 cpukit/score/include/rtems/score/threadimpl.h |  2 +-
 cpukit/score/src/threadglobalconstruction.c   | 18 +-----------------
 4 files changed, 22 insertions(+), 20 deletions(-)
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index 9842316..6584b83 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -35,6 +35,15 @@
 #include <rtems/posix/config.h>
 #include <rtems/rtems/config.h>
+static void *_POSIX_Global_construction( void *arg )
+  Thread_Entry entry_point = (Thread_Entry) Configuration_POSIX_API
+    .User_initialization_threads_table[ 0 ].thread_entry;
+  (void) arg;
+  _Thread_Global_construction( entry_point );
 void _POSIX_Threads_Initialize_user_threads_body(void)
   int                                 eno;
@@ -84,7 +93,7 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
     if ( register_global_construction ) {
       register_global_construction = false;
-      thread_entry = (Thread_Entry_pointer) _Thread_Global_construction;
+      thread_entry = _POSIX_Global_construction;
     eno = pthread_create(
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 46d0af3..f5c2f82 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -31,6 +31,15 @@
 #include <rtems/score/apiext.h>
+static void _RTEMS_Global_construction( rtems_task_argument arg )
+    Configuration_RTEMS_API.User_initialization_tasks_table[ 0 ].entry_point;
+  (void) arg;
  *  _RTEMS_tasks_Initialize_user_tasks_body
@@ -92,7 +101,7 @@ void _RTEMS_tasks_Initialize_user_tasks_body( void )
-      entry_point = (rtems_task_entry) _Thread_Global_construction;
+      entry_point = _RTEMS_Global_construction;
     return_value = rtems_task_start(
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index c61dd89..abdd7e6 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -325,7 +325,7 @@ void _Thread_Handler( void );
  * the first POSIX initialization thread in case no RTEMS initialization tasks
  * are present.
-void *_Thread_Global_construction( void );
+void _Thread_Global_construction( Thread_Entry entry_point ) RTEMS_NO_RETURN;
  *  @brief Ended the delay of a thread.
diff --git a/cpukit/score/src/threadglobalconstruction.c b/cpukit/score/src/threadglobalconstruction.c
index c7c10d9..56a6df1 100644
--- a/cpukit/score/src/threadglobalconstruction.c
+++ b/cpukit/score/src/threadglobalconstruction.c
@@ -44,10 +44,9 @@
   #define EXECUTE_GLOBAL_CONSTRUCTORS
 #endif
   Thread_Control *executing;
-  Thread_Entry    entry_point;
 #if defined(EXECUTE_GLOBAL_CONSTRUCTORS)
@@ -58,19 +57,6 @@ void *_Thread_Global_construction( void )
   INIT_NAME();
 #endif
-#if defined(RTEMS_POSIX_API)
-  if ( Configuration_RTEMS_API.number_of_initialization_tasks > 0 ) {
-#endif
-    entry_point = (Thread_Entry)
-      Configuration_RTEMS_API.User_initialization_tasks_table[ 0 ].entry_point;
-  } else {
-      Configuration_POSIX_API
-        .User_initialization_threads_table[ 0 ].thread_entry;
-#endif
   _Thread_Disable_dispatch();
   executing = _Thread_Executing;
@@ -86,6 +72,4 @@ void *_Thread_Global_construction( void )
   _Thread_Enable_dispatch();
   _Assert_Not_reached();
-  return NULL;
1.8.4.5
